- Jun 20, 2007
- 3,942 (0.64/day)
System Name | Widow |
Processor | Ryzen 7600x |
Motherboard | AsRock B650 HDVM.2 |
Cooling | CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5) |
Memory | 32GB Gskill Flare X5 |
Video Card(s) | GTX 1080 TI |
Storage | Samsung 9series NVM 2TB and Rust |
Display(s) | Predator X34P/Tempest X270OC @ 120hz / LG W3000h |
Case | Fractal Define S [Antec Skeleton hanging in hall of fame] |
Audio Device(s) | Asus Xonar Xense with AKG K612 cans on Monacor SA-100 |
Power Supply | Seasonic X-850 |
Mouse | Razer Naga 2014 |
Software | Windows 11 Pro |
Benchmark Scores | FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x |
This is my first 'request' post for parts of any type, which I could have added to some of the previous threads, but do not want to hijack anyone.
I am looking to run a water/liquid system, primarily with CPU/VGA-GPU blocks, but would like further suggestions on a block for the northbridge and possibly the southbridge(if deemed appropriate, a simple heatsink may do?). The system will be connected to an EVGA 650i Ultra w/ LGA 775 and 8800 GTX.
I chose this board over the 680 SLI, because the core overclocking capabilities are enough for my needs, and the only main difference that would have appealed to me, is the NB/SB fan/sink piped combo and the MOSFET thermal covers. As I understand it, that NB/SB combo is better than nothing, but is not competitive versus a custom liquid block or air cooling setup.
Here is a list of websites, that I will be able to pull products from. If you know of any others feel free to make note.
*Note: Am willing to buy products from multiple vendors, but only if necessary.
http://specialtech.co.uk
http://coolercases.co.uk
http://www.overclockers.co.uk
http://www.overclock.co.uk <--- Yes, there is a difference
http://scan.co.uk
http://www.candccentral.co.uk/
http://www.aria.co.uk/Products
http://www.ebuyer.com
I'm going to set aside about 230 GBPounds (that's about 400+ USD?)
I would prefer to manage all the tools and parts for the liquid system, including CPU, GPU and NB block for 180GBP, give or take a bit. If it's more cost effective to run air cooling on the NB then so be it.
If I could also be pointed in the direction of where to get thermal protection for MOSFET and heatsink size for South Bridge.
For my entry-low level understanding:
I need:
Pump (d44ve jump in here if you like, and give me that run down on which pumps to avoid)
Radiator(w/ or without mounting brackets?)
Blocks (CPU LGA 775, GPU 8800 EK? (something full, rather than just a core mount) seems best)
3/8" tubing (is 1/2" bleh???)
Reservoir (no idea the ins and outs there)
Coolant (again, no idea)
EDIT: Thoughts on 'external' designs, like units that house the rad/fans/pump in one with LCD display and fan settings?
I suspect they are nice and compact persay, but a bit worried if either of the internal components goes bad.
http://scan.co.uk
I need:
