Hey guys thanks for the tips. I read it from first post to last and it helped me out in everything from did I get the right card to how to fix it up.
I updated the bios to v7 and then used CCC to up the speed. Unfortunately while the new bios is good at downclocking the card in 2d, it doesnt work when I have CCC overdrive on. So what I have done is used the CCC profile http://forums.techpowerup.com/showthread.php?t=117633 to make 2 profile, one for 2d and one for 3d.
In 3d I get 920/1200 stable using furmark @1900x1200 resolution. The temperature peaks at 86 degrees. I used the profile trick as per the instructions in http://forums.techpowerup.com/showthread.php?t=117633 but in 2d it would only go down to 300/1200. I dont know why the memory clock won't reduce.
So I made another profile, called it 2d and switched off the overdrive which gives me 157/300 in the desktop.
Does f7 fix the 55% fan speed bug?
System Name | Perpetual Upgrade Rig |
Processor | Intel Pentium Dual Core E5200 @ 3.5Ghz |
Motherboard | Gigabyte G31M-S2C |
Cooling | Scythe Ninja Plus, rev. B |
Memory | 2x2GB Kingston KVR DDR2-800 |
Video Card(s) | Powercolor HD4650 1GB DDR3 |
Storage | WD Caviar Blue 320GB SATA |
Display(s) | Acer X233H 23" 1080p LCD |
Case | Thermaltake V3 Black Edition |
Audio Device(s) | onboard |
Power Supply | OCZ ModXStream-Pro 500W (soon: Antec TPN 650) |
Software | Windows XP Pro SP3 / Win 7 Ultimate 32-bit |
Processor | Intel Core i7 860 2.80Ghz |
Motherboard | Asus P7P55-M |
Memory | G.Skill ECO 4GB 7-8-7-24 1.35v |
Video Card(s) | Gigabyte HD5850 OC 900/1200 |
Storage | 1Tb Spinpoint F1 + 1.5Tb Barracuda |
Display(s) | Dual Samsung 2333SW+ 1920x1080 |
Case | Lian Li PC V351 |
Power Supply | Corsair HX620 |
Software | Windows 7 Pro 64bit |
i still doubt the performance of the dual fan..
hi opinena, your card is running cool as i can see. mine is the other way round. wonder if it is the card's problem or the bios
There never really was an 'Issue'
The fans minimum speed in RPM reported by windows is ~2500RPM what this doesn't take into account is the dual fans, in actual fact each fan is running at 1250RPM and monitoring apps read it as one big number instead of two.
Well, I sent a mail to gigabyte a couple of months ago and they said they where working on a fix to make the idle fan speed lower. Is minimum fan speed still ~1250x2?
Yes it is, I'm not arguing that. But the fact is you use Windows to monitor the RPM of the fan, and windows can only read one signal from the GPU, so it combines the two fan speeds and that's what you see. Is it really that hard to understand?
Processor | Core i5-750 @ 3.6GHz 1.136V 24/7 |
Motherboard | Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby! |
Cooling | Alpenföhn Brocken HeatpipeDirectTouch |
Memory | Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24 |
Video Card(s) | Gigabyte GTX 460 1GB OC (mostly stock speeds) |
Storage | OS: Samsung F3 500GB Games: Samsung F1 640GB |
Display(s) | new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD |
Case | new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans |
Audio Device(s) | new! ASUS Xonar DG & JVC HA-RX700 headphones |
Power Supply | Cougar CM 700W Modular |
Software | Windows 7 Home Premium x64 |
Benchmark Scores | Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging |
