My ATI Radeon 5850 review (Gigabyte 5850OC) (custom dual fan model)
DeathMonk
3 (0.00/day)
You need to go into the afterburner.cfg file and edit the value for [unofficialatioverclocking] by changing the value to 1. There are also two other values in there for voltage control to change to 1.
Sweet.. Thanks erocker!
I'll see if I can squeeze any more out of it tonight :toast:
Byja
1 (0.00/day)
fan speed
I got strange issue whit my card.When i manually set fan above 92%,card crashing.Using F8 bios atm,i didnt notice that problem before.Not that i need 100% of speed ,i just wonder does anyone else have same problem or is it just my card?:wtf:
966 (0.17/day)
Motherboard MSI MAG X570S Tomahawk Max WiFi
Cooling EK Supremacy EVO Elite + EK D5 + EK 420 Rad, TT Toughfan 140x3, TT Toughfan 120x2, Arctic slim 120
Memory 32GB GSkill DDR4-3600 (F4-3600C16-8GVKC)
Video Card(s) Gigabyte Radeon RX 7900XTX Gaming OC
Storage WDBlack SN850X 4TB, Samsung 950Pro 512GB, Samsung 850EVO 500GB, 6TB WDRed, 36TB NAS, 8TB Lancache
Display(s) Benq XL2730Z (1440P 144Hz, TN, Freesync) & 2x ASUS VE248
Case Corsair Obsidian 750D
Audio Device(s) Topping D50S + THX AAA 789, TH-X00 w/ V-Moda Boompro; 7Hz Timeless
Power Supply Corsair HX1000i
Mouse Sharkoon Fireglider optical
Keyboard Corsair K95 RGB
AHH NECROMANCY! Lol.
@BYJA. Yeah, me too. Using MSI afterburner to set fan @ custom curve and card crashes. (Stock BIOS never sets fan higher than 76%. Card artifacts before fan goes higher).
Card will crash once it heats up enough for the fan to go to a higher value with the custom setting. Not always right away, but it always does. Tested setting fan @ 100% manually w/MSI AB, same result.
Also using F8 bios. Interesting to note, card ignores BIOS fan settings. Modified BIOS fan curve w/RBE and card acts as if stock. (76% fan MAX)
Perhaps Gigabyte knows the card cannot run the fan any higher, and so disabled bios fan control. My CCC couldn't set it either. MSI Afterburner is the only prog i've tried that can set the fan.
35 (0.01/day)
Hi guys is anyone getting a higher voltage setting with flashing a different bios? If i flashed the msi or sapphire ones would the voltage change or stay the same (1.088 i think)? I want to push it a bit more on air.
29 (0.01/day)
System Name Whatever 2
Processor Intel i5 2500k @ 4.5ghz
Motherboard P8P67 (non-pro)
Cooling ThermalRight 120 extreme
Memory 16gb GSkill DDR3 1600mhz
Video Card(s) Gigabyte 6950> 6970 (shader unlocked)
Storage OCZ Vertex2, WD RE4 500gb
Display(s) Dell 24" LCD
Case Antec 900
Audio Device(s) Creative X-FI
Power Supply Seasonic 700W
Software Windows 7 PRO 64bit
I flashed mine with the gigabyte 5870 ultra durable bios and the card is stable to 975/1125, sold the card to a friend but its been running like that for about 1yr no problems. And yes it does up the voltage to the GPU. The voltages in RBE are 1.15 and 1.063 with the 5870 bios. the voltages are 1.088 with the f5 bios for R585OC.
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Don't bother flashing your card to get higher voltage. Use MSI Afterburner.
29 (0.01/day)
Case Antec 900
the 5850OC is NOT a reference design card so MSI AfterBurner will not work. The only way to get higher voltages is to flash the card, the gigabyte 5850 and 5870 UD cards are identical and flashing the 5850 with the 5870 will work the best IMHO.
43,587 (6.71/day)
Storage WD m.2
Keyboard Tester84
Afterburner works with some non-reference designs. Have you tried to see if it works?
29 (0.01/day)
Case Antec 900
I did and it won't with this particular card, I have since moved to a gigabyte 6950 its reference and does work with MSI AfterBurner although due to a recent punkbuster update i can't run AB with BFBC2 or I get a hard lock. But the 5850OC cannot be voltage controlled by AB because of it's non-refence design. The GB 5850 and 5870 UD are identical cards and the extra voltage from the 5870 Bios definitely helped my 5850 Overclock a bit more.
43,587 (6.71/day)
Storage WD m.2
Keyboard Tester84
The design itself doesn't matter. What matter is what voltage controller it is using. Afterburner gets updated to use different voltage controllers, therefore it's worth a try using the latest version. If not, use Radeon Bios Editor and change the load voltage values to whatever.
29 (0.01/day)
Case Antec 900
Exactly and this ref-design doesn't use adjustable controllers. Why not read this thread from the beginning like I did and you'll understand this particular card better. this review http://www.bjorn3d.com/read.php?cID=1811&pageID=8621 is for the 5870 card which is identical to the 5850oc, states my points.
43,587 (6.71/day)
Storage WD m.2
Keyboard Tester84
Thanks for reading the entire thread so I don't have to. You saved me a lot of time.
35 (0.01/day)
Hey guys i found a review in polish that said they could adjust the voltage of the non-reference 5850 with OC guru version 1.0 (Not the latest one). I have tried it and theres an option to increase the voltage but i dont think its kicking in. Heres the review if anyone is interested in reading it.
Click Here
