my i7 4790k haswell is burning while working
Foredance
5 (0.00/day)
First of all i have learn a lot of stuffs here, and this is my first post, my english is not the best but i hope you all understand
so, i have a problem here, i bought a 4790k haswell a few weeks ago, and i built my new pc
the problem is that while my cpu do something it just gets on fire hitting 100º while running prime95, also, let me tell you that while my cpu is iddle everything is fine i guess, since the temp stands on 30 40 while idle.
theres an example:
http://imgur.com/YMPnG4z
my others pc stuffs
Gigabyte z97x gaming 5
Corsair rm820
xfx 280x 3gb ddr5
2x8gb gskill 2400
Western Digital black edition 1tb
Nzxt Phantom 410
i just changed the thermal paste and it did not change anything at all
i have no idea, theres no overclock at all
thanks!
Solaris17
Super Dainty Moderator
27,610 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
It could be a bad thermal sensor.
It could be the cooler is on too tight.
It could be cooler is not on tight enough (take it off is it spread well?)
paste is not good between heat spreader and core. (RMA time)
  • Like
Reactions: XSI
Foredance
5 (0.00/day)
ill try to tight it up tomorrow and ill comeback with the results
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
test it by touching the heatsink, is the heat normal?
whats your heatsink?
what about your airflow?
259 (0.06/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
What cooler are you using?
Post the CPU voltage you get under load.
Also post frequency under load, some motherboards like to overclock a bit by themselves.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
If you are on the stock cooler I would expect you to see temps like that from a stress test. My 4770k was the same on a stock cooler at stock speeds. Running prime on a stock cooler with these chips is a waste. They will get HOT. They can get to those levels and throttle though, I haven't seen one fail because of those temps and stock speeds...and if it does within the 3 years..you'll get it replaced via Intel RMA.
Get at least a CM 212EVO and you'll be fine at stock speeds. Honestly they should shave the costs of the stock cooler and give a voucher for the damn 212EVO imho.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Foredance
5 (0.00/day)
i got 100º playing games too
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
Well if the cooling can't keep up, it needs upgraded, simple as that. If that answer doesn't work for you, then you need to contact Intel Support and request an RMA replacement if you feel you have a faulty chip or faulty CPU sensors.
MAKE SURE you have the most recent BIOS update for your mainboard to ensure that there is no discrepancy. Download the Intel XTU and that will assist you in dealing with Intel RMA if you decide to go that route.
Honestly if you're not failing tests, but it's running hot, I'd say the CPU just needs better cooling. It's an Intel quad core running at 4-4.4GHz...mine at 3.5-3.9GHz was doing the same thing on stock cooling just FYI.
259 (0.06/day)
System Name maipc
this is my cpuz under 100% load
http://imgur.com/9aMlSAg
That voltage is way too high.
proper stock voltage for 4790K should be at about:
1.00-1.10V at 4GHz
1.10-1.15V at 4.2GHz
1.20V at 4.4GHz
If your haswell is at 1.28V and you have stock cooler, its gonna overheat for sure.
Make sure your motherboard bios is up to date.
If that don't fix it, your motherboard or CPU is faulty, motherboard more likely.
As a last ditch effort, you can try going into the BIOS and making sure all the voltage settings are correct.
2,695 (0.41/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
1.00-1.10V at 4GHz
1.20V at 4.4GHz
what a load of crap.
good chips can do those kind of speeds on those voltages but not all chips are good.
not that i am saying this aint a good chip either, as my money is on an auto oc overvolting.
temps are about right imo for those volts under a stock cooler.
if you want lower temps reduce the voltage or improve the cooling.
259 (0.06/day)
System Name maipc
thanks for correcting me!
please tell me what the real 4790k stock voltages are.
954 (0.22/day)
Cumberland Plateau
System Name EVGA-FX | Lenny (Lenovo Y480)
Processor AMD FX-8320 @ 4.5GHz 1.416v | i7 3610qm
Motherboard Asus M5A99FX Pro R2.0
Cooling Phanteks PH-TC14PE
Memory 2x4GB Corsair Vengeance @ 1600 | 8gb DDR3 @ 1600
Video Card(s) EVGA GTX780 Classified @ 1228MHz 1.615v | GT640m LE
Storage Crucial M500 480GB, WD Caviar Blue 500GB, WD Scorpio Blue 750GB | Samsung 250GB 840
Display(s) Qnix QX2710 1440p | 42" Vizio 3D LCD TV 1080p
Case CoolerMaster HAF XB Evo
Power Supply Seasonic G-650
Software Windows 6.3.9600
1.00-1.10V at 4GHz
1.20V at 4.4GHz
Idk it it is different for intel but CPU-Z never gives me the exact voltage. I use HWMonitor or AIDA64 when i want to see the true vcore.
7 (0.00/day)
System Name theslowcow
Processor Amd Ryzen 2600@ 4.0 vcore 1.1875
Motherboard Asus x470 gaming f
Cooling plain water and X-500 chiller
Memory G.SKILL Flare X Series 16GB 3200 14-14-14-34
Video Card(s) Gigabyte AORUS GeForce GTX 1080 Ti
Storage 248 gb ssd's
Case none
Power Supply Capstone 1000M
Foredance try 1.160 vcore for the 4790k all the others auto
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
No, he's right. My 4790K basically follows those voltages he said when I leave it at stock(slightly lower actually).
3,014 (0.62/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
My 4790K basically follows those voltages he said when I leave it at stock.
Rather, the defaults in your BIOS are making your 4790K follow those voltages ... many motherboards are overvolting by default, I guess to account for a worst possible chip out there.
OneMoar
There is Always Moar
8,837 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
to much voltage check the bios settings
reduce the voltage to about 1.1 to 1.150
1,683 (0.32/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
I'm highly doubtful the high voltage is the OP's fault; it just seems that everyone's unaware of the default behavior of Haswell processors.
If you have a Haswell processesor and enable adaptive voltage in the BIOS, many BIOSes will automatically add 0.1V on top of your maximum core voltage when running AVX loads. This occurs even when you are running stock clock speeds. As soon as you run something with AVX like prime95, the voltage and heat generated go off the charts due to that automatic 0.1V increase.
The stock heatsink is not designed to handle a prolonged 100% AVX load without causing throttling, even at stock clock speeds, so I'm not surprised at the results.
OneMoar
8,837 (1.61/day)
Rochester area
its 0.01 not 0.1v
fullinfusion
Vanguard Beta Tester
9,909 (1.57/day)
Stocks voltage, let's see as I need to make a draft and past it in all these threads.
First off go clear the bios, next boot into the bios and select LOAD OPTIMIZED settings.. Then restart and go directly into the bios, noe go down to the CPU voltage, what's it show beside the auto setting?
That will tell you what the could needs for non turbo volts. If it says like 1.043 then manually set it to 1.100v and test it.
These boards overvolt the shit outa these Chios and also check for the newest boards bios update and flash it if needed.
2,695 (0.41/day)
System Name panda
Processor 6700k
Case 540 Air
Mouse g502
Software win 10
they would be correct for some, and not others. not all chips are the same across the board.
to think the ic lotto is any less with the 4790k than all other chips is funny.
same as how some will do 5ghz on 1.25 and others need 1.45+ or will not even hit that speed stable at all.
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
1.00-1.10V at 4GHz
1.20V at 4.4GHz
Its a bad chip.
I had an Ivy i5 like this, but not quite as bad. The stock voltage was 1.25v. I only got it to around 4.3 ghz with any kind of stability and heat, at 4.4 it was in the 90s and 4.5 would only boot to validate, 4.5 was impossible to get stable on my H100i even with 1.4v+, which would just barely boot it. At stock, it worked fine though, it was an acceptable i5 in that it ran stock okay, it was just garbage overclocker and very high vid meant it ran hot all the time. Delid reduced temperatures by maybe 15*C but didn't fix the very high voltage and it was still just as unstable as before.
Same mobo plus a good chip and I can do 4.8 on air and its still "lidded".
1,683 (0.32/day)
VR HMD HP Reverb G2
its 0.01 not 0.1v
It is most definitely 0.1V, as I have experienced the exact same issue myself. Look at Haswell overclocking reviews if you would like additional sources.
