Need Help Purchasing A New Graphic Card + Power Supply
Kaiokhen
20 (0.00/day)
Seems like the 460 require 2 pins of connect.
Still undecided whether i should go for 5770 or 460 as for power and graphic performance. If the 460 has a slight better performance then i would prefer going 5770 as the cheap and valuable.
I am already settle with the power supply. Rosewill Green Series RG630-S12 630W Continuous @4... just incase i do future upgrades so i need a bit of more watts just in case.
So my 3 choices are either
GIGABYTE GV-R577SO-1GD Radeon HD 5770 1GB 128-bit ...
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR...
EVGA 768-P3-1360-TR GeForce GTX 460 (Fermi) 768MB ...
{JNT}Raptor
732 (0.11/day)
NY
System Name Ummmm...Mine
Processor I7 920 @ 4.2ghz @ 1.29v's load
Motherboard ASUS P6T Deluxe V2
Cooling Custom 1/2 inch H20
Memory 3x2gb Patriot Sector 7 @2008Mhz 27-9-11-9 1T
Video Card(s) EVGA GTX 580 SC 900/1800/1090
Storage 1-Mushkin 60gb SSD 1-500GB WD Black and 2-1TB 32mb WD Black
Display(s) 25 inch Hanns-G 2ms
Case Custom
Audio Device(s) Turtle Beach Catalina
Power Supply Corsair AX850 Pro Series-Modular
Software All Kinds...and then some.
Benchmark Scores 3dMark 11 P7066 Compare Link- http://3dmark.com/3dm11/251153
GTX460 stomps on the 5770...no competition actually....dunno why peeps would recommend that card still....it may use less power....but that's because it doesn't give you the performance that the GTX 460 can.
Heres a look at them head to head at Toms
No comparison. :toast:
6,207 (1.12/day)
Midlands,UK
System Name Ultraman
Case Alienware X16
Kaiokhen
20 (0.00/day)
As far as i read the previous link about GTX460. I am going to stay with 460.
But i am now still needing a power supply that provides whats needed and for a future proof just incase a slight upgrade and with a good price on total with graphic card and psu.
849 (0.16/day)
Argentina (South America)
System Name Classy Gal
Processor i7 2600K
Motherboard Gigabyte GA-Z68X-UD3-B3
Cooling CM Hyper 212 plus
Memory 16GB Kingston Hyper X
Video Card(s) EVGA GTX1070 FE
Storage 2x120GB Vertex 3 - 1x1TB WD
Display(s) LG 23" 1920x1080
Case Coolermaster Cosmos S
Audio Device(s) Creative SB Titanium HD
Power Supply Seasonic M12II 750W
Software Win10 / Linux Mint
If you are only going to play MW2 stay with the 5770, it can max out that game easily, both cards will be bottlenecked by your CPU. Unless you are planing to upgrade your CPU go for the 5770 (less heat, less power needed).
My father's PC used a similar CPU with a 4870 (similar to a 5770) and the card performed poorly until he upgraded to a Phenom 2 X4 955
No CPU upgrade:( go for the 5770
CPU upgrade some time in the near future:D, go for the GTX460
Kaiokhen
20 (0.00/day)
I am planning to do a future upgrade but not anytime soon probably later in a year or so, i am trying to built up slowly and be a future proof slowly but not insanely playing games like crysis nor any in particular.
6,207 (1.12/day)
Midlands,UK
Case Alienware X16
If you seen the OCZ PSU list i linked it has a 700w psu available aswell like these 2:
If your not really going do any extreme overclocking or tri-sli or whatever you should be perfectly fine with these 700w
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / E...
OCZ StealthXstream II OCZ700SXS2 700W ATX12V v2.2/...
I would still get a corsair psu though just for fact i have great experience with my one.
I would still go for the GTX460 due for fact its more powerfuler than 5770 by a lot and it cost the same as the gigabyte you linked.
Kaiokhen
20 (0.00/day)
I am not planning to do any sli nor anything in particular, just want a psu that is somewhat future proof for upgrades like cpu upgrade and motherboard. Not doing sli nor anything like that.
GTx 460 + the OCZ 700W = $265
Is there a cheaper psu that perform similar or better beside the rosewill that i am thinking in mind?
6,207 (1.12/day)
Midlands,UK
Case Alienware X16
Its actually $250 exactly if you do the after rebate and if you want even cheaper there is this Antec Earthwatt 500w which is $50 after rebate:
Antec EarthWatts EA-500D Green 500W ATX12V v2.3 / ...
OR if you want really good quality get this seasonic and seasonic manufactures Corsair psu i believe so you can bet this PSU is really reliable:
SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 1...
Kaiokhen
20 (0.00/day)
OH that antec looks old and i prefer the new psu where there is a big fan on top. Do u have one in mind thats around $60-$70?
6,207 (1.12/day)
Midlands,UK
Case Alienware X16
Don't think there is anymore cheaper Antec psu,i would go for the seasonic 520w psu as it will be all you need if you use only single gpu,HDD use nothing and upgrading to future CPU be fine as long as its nothing really intense like some i7 extreme or something with crazy overclock.
The seasonic be enough for any single GPU and any CPU.
Kaiokhen
20 (0.00/day)
I have probably finalized which to buy.
GTX 460 and the Seasonic PSU.
Thanks a lot guys i really appreciate the fast help and the detailed in depth help of each product.
