Problem Cannot Upload(deadline is 1 aug help very quick)
1,027 (0.24/day)
Patna, Bihar, India, Asia, Earth, Terron System, M
System Name Oldtimer(Always Crunching)
Processor Intel P4 631 @ 3.2 GHz [Stock 3.0 GHz]
Motherboard Intel D945GCPE
Memory 512 MB x2 DDR2 (533MHZ and 366 MHZ)
Storage 160GB Sata1 7200rpm
Display(s) ViewSonic VA703m
Power Supply Normal 450W PSU
Software Windows 7 Ultimate 32bit
You'll have to log back in using your WCG credentials.
This is what i get after reinstalling the bonic
It remains same even if i click on Update button and right now i do not have any task to compute or upload so this is needed to get new tasks
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
The behavior it is exhibitting is consistent with the "<exclusive_app>Action.exe</exclusive_app>" option in cc_config.xml:
http://boinc.berkeley.edu/wiki/Client_configuration
BOINC will suspend computing whenever the executable is running (e.g., a game). Case is ignored in filenames. Multiple applications can be specified.
Deleting ProgramData\BOINC should have eliminated that problem. It could be downloading it from the web or from a cc_config.xml in a different BOINC directory.
1,027 (0.24/day)
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
It's gotta be somewhere (and maybe in many places):
C:\ProgramData\BOINC
C:\Users\NAME\AppData\Local\BOINC
C:\Users\NAME\AppData\Roaming\BOINC
C:\Program Files\BOINC
C:\Program Files (x86)\BOINC
2,406 (0.46/day)
London, UK
System Name Slick
Processor Intel i5 2467M
Motherboard Samsung Series 5 Ultrabook
Memory 8GB Corsair Value
Storage Crucial M4 7mm 256GB
Display(s) 13"
Software Windows 8 Pro x64
1,027 (0.24/day)
Found it, Now what should i do with it?
it was in the C:\ProgramData\BOINC
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
You can post the contents here or, if you see "exclusive_app" in there, remove the tags and everything between them.
1,027 (0.24/day)
Here the whole content of the file!
<?xml version="1.0"?>
-<cc_config> -<log_flags> <file_xfer>1</file_xfer> <sched_ops>1</sched_ops> <task>1</task> <app_msg_receive>0</app_msg_receive> <app_msg_send>0</app_msg_send> <async_file_debug>0</async_file_debug> <benchmark_debug>0</benchmark_debug> <checkpoint_debug>0</checkpoint_debug> <coproc_debug>0</coproc_debug> <cpu_sched>0</cpu_sched> <cpu_sched_debug>0</cpu_sched_debug> <cpu_sched_status>0</cpu_sched_status> <dcf_debug>0</dcf_debug> <disk_usage_debug>0</disk_usage_debug> <priority_debug>0</priority_debug> <file_xfer_debug>0</file_xfer_debug> <gui_rpc_debug>0</gui_rpc_debug> <heartbeat_debug>0</heartbeat_debug> <http_debug>0</http_debug> <http_xfer_debug>0</http_xfer_debug> <mem_usage_debug>0</mem_usage_debug> <network_status_debug>0</network_status_debug> <poll_debug>0</poll_debug> <proxy_debug>0</proxy_debug> <rr_simulation>0</rr_simulation> <rrsim_detail>0</rrsim_detail> <sched_op_debug>0</sched_op_debug> <scrsave_debug>0</scrsave_debug> <slot_debug>0</slot_debug> <state_debug>0</state_debug> <statefile_debug>0</statefile_debug> <suspend_debug>0</suspend_debug> <task_debug>0</task_debug> <time_debug>0</time_debug> <trickle_debug>0</trickle_debug> <unparsed_xml>0</unparsed_xml> <work_fetch_debug>0</work_fetch_debug> <notice_debug>0</notice_debug> </log_flags> -<options> <abort_jobs_on_exit>0</abort_jobs_on_exit> <allow_multiple_clients>0</allow_multiple_clients> <allow_remote_gui_rpc>0</allow_remote_gui_rpc> <client_version_check_url>http://www.worldcommunitygrid.org/download.php?xml=1</client_version_check_url> <client_download_url>http://www.worldcommunitygrid.org/download.php</client_download_url> <disallow_attach>0</disallow_attach> <dont_check_file_sizes>0</dont_check_file_sizes> <dont_contact_ref_site>0</dont_contact_ref_site> <exclusive_app>Action.exe</exclusive_app> <exit_after_finish>0</exit_after_finish> <exit_before_start>0</exit_before_start> <exit_when_idle>0</exit_when_idle> <fetch_minimal_work>0</fetch_minimal_work> <force_auth>default</force_auth> <http_1_0>0</http_1_0> <http_transfer_timeout>300</http_transfer_timeout> <http_transfer_timeout_bps>10</http_transfer_timeout_bps> <max_file_xfers>8</max_file_xfers> <max_file_xfers_per_project>2</max_file_xfers_per_project> <max_stderr_file_size>0</max_stderr_file_size> <max_stdout_file_size>0</max_stdout_file_size> <max_tasks_reported>0</max_tasks_reported> <ncpus>-1</ncpus> <network_test_url>http://www.ibm.com/</network_test_url> <no_alt_platform>0</no_alt_platform> <no_gpus>0</no_gpus> <no_info_fetch>0</no_info_fetch> <no_priority_change>0</no_priority_change> <os_random_only>0</os_random_only> -<proxy_info> <socks_server_name> </socks_server_name> <socks_server_port>80</socks_server_port> <http_server_name> </http_server_name> <http_server_port>80</http_server_port> <socks5_user_name> </socks5_user_name> <socks5_user_passwd> </socks5_user_passwd> <http_user_name> </http_user_name> <http_user_passwd> </http_user_passwd> <no_proxy> </no_proxy> </proxy_info> <rec_half_life_days>10.000000</rec_half_life_days> <report_results_immediately>1</report_results_immediately> <run_apps_manually>0</run_apps_manually> <save_stats_days>30</save_stats_days> <skip_cpu_benchmarks>0</skip_cpu_benchmarks> <simple_gui_only>0</simple_gui_only> <start_delay>0</start_delay> <stderr_head>0</stderr_head> <suppress_net_info>0</suppress_net_info> <unsigned_apps_ok>1</unsigned_apps_ok> <use_all_gpus>0</use_all_gpus> <use_certs>0</use_certs> <use_certs_only>0</use_certs_only> </options> </cc_config>
EDIT: Wait this is messy i have compressed that file into a zip file and attaching it so you can view it in ie
View attachment cc_config.zip
2,406 (0.46/day)
London, UK
System Name Slick
Display(s) 13"
My eyes!
All you need there is:
<cc_config>
<options>
</options>
</cc_config>
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
I bolded the problem.
Open it with NotePad, remove that line, save it. Open BOINC, and make it "Read config file" and the problem should be fixed.
1,027 (0.24/day)
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
I attached the file with it removed...
1,027 (0.24/day)
Same as before!!
AS you can see i have pressed the update button but it is not updating because i don't have any task so there is only way is that and it is no updating
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
Do you want BOINC to use GPUs?
1,027 (0.24/day)
1,027 (0.24/day)
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
Here's the cc_config I use. It's the same as what KieX said with the addition of no_gpu option set.
I really need to finish that cc_config editor.
  • cc_config.zip
1,027 (0.24/day)
LOL it is solved already!:laugh:
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
It won't report results immediately without it. It may also accept GPU-based projects could slow your computer to a crawl.
I started playing Dawn of War II and lost track of time. Pretty much was suggesting to do the same thing but I didn't want to give you mine unless you wanted the nogpu setting set.
1,027 (0.24/day)
Okay, Used your Config file.
5,975 (1.32/day)
Hi! I'm from the Internet
System Name Selene / Yoda
Processor Fx 8350 @ 4.4 / Phenom II x6 1090t @ 3.6
Motherboard Gigabyte 990FXA-UD3 r4.0 / Gigabyte 890XA-UD3
Cooling H100i / Xig Dark Knight
Memory 4x 8gb G.Skill Snipers / 4x 4gb G.Skill Ares
Video Card(s) Gigabyte R9 290x / XfX DD & VisionTek HD6850's C'fired
Storage 256gb ssd, 2x 2tb Wd Blacks & 1x 1tb Wd black / 1x 1tb
Display(s) Dell Ultra Sharp 2408 WFp / Hp w2207
Case Raidmax Vampire / Chieftec Alum. Dragon Blue
Audio Device(s) Onboard Hd Audio / Onboard Hd Audio
Power Supply Corsair TX 850 watt / Corsair TX 750 watt
Mouse Logitech G500s
Keyboard Corsair Strafe
Software Win 10 pro / Win Vista Home prem. 64 bit
Benchmark Scores What are benchmarks anyway?
Cool glad you got it worked out :toast:
1,027 (0.24/day)
@ThE_MaD_ShOt;Thanks
