Project WaterFall -- A water cooling project log by Phenom
manofthem
WCG-TPU Team All-Star!
10,960 (2.26/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Plus wih a thick rad you should be able to slow the fans down too, cutting down on noise. I have 3 GT14s (1450rpm) on my XTX360 (64mm thick), and it does pretty well. The other day I only had the fans on that rad going (had the 3 GT14s on my xspc ex360 off) while playing BF3. Both 7970s at 1050/1500 and my CPU @4.5, and the cards only hit 44/45*. I know the only rad may have helped a little but still, I think the thick rads work out nicely, given you have enough space ;)
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
Yeah, I probably won't have the top on my case when I get a thick rad, If I do I will cut out a big rectangle out of the mesh for the rad to stick out of.
4,113 (0.71/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
I have been looking at doing Paracord, and I have been reading about FTW PC I hear is very slow now and may be stopping bossiness I may buy from this top site, they maybe the supplier to FTW PC and its cheaper.
http://www.supplycaptain.com/index.cfm?fuseaction=product.display&product_ID=753&ParentCat=19
http://www.supplycaptain.com/index.cfm?fuseaction=product.display&product_ID=754&ParentCat=19
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
thanks, for that information. yeah paracord is fricking sweet! Ill probably wait till i get a platnium all modular PSU. Which will be next year I think.
Black and Royal blue would be sweet!
4,113 (0.71/day)
Iowa, USA
Mouse Logitech G700
I just realized I'm not for sure if that paracord is the right thickness or not...
6,688 (1.43/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
I'm sure that will make James888 all creamy.
Make it on 80mm thick monsta and I just might... I am pretty set on the 120x80mm for the bottom front though. 80mm thick is just... YES! I am open to suggestions. If I could find a denser rad that isn't as thick I would definitely look into it. I am still slowing planning and browsing rads. I am currently looking at the ek rads. They are thick and have 11fpi compared to 9.6 in the alphacools. The price is so much more than the alphacools though.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
EK rads are trash! Pretty restrictive from what ive been reading. I dont care how well the 80mm monsta rad cools, its just too big.
6,688 (1.43/day)
Processor 7800x3d
Case ThermalTake P3
So many jokes could be made off that... but... I can fit the 120mm so I will. I can't fit a 240 there without taking out my bottom 5.25 bay so... 80mm monsta it is. Combined with 2 38mm panaflo fans.
Thanks for the info on EK rads. Removing them from my thoughts as an option... now.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
For the Monsta you dont need huge loud fans like that. the Fins are spread out you only need fans that do 1400rpm or lower.
6,688 (1.43/day)
Processor 7800x3d
Case ThermalTake P3
I don't want thread jack this towards me here but. I got the 38mm fans for cheap and why not use them on the monsta? The monsta does have a lower fin count but does much much better with higher rpm just because it is so thick. I have literally spent a few hours of my life reading anything the internet has to say about this 80mm rad alone, not to mention other stuff. It peforms much better at 1800rpm than 1400rpm. It is just sooo thick it needs that extra oomph to make it through the rad. If you have enough fans for the monsta, it really shines or so I have read.
HammerON
The Watchful Moderator
8,397 (1.52/day)
Up North
System Name Threadripper
Processor 3960X
Motherboard ASUS ROG Strix TRX40-XE
Cooling XSPC Raystorm Neo (sTR4) Water Block
Memory G. Skill Trident Z Neo 64 GB 3600
Video Card(s) PNY RTX 4090
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard Corsair K70
Good review here:
http://www.hardwarecanucks.com/foru...view-triple-radiator-360-roundup-16-rads.html
I actually have a couple Swiftech rads (2x120 and a 3x120), Feser Monsta Lite 3x140 and a Koolance 4x120 that I have used in different rigs over the years. I recently purchased the EK XTX 360 just to try something else based on this review. Will be working on the build hopefully next week. Was going to use the Monsta rad, however it wouldn't fit in the 800D (great rad though).
Still have all of the other rads for backup...
manofthem
10,960 (2.26/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Good review here:
I actually have a couple Swiftech rads (2x120 and a 3x129), Fezer Monsta 3x140 and a Koolance 4x120 that I have used in different rigs over the years. I recently purchased the EK XTX 360 just to try something else based on this review. Will be working on the build hopefully next week. Was going to use the Monsta rad, however it wouldn't fit in the 800D.
I'm running an EK XTX 360 right now, and I have no complaints at all with it. It does a nice job cooling. :toast:
cdawall
where the hell are my stars
27,680 (4.27/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Get a black ice gt stealth 30FPI great performance with high static pressure fans.
Very very thin rads and perform very very well with high static pressure fans.
6,688 (1.43/day)
Processor 7800x3d
Case ThermalTake P3
http://img.techpowerup.org/121026/20121026_113739.jpg
http://img.techpowerup.org/121026/20121026_153616.jpg
Thank you. Was already looking as some and was about to make a post about them in my thread. Any further discussion involving my future loop or rad suggestions for me I would like to direct to my thread here.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
For the record I am very impressed with my thin Alphacool single 120mm ST30 seeing as how it's, well, thin and a single 120mm. :p
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
New list of parts coming later this month.
AlphaCool NexXxos UT60 240mm rad (This blackice rad sucks. I dont want to run 2500rpm fans that sound like a jet engine to get good temps. This UT60 will be much better as its a lot thicker and its double pass)
another Bitspower 90 degree fitting
5 more feet of tubing :)
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
I think I have chosen on Full tower case to get when I want to add the CPU to the loop, and then have an internally mounted 360 rad.
NZXT Phantom 820 is what I have chosen I think. I love the way it looks. Its simple look, but not as boring looking as the Corsair 700/800D, and some good features, and awesome water cooling capability. Ill stick a Alphacool UT60 360 rad at the top :)
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
Sounds like a plan.
1,770 (0.38/day)
Cussing desert
System Name Torquey Vulture
Processor Ryzen 5 2600
Motherboard Gigabyte B450 MiniITX
Cooling DDC water loop, EK block
Memory 16GB Patriot Viper RGB
Video Card(s) EVGA 1070
Storage 500gb NVME; some Phat HDDs
Display(s) Achieva Shimian 27" 2560x1440
Case Thermaltake V1 MiniITX
Power Supply EVGA supernova 850 G2
Mouse Corsair Harpoon
Keyboard Possibly the cheapest you can buy. Shift key broke recently. Space sounds like I'm kicking a ham
Awesome, cant wait. I was just looking at that rad, was gonna suggest it since you were considering a bigger case
