Project WaterFall -- A water cooling project log by Phenom
cdawall
where the hell are my stars
27,680 (4.27/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Usually it's less modding and less hassle with a full tower. your ITX build really is amazing though, impressive. :toast:
Even with my Haf 932, I had to do slight modding to get my rad on the back on my case. It was too tough to try and squeeze them both inside.
Oh no doubt it is easier that is why my full tower has an MCR420, 320 and 220 in it. :laugh: I can't be the norm.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
I think it has to do with the fact theres way more space to work in when it comes to full towers. And to be able to stick a single triple rad inside it!
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
yeah at 1280mhz. Before on air it was up around 68-69c at same clocks, and it was a little unstable because I think VRMs and memory got way to hot on air because the cooler had no contact points for them. Only the GPU.
Theres a ton of minature bubbles in the reservior! haha
Is your pump turned all the way up? I'm pretty sure the radiator you chose is going to struggle a little bit with keeping your temps below 45c.
You can use HWiNFO64 to monitor your VRM temps.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Yeah, and yeah probably. I dont have the fans at full tilt either soo.
Regardless, temps are still WAY better! And it climbs in temperatures so much slower.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
Yep and makes sense as water can remove the heat from the CPU so much more efficiently and effectively.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
yeah its pretty sweet. It got up to 52c in Crysis 3 Alpha.
1,770 (0.38/day)
Cussing desert
System Name Torquey Vulture
Processor Ryzen 5 2600
Motherboard Gigabyte B450 MiniITX
Cooling DDC water loop, EK block
Memory 16GB Patriot Viper RGB
Video Card(s) EVGA 1070
Storage 500gb NVME; some Phat HDDs
Display(s) Achieva Shimian 27" 2560x1440
Case Thermaltake V1 MiniITX
Power Supply EVGA supernova 850 G2
Mouse Corsair Harpoon
Keyboard Possibly the cheapest you can buy. Shift key broke recently. Space sounds like I'm kicking a ham
Sounding awesome. Grr, you making me want water!
6,689 (1.43/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Got some cheap stuff from danger den, plus this thread, is getting me to go to water. Thanks mxphenom, thanks a lot.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Pushing the fans to 100% dropped the load temps to 45/46c haha!
Rad is probably getting saturated haha
manofthem
WCG-TPU Team All-Star!
10,960 (2.26/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Those fans really work well to be honest. I had 3 on my 360 rad, and they worked extremely well, beat out 6 med. yate loons in push/pull. Not only did they work well, but they were very well built with nice black cabling :D
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Yeah, the corsair fans are the only fans I buy. regardless of situation :) Innovative too, I like the colored rings.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
Yeah even with this little single 120mm rad I got for my Prodigy (a really good all-copper AlphaCool Nexxos ST30 but still) the 3570K doesn't get above 57C Prime 95 at 4.4Ghz (only 1.18v though but still as good if not better than my old MCR-220). Heh, actually it passes Prime at that voltage but BF3 "stopped working" so I dropped to 4.2 for now.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
4,013 (0.75/day)
Glad things worked out. I like the color of the tubing, it's a slightly different opacity and color than the standard blue.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Yeah its fricken sweet. Thanks for your help during the process.
1,770 (0.38/day)
Cussing desert
Yeah, it looks awesome.
What color sleeving are you gonna go with?
Edit: Im dumb, you linked to black. Blue could be cool
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Probably black and blue. Alternate
4,013 (0.75/day)
I'd rather spend a full day hitting my genitals with a hammer than do that much sleeving. Talk about boring tortuous monotony. Besides that, it would take you a year. Buy some extensions and be done with it, or ditch that PSU and get a full modular and have someone make a new set so you aren't voiding your warranty.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
I like sleeving haha! I do want to get a fully modular Platinum PSU. Like the Seasonic platinums.
SeaSonic Platinum Platinum-860 860W ATX12V / EPS12...
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
I'm sure that will make James888 all creamy.
oh god Alex your sick.
Hey Alex didn't you say you had to slow down the flow of your loop when you had a mid tower? Why was that? Because i have my pump on full tilt right now.
4,013 (0.75/day)
Not because of my tower size, it's because my pump has the power of 10,000 suns. I'd slow your pump until you like the sound of it, it shouldn't matter with such a small loop with little restriction.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Yeah my pump, sounds like my San Ace fans haha. I figured if you slow it down, itll slow the flow allowing the water to last in the rad longer. I really want a thick rad now though. This X-Flow rad gets saturated so fast.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
Agreed on the nice color of that XSPC tubing...noted.
