Water Cooling Project Log
Deleted member 24505
Thats a high ambiant.Mines usually no more than 20ish.
JrRacinFan
Served 5k and counting ...
20,073 (3.21/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
5,787 (1.00/day)
Switzerland, Heart of Europe
System Name Fractality 1.0
Processor Intel Core i7-860 @ 3.6GHz
Motherboard EVGA P55 SLI
Cooling Prolimatech Megahalems and four Fractal Design 120mm fans, sleeved
Memory 16GB Kingston Hyper RAM
Video Card(s) PNY GeForce 580 XLR8
Storage 64GB and 180GB SSDs / 1TB and 2TB HDDs
Display(s) 24" Acer V243W
Case Fractal Design Define R2, sleeved all I/O cables
Power Supply Corsair HX750W modular, sadly only stock sleeving
Software Win 7 64bit
47c, you live in the desert or what? :eek:
And overclocked chips need big heat transfer. I have a triple and a single rad, granted two cards than run hot also. It goes just as high as 65° above 1.45v, thats why a seperate loop is due soon.
A dual rad, especially as thin as yours can have a hard time dealing with those temps.
5,976 (1.08/day)
Cybertron aka Canada
Processor Intel Core i5-3570K
Motherboard Asus P8Z77-V Pro
Cooling Noctua NH-D14
Memory 8GB Mushkin Blackline DDR3-1600
Video Card(s) Gigabyte GTX 670
Storage Intel 520 60GB, Seagate Barracuda XT 2TB
Display(s) BenQ 24" XL2420T
Case Corsair 550D
Audio Device(s) Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X
Power Supply Corsair AX650
Mouse steelseries Sensei MLG edition
Keyboard Cooler Master QuickFire Pro
Software Windows 7 64-bit Home Premium
that reservoir is as big as your ambient temp. i'll be honest i'm not a fan of your case I really don't like Apevia cases. this will be a great learning experience your loop is much better than mine was I had a external fish tank pump, old grout bucket for a reservoir, modified auto radiator I got from a mcse class mate and some no name tubing from the local hardware store but this was when liquid cooling market was born. I have always setup my loops in Reservoir -> Pump -> CPU -> Radiator -> Reservoir. forget Push and Pull, Push and Pull favors High Speed Fans and since High Speed Fans favor Thick Radiators with large Fin Density stick with Low Speed Fans in Pull until you can purchase a new Radiator. lol at smoke break when you have a smoke make sure you play some punch-out.
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
I just checked my temps and they suck!!
E8600 @ 4.25 1.4 volts idle @ 48c and 65c @ load!!
Hell thats no better than my air cooler!!
Dont see any air in the lines and ive leaned it side ways to see if it had any in the block or rad and shook it on the way back up and no air came out!!
Then took the block off and checked the seal to the CPU and the paste was even on both sides!!
Reapplied new paste and remounted block and still have same temps!!
What could be wrong?
The water is flowing very well...I can see it in the res shooting up!!
Any ideas?
Whats your ambient temp Asylum?
Oh also...
I'm working on a watercooling loop myself. :)
Asylum - ambient means the air temp in the room. 47c is about 117f! And that's one HELL of an overclock!!!
I have a triple rad and see idle temps around 38c and load temps up to 52c with my E6600 CPU only at 3.2 right now (still messing with dividers and shit). Air temp is about 24c (75f).
What are you using for temp monitor?
Bumblebee has good points, good airflow through the rad is as important as it is with an air cooler.
2,894 (0.50/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
Sorry guys thought he meant idle temps!!
The temps in my house stay around 70f
2,863 (0.49/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
Dude put the rad inside more awesome/ better
2,894 (0.50/day)
South Carolina
System Name KILLER
Wont fit inside!!
Plus that would just make temps hotter!!
10,235 (1.70/day)
Austin Texas
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
3 suggestions -
try water wetter - it will drop temps by a bit - by reducing the surface tension of the water (i.e. making it absorb heat better)
Put your fans in pull mode, instead of push (mount the fans outside of the case to the rad.) Pull mode works better with <75CFM fans.
3 - check the mounting of the waterblock, and check the flatness of your chip. You may need to lap that sucker.
Last question - what are you using to load the chip?
2,894 (0.50/day)
South Carolina
System Name KILLER
10,235 (1.70/day)
Austin Texas
Case SLIGER S620
Audio Device(s) Yes
Mouse Xlite V2
Keyboard RoyalAxe
yeah your chip should be barely making it past 50C, at max.
Try to reverse the fans for a second so that they are blowing IN to the case through the rad.. If that makes a difference then you have an airflow problem, which is easy to fix.
I used to have those same exact components with the E8500 at 4.1Ghz 1.42V It should be performing alot better - we can fix it.
I'm using a 120.2 with my fans in pull mode,i have also put two fan frames twixt fan and radiator,seems to make a differance.
10,235 (1.70/day)
Austin Texas
Case SLIGER S620
Audio Device(s) Yes
Mouse Xlite V2
Keyboard RoyalAxe
yeah the shrouds make a big difference, always a good idea if you got the space.
You reckon it would make any differance if i put two more frames/fans on in push/pull mode?
2,894 (0.50/day)
South Carolina
System Name KILLER
Ill try that out and see what happens!!
10,235 (1.70/day)
Austin Texas
Case SLIGER S620
Audio Device(s) Yes
Mouse Xlite V2
Keyboard RoyalAxe
It would. Martin's Liquid lab shows just the one 25MM-30MM shroud can improve t-delta by 10-15% - I don't know how much a second shroud would improve it by - never tried it since it would make cleaning dust out of the rad a PITA.
It would make cleaning a pita,as it is now,i just take the side off and hoover the rad.Push pull is apparently better though,i might try it.
2,894 (0.50/day)
South Carolina
System Name KILLER
I tried the push pull method with 2 more fans on the outside and it only made 1c difference!!
Starting to think this rad or block is crap.
One or the other!!
Started out at 43c this morning when i first turned it on!!
Didnt take it long to go to 47c at idle!!
Ive checked the block 3 different times and the contact seems fine!!
Any ideas?
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Is this with your processor at stock?
2,894 (0.50/day)
South Carolina
System Name KILLER
No its overclocked...E8600 @ 4.25ghz 1.38 volts 47c @ idle and 65c @ load!!
I got that with my air cooler!!
10,235 (1.70/day)
Austin Texas
Case SLIGER S620
Audio Device(s) Yes
Mouse Xlite V2
Keyboard RoyalAxe
is the block flat?
3,459 (0.61/day)
Processor ???
Motherboard 760
Cooling HK
Memory 3x1gb
Video Card(s) 285 Classified / EVGA 480
Display(s) 22" Acer /42" Toshiba
Case Stacker
Power Supply Toughpower 1000w / Coolmaster 650w
Software All of them
i would go through the list
1 make sure its on securely
2 make sure its flat like phanbuey said you may need to lap it
Most intel ihs are not flat,you can either try lapping the cpu,or use the fat ring that came with the apogee gt to bow th block.I just lapped my E6750 as the base on the gt is pretty flat.
2,894 (0.50/day)
South Carolina
System Name KILLER
I changed flow direction and moved some fans around!!
Changed to pure water and got about 3c difference!!
The block looks to be flat but ill get a blade from work and check it and the CPU tomarrow!!
Looks like to me the rads not doing a good job!!
10,235 (1.70/day)
Austin Texas
Case SLIGER S620
Audio Device(s) Yes
Mouse Xlite V2
Keyboard RoyalAxe
You can tell if its the rad by touching the rad during load. Rads that are overloaded will be hot to the touch... that MCR 220 is one of the better rads around, and I almost guarantee that it is not the rad.
That same rad cooled my OC'd Q6600 at 1.52V to below 55C.
If you're BOOTING at 43C, then you have a contact issue. You should be booting at mid-20C.
Buy water wetter and add it to the loop. - it cools even better than pure water.
