Water cooling sprung a leak, need help!
12,062 (2.75/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Thanks and if I take it out for 1 minute the cmos will reset? im sorry if I sound stupid lol
Take it out, and then use a screwdriver to make a contact between the two pieces of metal the battery touches. You might have two jumpers to reset your CMOS, but that will be in your motherboard manual.
736 (0.18/day)
Kolkata, India
System Name barely hangin on...
Processor Intel I5 4670K @stock
Motherboard Asus H81m-cs (nothing else available now)
Cooling CM Hyper 212X (in push-pull)
Memory 16GB Corsair Vengeance Dual Channel 1866MHz
Video Card(s) Asus RX 580 4GB Dual
Storage WD Blue 1TB, WD Black 2TB, Samsung 850 Evo 250GB
Display(s) Acer KG241QP 144Hz
Case Cooler Master CM 690 III (Transparent side panel) - illuminated with NZXT HUE RGB
Audio Device(s) FiiO E10K>Boom 3D>ATH M50/Samson SR850/HD599SE
Power Supply Corsair RM 850
Mouse Redragon M901 PERDITION 16400 DPI Laser Gaming Mouse
Keyboard HyperX Alloy FPS Mechanical Gaming Keyboard (Cherry MX Brown)
Software 7-64bit MBR, 10-64bit UEFI (Not Multi-boot), VBox guests...
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
feser 1 black uv
Hmmm... supposedly non-conductive:
"Description Feser One - is the only coolant you will ever need! Proven as a safe way you cool your system. No other additives are needed as Feser One contains 4 anti corrosives! Corrosion protection For longer lifetime of your system ... The Priority for coolants is to improve the corrosion protection. To protect all kinds of metals Feser One has developed a cooling agent, which protects the metals COPPER, ALUMINIUM, BRASS and NICKEL. UV reactive And it glows ... With addition of UV active materials, so-called artificial tracers, the liquid begins to glow when ultraviolet light hits the material in the liquid. For theses effects you only need a CCFL / UV Cold Cathode light tube which is already on the market and available from different third party manufacturers (e.g. Sharkoon, Revoltec, etc.). Quality Control - Made in Germany Feser One is manufactured and supervised in Germany. All necessary components for the liquids are manufactured in Germany. In co-operation with specialists for corrosion protection at the professional school Südwestfalen / Germany, Feser One developed this coolant primarily for PC water cooling systems. The liquids are examined each month for its consistency and is submitted to different long term test in cooling systems. This always ensures a safe and optimal product. Features * 1000mL (33.8 ounces) * Non-Conductive * UV Reactive properties * Stable HDPE upright bottle * Conductivity < 10 µS/cm (20°C) * Dropper Cap - no funnel needed * Ready for use - no mixing needed * Corrosion protection for copper, brass,aluminum and nickel * Prevents algae growth within your water cooling system * Compatible with all available PC liquid-cooling systems * Unopened shelf life of 3 years maximum * MSDS File"
brandonwh64
19,542 (3.65/day)
Ok will do how do I reset the cmos? and what are front panel headers?
I am not trying to be rude but if you do not know what these or how to do these then custom water cooling is not something you need to be doing at this time.
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Chill... only one way to learn.
12,062 (2.75/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
brandonwh64
19,542 (3.65/day)
I said it in a nice way. It wasn't meant to be rude or belittling I just think he needs more experience with PC hardware before jumping directly to watercooling.
736 (0.18/day)
Kolkata, India
Folks are just kidding. But seriously, where'd ChizzY go anyway? I'm dying to know what happened. I hope he didn't pluck out the caps or anything - or get electrocuted!
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
He's doing shots of tequila, with Feser 1 chasers :p
ChizzY
15 (0.00/day)
Hey I took the battery out and put a screw driver over the metal bits and still nothing. And I built the pc from scratch on my own following instructions and it worked flawlessly until now
the54thvoid
Intoxicated Moderator
12,463 (2.37/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Dismantle it, remove all peripherals. Use paper towel and dab through all small apertures and slots, especially PCI. Leave all parts overnight at least, all separate. Put it back together as it was, make sure connections are secure. Try it again.
I had water on my gpu in the past but i dabbed the excess and it survived.
Dismantle, air dry and leave it. Only patience will help.
If it's not responsive after all that, something has been damaged.
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
I would be liberal with some distilled water and a towel, then put the oven on 150f, set the components in for a few hours. Bottom line, you're going to have to tear it apart, clean it and put it back together again.
I've told this story many times... splashed some Blue Koolance fluid in my case years ago. A few weeks later my system became totally unstable. After trying just about everything, I took the RAM out and noticed some dried blue crust on the contacts. Wiped with a cloth, put it back together and didn't have a single problem after that.
Durvelle27
6,707 (1.56/day)
Memphis, TN
System Name Black Prometheus
Processor |AMD Ryzen 7 1700X
Video Card(s) |AMD R9 290
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Hey this may be a silly question but can I use tap water?
Absoulty big fat NO. Tap water has a lot of harsh metals in it which would corrode blocks and it's also conductive. I only recommend using distilled water which can be had fairly cheap. I bought 3 jugs for $3 from Walgreens and Kmart.
3,842 (0.93/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
meh! ive ran plain tap water for a few weeks when i had my loop in ice. was too lazy/cheap to freeze distilled and keep flushing that! had no bad effects at all. just dont do it permanently.
also like everyone else said test it all separately.
ChizzY
15 (0.00/day)
So I can wash my motherboard with tap water then dry it then put it all back together?
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
After running in a loop for a while and picking up metal particulates any liquid will become conductive after a short time. It was most likely conductive at the time.
lyndonguitar
I play games
1,878 (0.37/day)
Philippines
System Name X6 | Lyndon-ROG
Processor Intel Core i7-8700k | Intel Core i7 6700HQ
Motherboard Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX
Cooling Deepcool Captain 240EX
Memory 16GB Corsair Vengeance LED | 8 GB
Video Card(s) NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB
Storage SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB
Display(s) Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p
Case Cougar Panzer Max
Audio Device(s) HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200
Power Supply EVGA 750GQ
Mouse Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5
Keyboard Corsair Vengeance K70 Cherry MX Red
Maybe he had someone else build the PC for him(i have friends who does this) and now this happened and he couldn't contact a "PC guy" so he goes here.
don't use tap water, like the guy above me said, use distilled. just make sure you dry it completely
43,587 (6.71/day)
Storage WD m.2
Keyboard Tester84
It's most likely better to use alcohol than water due to a higher evaporation rate which in turn causes lower permeability. It's never really a good idea to use water on electronics.
43,587 (6.71/day)
Storage WD m.2
Keyboard Tester84
You can get it from any drug store. 92% will work fine too.
7,126 (1.45/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Video Card(s) Sapphire Pulse RX 7900XTX + under waterblock.
Storage Optane 900P[W11] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO[FEDORA]
Case Lian Li O11 Dynamic EVO
Software FEDORA 39 / Windows 11 insider
Simply putting.... there are no ideal solutions. Just precautions as in a nuclear plant...
5,975 (1.32/day)
Hi! I'm from the Internet
System Name Selene / Yoda
Processor Fx 8350 @ 4.4 / Phenom II x6 1090t @ 3.6
Motherboard Gigabyte 990FXA-UD3 r4.0 / Gigabyte 890XA-UD3
Cooling H100i / Xig Dark Knight
Memory 4x 8gb G.Skill Snipers / 4x 4gb G.Skill Ares
Video Card(s) Gigabyte R9 290x / XfX DD & VisionTek HD6850's C'fired
Storage 256gb ssd, 2x 2tb Wd Blacks & 1x 1tb Wd black / 1x 1tb
Display(s) Dell Ultra Sharp 2408 WFp / Hp w2207
Case Raidmax Vampire / Chieftec Alum. Dragon Blue
Audio Device(s) Onboard Hd Audio / Onboard Hd Audio
Power Supply Corsair TX 850 watt / Corsair TX 750 watt
Mouse Logitech G500s
Keyboard Corsair Strafe
Software Win 10 pro / Win Vista Home prem. 64 bit
Benchmark Scores What are benchmarks anyway?
As Erocker said I would just go get a bottle or 2 of 92 to 99% alcohol and dismantle the complete rig. Clean everything like your life depended on it. Let sit for a day or 2 then reassemble and see what happens. Also as your reassembling start with the basics. Set motherboard on a table with a air hsf if you have one and test it with just one stick of mem and the gpu. If it works then start adding ram a stick at a time. If you add all ram and its good start adding other things like the hdd. If it doesn't boot with just the ram and gpu try another gpu. If that doesn't work try a different ram stick. if that doesn't work you have narrowed it down to either the mobo or cpu being bad.
