Will a Noctua NH-D15 fit in to my case?; Cooler Master elite 431 plus.
Dominates
11 (0.00/day)
Question in the title. I am going to build my rig soon and I was wondering if it would fit. The case is a mid tower case. And the motherboard will be a ASROCK Z97X Fatality Killer. Thanks for any input you give :)
[Ion]
WCG Team Assistant
13,391 (2.51/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
I would suspect that it would not. From the reviews I've seen, the CM Elite 431 Plus is already a relatively tight fit using a standard 120mm tower cooler. Certainly, a 120mm tower cooler fits fine, but without a lot of clearance. The Noctua NH-D15 is considerably bigger, so I imagine that the side panel would not go on completely. I don't see a maximum CPU cooler size listed on the CM website, but, from experience with lots of other mid-tower cases, I'm not convinced it would fit.
39 (0.01/day)
England
Processor Ryzen 3600
Motherboard MSI Mortar Max
Cooling Phantek PH-TC14PE
Memory 2x8GB Corsair 3200 C16
Video Card(s) Gigabyte 1080 G1
Storage Many SSDs
Display(s) iiyama 34" 3440x1440 144Hz
Case Fractal Define
Audio Device(s) Ath-m50x + Modmic + AV 5.1 Setup
Power Supply Corsair AX760i
Mouse Steelseries Rival 110
Keyboard Corsair K70
Software Win10
de.das.dude
Pro Indian Modder
8,785 (1.73/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
According to Cooler Master website:
CPU cooler height: 192mm / 7.6 inch
So a 165mm NH-D15 should fit fine. However I'm not convinced looking at photos of the case! 162mm cooler installed here:
http://aphnetworks.com/reviews/cooler_master_elite_431_plus/4
you need to take into account 20-25mm for motherboard thickness, socket thickness and chip thickness.
they just give a measure of the distance of base plate to the side panel.
just get a ruler and measure the distace from the top of your CPU to the side panel.
it should fit.
Dominates
11 (0.00/day)
Thanks everyone. I already have the case purchased and I will order the cooler soon. Its the best cooler I can get since I hate water cooling
259 (0.07/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
Coolermaster site says your cooler can be at most 163mm high. (not 192mm, that's the width of the entire case)
It probably won't fit.
