XFX HD 4830....Overclocking, Temps and 3DMark, etc
Discussion in 'AMD / ATI' started by TheScavenger, Jan 22, 2009.
  1. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    I use RivaTuner to overclock and adjust the fan settings. I haven't tried gaming at 800/1075. I have been running all my games at 750/1050.
  2. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.47/day)
    148
    The Netherlands
  3. r9
    r9
    Jul 28, 2008
    2,144 (0.78/day)
    284
    Great OC :toast:
    800CORE :eek:
  4. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    I broke 12k in 3DMark06!
  5. inf3rno
    inf3rno
    Nov 25, 2008
    415 (0.16/day)
    41
    Pakistan
    Congrats on breaking 12k barrier. at 750 or 802.
  6. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    802
    I must admit that I am a little proud of my cheapy setup :rockout:
  7. inf3rno
    inf3rno
    Nov 25, 2008
    415 (0.16/day)
    41
    Pakistan
    You should be feeling proud. If I am not wrong you are getting the performance nearly 4870....:toast:
  8. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    I am getting there...but if only I had that GDDR5 memory bandwidth :cry:
  9. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    To put things in perspective...
    My Q9450 @ 2.66GHz combined with a stock MSI 4830 @ 575/900 scored a 11,517 in 3DMark06. Passed that up with my AMD dual core!
  10. Flash
    Jan 27, 2009
    223 (0.09/day)
    11
    I can tell you what doesn't overclock well. My HIS 4870. Stock is 750/900 and I can't run Crysis at 800/1000. It will freeze in the first 5-10 minutes, in any point of intensive combat, and also give few micro shutters until then. It stays frozen for about 2-3 seconds then VPU kicks in, and the game either CTD or sometimes keeps going.
  11. 1Kurgan1
    1Kurgan1 The Knife in your Back
    Dec 8, 2008
    10,398 (3.97/day)
    2,410
    Duluth, Minnesota
    Nice to see some 4830 appriciations, truely an amazing card and it seems no one even puts it on the radar, such a good deal!
  12. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    I honestly think I am the first and only person to talk about it so far. If you google "XFX HD 4830" the first page of results contains 5 of the threads I have started at various message forums :laugh:
    WHY AREN'T PEOPLE SNATCHING THESE UP?
  13. nafets New Member
    Jul 26, 2008
    611 (0.22/day)
    133
    You can't compare it to the HD4870 in regards to overclocking because the core has two SIMDs disabled (160 shaders and 8 texture units less).
    I would expect the HD4830 to overclock quite well as it has lower heat output and power requirements...
  14. crtecha
    crtecha New Member
    Dec 8, 2008
    2,407 (0.92/day)
    207
    ipsay meechigan
    Im getting two for crossfire!!!!! :D
  15. r9
    r9
    Jul 28, 2008
    2,144 (0.78/day)
    284
    Why first of all people are more confident buying 4850 and second ATI let manufacturers build with own PCB design and all are building those shitty short versions that don`t overclock well.
    In my country I was looking for reference or close to reference 4830 and all I could find was those short versions and I ordered one and it died after 3 min of gaming. And I was tired of switching VGAs and went with ASUS 4850 it is not remarcable sample as yours but it does 750+ and 1075 mem witch is fine. Little dissapointed in mem OC but 1075 it is no to bad I guess.
  16. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    Theres one person :rockout:
    crtecha says thanks.
  17. crtecha
    crtecha New Member
    Dec 8, 2008
    2,407 (0.92/day)
    207
    ipsay meechigan
    Hey could you perfhaps post some furmark and maybe lightsmark scores?
  18. r9
    r9
    Jul 28, 2008
    2,144 (0.78/day)
    284
    I bet that 4830 at 750 would beat 4850 short PCB version bios locked 680MHz core. Those extra MHz on core are enough to compensate for less shaders. I`m talking about Sapphire versions and there are others that cant break 700 core both 4830 and 4850.
  19. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    I'll jump on it.
    I wanted to get some GPGPU going but for some reason Sandra SP1 isn't working with Windows 7.
  20. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    LightsMark-
    368.4 FPS @ 575/900
    432.4 FPS @ 802/1074
  21. crtecha
    crtecha New Member
    Dec 8, 2008
    2,407 (0.92/day)
    207
    ipsay meechigan
    Hey thanks!!
    I cant wait to get mine although I need to upgrade my cpu also.
  22. TheScavenger New Member
    Jul 29, 2008
    326 (0.12/day)
    37
    Kansas City, MO
    I can't wait to get my 940BE either!
  23. philbrown23
    philbrown23 New Member
    Dec 22, 2007
    1,231 (0.41/day)
    147
    vermont
    so these cards clock higher than the 4850's
  24. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
    Make that 2. ;)
  25. spearman914
    spearman914 New Member
    Apr 14, 2008
    3,339 (1.17/day)
    502
    Brooklyn, New York 11223
    The reason a 4830 clocks well is because AMD factory underclocks it from the 4850 speeds (but less shaders) . LOL, that's why u can easily achieve speeds like 800MHZ
