%0 GPU Usage and 1 FPS Spikes Only on PUBG
36 (0.02/day)
Istanbul
System Name I'ts Working!(for now)
Processor AMD Ryzen 5 3600X
Motherboard MSI B450 Tomahawk Max
Cooling Cooler Master Hyper HD 212 Blac/Stock Case Fans(I know)
Memory geiL EVO X II AMD Edition 16GB(2x8)
Video Card(s) ASUS TUF Gaming RTX3080 OC Edition
Storage Samsung 970 EVO 500 GB/Seagate Barracude 2TB(barely alive)
Display(s) ASUS PG279QE
Case Corsair 270R
Audio Device(s) ASUS Tuf Gaming H3
Power Supply Seasonic Focus Plus 750W 80+ Gold (Don't buy cheap bronze ones, specially Corsair!)
Mouse Razer Deathadder V2
Hey there,
So I've been having this problem for some time now, tried almost everything I could find people suggested about this game and performance issues, nothing worked so far. The problem is simply put, the GPU usage drops to 0% and I'm getting 1 FPS whenever I move my character. The game works fine when I stand still and look around with my mouse, but whenever I move, the game basically stops working. When character stops moving, game starts to work again.
My Specs: Ryzen 5 3600x, Asus TUF 3080 OC, 16 GB 3400 Mhz memory (2x8), Samsung EVO SSD, Seagate HDD.
I reinstalled the game multiple times, both on SSD and HDD.
Game used to work perfectly until couple of months ago. Back then I had RTX 2070s when the problem first started. When I changed to RTX3080 it still continues.
Anyone had similar issues or found a solution?
Toothless
Tech, Games, and TPU!
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Temperatures?
167 (0.10/day)
USA
Processor 5800x3D
Motherboard x570 Extreme 4
Cooling Deepcool AK620 Digital
Memory 2x16 Steel Viper 3600 Mhz
Video Card(s) 4070 SUPER FE
Storage 500 GB WD SN750 / 870 Evo 500 GB / Kingston 480 GB SSD
Display(s) Alienware 34 aw3418dw / ROG Swift pg27q
Case Corsair 3000D
Power Supply Seasonic V3 1000w
Mouse Model O
Keyboard GMMK Pro w/ SP Magic Girls
Software WIndows 10 Pro
Correct/updated drivers installed?
36 (0.02/day)
Istanbul
Case Corsair 270R
Temps are around 40c both CPU and GPU (normally, GPU gets around 60 while on full load).
All the latest drivers installed, I double checked again.
36 (0.02/day)
Istanbul
Case Corsair 270R
I captured a video with the problem in question, I believe I may have not do good jo with explaining, so here it is.
First of, please excuse the audio. It captured the TV.
As can be seen in the video, when I try to scroll trough the setting menu with the wheel, it stutters. But when I do it with clicking on the side bar, it doesn't. Does that even make sense?
It's pretty frustrating to be honest. I really don't care much about the game (aside from playing with a friend, who loves the game for some reason). But at this point it became kind of an obsession.
I would really appreciate if anyone can help me with this very strange issue.
3,983 (1.93/day)
Thessaloniki, Greece
System Name PC on since March 2025, upgraded from 5900X
Processor Ryzen 7 9700X (March 2025), 150W PPT limit, 85C temp limit, CO -25, +100MHz (up to 5.65GHz)
Motherboard Asrock X870E NOVA, BIOS v3.2, AGESA PI 1.2.0.3a Patch A
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryosheet
Memory 2x32GB G.Skill Trident Z5 RGB (March2025) 6200MT/s 1.42V CL30-36-36-36-28-64 1T, tRFC:500, Hynix A-D
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (370W current) PowerLimit, 1060mV, Adrenalin v25.3.1
Storage NVMe: 990Pro 2TB(OS 25), 980Pro 1TB(22), 970Pro 512(19) / S-III: 850Pro 1TB(15) 860Evo 1TB(20)
Case Thermaltake Core P8 TG Gaming Full Tower, Fans: 9x140mm + 3x120mm
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3775), Install March 2025
Is the game installed on the SSD NVMe or the HDD? Is this happening only with this game?
