- May 24, 2023
- 46 (0.07/day)
Processor | Intel i9-11900H |
Cooling | IETS GT500 |
Memory | 32GB DDR4 @ 3200MHz |
Video Card(s) | RTX-3060 6GB |
Storage | 512GB NVMe SSD |
Mouse | Razer Naga Trinity |
Keyboard | Razer Ornata V2 |
Oh wow, a desktop user!
Sorry, it's been a while.
My 14700K won't overclock. Now, I have a few theories. And yes I have the headroom, at least when using under 8 performance cores (I can run 5.6ghz indefinitely below 92c, am using mx-5 which is less than ideal, but my 420mm radiator works).
My motherboard DOES allow overclocking, it's the Aorus Elite AX Z790. I've also made sure I can overclock (I can do it through gigabyte control centre, but I don't want to use it because it'll force a single clockspeed across all cores rather than be dynamic).
Here's my setup for FIVR:
I know it's probably gonna crash on those higher clock speeds, but I can't exactly test it because my clocks won't go above an x55 multiplier on 6 of the p-cores, and won't go above x56 on the favoured p-cores (even if intel doesn't mention this, I only see 2 of the cores actually pushing the rated 5.6GHz).
My powerlimits are pumped to the max by default, and I'll fiddle with voltage when I actually start seeing the turbo multipliers go above 55-56.
Here is TPL; note, I don't get PL2 warnings or anything like that. I tested this using cinebench 2024 multi core load, I hit like 305w.
I've tried different settings on my uefi bios, like "unleash" and "instant 6ghz" but neither seemed to work, so I presume some software is locking me out?
The weird thing is, if I do this in Gigabyte control centre, it works. Which makes me think it's interfering.
Edit: I just rebooted my PC without GCC, and now the favoured cores are overclocking... but not the other 6 P-cores. I'm just incredibly confused about this. I know all the cores can be overclocked using GCC, I tested it before, but I'd rather use Throttlestop for this.
Also here's my main window:
