Deleted member 24505
is it ok to run 2 fans of the same type off 1 motherboard fan header?
System Name | Box of Distraction |
Processor | Ryzen 7 1800X |
Motherboard | Crosshair VI Hero |
Cooling | Custom watercooling |
Memory | G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T |
Video Card(s) | EVGA 1080Ti FE. WC'd & TDP limit increased to 360W. |
Storage | Samsung 960 Evo 500GB & WD Black 2TB storage drive. |
Display(s) | Asus ROG Swift PG278QR 27" 1440P 165hz Gsync |
Case | Phanteks Enthoo Pro M |
Audio Device(s) | Phillips Fidelio X2 headphones / basic Bose speakers |
Power Supply | EVGA Supernova 750W G3 |
Mouse | Logitech G602 |
Keyboard | Cherry MX Board 6.0 (mx red switches) |
Software | Win 10 & Linux Mint |
Benchmark Scores | https://hwbot.org/user/infrared |
Wow, I'm actually quite impressed it's managing that, goes to show i guess.Yes it is. I have 3 fans and 1 pump in 1 Motherboard 4 pin fan header.
Processor | Intel Core i5 4590 |
Motherboard | Gigabyte Z97x Gaming 3 |
Cooling | Intel Stock Cooler |
Memory | 8GiB(2x4GiB) DDR3-1600 [800MHz] |
Video Card(s) | XFX RX 560D 4GiB |
Storage | Transcend SSD370S 128GB; Toshiba DT01ACA100 1TB HDD |
Display(s) | Samsung S20D300 20" 768p TN |
Case | Cooler Master MasterBox E501L |
Audio Device(s) | Realtek ALC1150 |
Power Supply | Corsair VS450 |
Mouse | A4Tech N-70FX |
Software | Windows 10 Pro |
Benchmark Scores | BaseMark GPU : 250 Point in HD 4600 |
Yes, if combined power of two fans dont exceed 12W power.is it ok to run 2 fans of the same type off 1 motherboard fan header?
Yep, unless they're really high power server fans they should be fine, the mobo manual should mention somewhere what the max rating is, iirc it's usually about 1Amp per header which is quite a lot when it comes to fans. I bought the connectors and crimp up my own y leads, just missing off the RPM signal wire from one, so far I've never had any prob running 2x 120mm EK vardar or corsair ML fans off a single header.
System Name | Senile |
Processor | I7-4790K@4.8 GHz 24/7 |
Motherboard | MSI Z97-G45 Gaming |
Cooling | Be Quiet Pure Rock Air |
Memory | 16GB 4x4 G.Skill CAS9 2133 Sniper |
Video Card(s) | GIGABYTE Vega 64 |
Storage | Samsung EVO 500GB / 8 Different WDs / QNAP TS-253 8GB NAS with 2x10Tb WD Blue |
Display(s) | 34" LG 34CB88-P 21:9 Curved UltraWide QHD (3440*1440) *FREE_SYNC* |
Case | Rosewill |
Audio Device(s) | Onboard + HD HDMI |
Power Supply | Corsair HX750 |
Mouse | Logitech G5 |
Keyboard | Corsair Strafe RGB & G610 Orion Red |
Software | Win 10 |
Well most motherboards fan header support 1A. Though some board support more power as you mentioned.I recall one MB manual specifically stating the wattage limit on the fan headers, and that number rings a bell.
Edit, blast from 2011, someone saying an ASUS X58 board can put out 2A (24w): https://www.techpowerup.com/forums/threads/multiple-fans-on-same-header.145295/post-2277037
Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Cooling | D15 |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | Sammy 860, MX500, Sabrent Rocket 4 Sammy Evo 980 \ 1xSabrent Rocket 4+, Sammy 2x990 Pro |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | Fractal Design Pop Air 2x140mm fans from Torrent \ Fractal Design Torrent 2 SilverStone FHP141x2 |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 \Paradigm 7se MKII, Paradigm 5SE MK1 , Blue Yeti |
Power Supply | Seasonic Prime TX-750 \ Corsair RM1000X Shift |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ Wooting Two HE |
Benchmark Scores | Meh benchmarks. |
System Name | 4K-gaming / console |
Processor | 5800X @ PBO +200 / i5-8600K @ 4.6GHz |
Motherboard | ROG Crosshair VII Hero / ROG Strix Z370-F |
Cooling | Eisbaer 360 + EK Vector TUF + Acool ST30 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC |
Memory | 32GB DDR4-3466 / 16GB DDR4-3600 |
Video Card(s) | Asus RTX 3080 TUF / Powercolor RX 6700 XT |
Storage | 3TB of SSDs / several small SSDs |
Display(s) | 4K120 IPS + 4K60 IPS / 1080p projector @ 90" |
Case | Corsair 4000D AF White / DeepCool CC560 WH |
Audio Device(s) | Sony WH-CH720N / Hecate G1500 |
Power Supply | EVGA G2 750W / Seasonic FX-750 |
Mouse | Razer Basilisk / Ajazz i303 Pro |
Keyboard | Roccat Vulcan 121 AIMO / Obinslab Anne 2 Pro |
VR HMD | Oculus Rift CV1 |
Software | Windows 11 Pro / Windows 11 Pro |
Benchmark Scores | They run Crysis |
Yes.so I can wire the 2 x 4 pin Corsair AF 140 on one header with just one rpm wire connected?
Well there are a few versions ....
DCV Air Series™ AF140 Quiet Edition High Airflow 140mm Fan = 0.10amps
https://www.corsair.com/us/en/Categories/Products/Fans/Air-Series™-AF140-Quiet-Edition-High-Airflow-140mm-Fan/p/CO-9050009-WW#tab-tech-specs
DCV Air Series™ AF140 LED (2018) White 140mm Fan Single Pack = 0.30 amps
https://www.corsair.com/us/en/Categ...se-Cooling-Fan/p/CO-9050085-WW#tab-tech-specs
http://www.performance-pcs.com/modmytoys-3-pin-power-distribution-pcb-3-way-block.html
This PCB may requires you to manage the rpm thing for 2nd fan yaself ....
https://allpinouts.org/pinouts/connectors/motherboards/motherboard-cpu-3-pin-fan-connector/
With this one, it's all done for you inside the PCB
https://www.newegg.com/Product/Product.aspx?Item=9SIA4RE5032993
Yes. Fans don't draw a bunch of power and it is safe to run 3 or 4 from one header. However...is it ok to run 2 fans of the same type off 1 motherboard fan header?
...this is really pushing it. Pumps do need a lot of power. Such a power draw might cause issues long term.. Try not to do this. Give a pump it's own dedicated connector.and 1 pump in 1 Motherboard 4 pin fan header.
