24% of space is taken in an empty drive ?
911 (0.36/day)
Al Balqa', Jordan
Processor AMD Ryzen 5 2600, OC: 4.0 GHz @1.3 V
Motherboard ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta]
Cooling Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust)
Memory Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8)
Video Card(s) Palit GeForce GTX 1660 Ti Dual OC
Storage Kingston NV2 1 TB
Display(s) MSI PRO M251 (HDMI), Running @104 Hz
Case Cooler Master MasterBox MB520
Audio Device(s) HP H360G USB
Power Supply Cooler Master MWE 550 80+ White
Mouse HP G200 Black
Keyboard Redragon MITRA K551-1 RGB
Software Windows 11 Home
Hello folks , so guys as u can c on the SS , drive G is completely empty but 24% of it's space is taken by nothing (or by something invisible) , it's really annoying , do u guys know how can i take advantage of the whole 260 GB on the partition G ??
Did you check hidden files and folders? There can be many things, from Recycle bin files and System Restore points to pagefile and maybe some other crap.
Disable page file on that partition then re-check.
pagefile, says it right in Diskmanager
Congrats, I never saw a 260GB page file till now :D
Many files can be hidden by simply changing their attribute. In cmd, the command is called attrib.exe. You can run it with /? switch to see what it does, and if you wish to do so, you can remove all attributes from all files in a drive. Some files will still remain hidden even after that though. For example, if you create a file and name it starting with a $ symbol, it will be invisible. Again, a cmd command del *.* should delete everything, including the ones with $. After that, all that remains is ADS, and I recommend you google, download and do a cleanup with Phrozen ads remover app. Alternatively, you can simply reformat the damn thing, either basic or low level format.
never been of fan of partitions. hate 'em for some reason, dunno why. it seems cluttered , or messy to me i guess. i think i have a form of PCoCd. I've given all my hard drives & solid-state drives out of my personal computer to my kids and nephews, and all I'm left with is a single 250GB Samsung 850EVO , and even that has almost 100 GB of free space. I can't stand my recycling bin being full, old files or short cuts being on my desktop, or any shortcuts at all on my desktop. The only thing I let it build up old files is my download folder
Well , this issue happened while i was trying to do RAID 0 for my HDDs .
Btw , thank u guys , it worked.
some 1 close this thread:);)
How do you find stuff in your dresser ? Is it just one big drawer ? ... or do you have a sock drawer, underwear draw, pants drawer, shirts, etc :)
That's my logic anyway. But there are a few reasons.
1. I always made at least two partitions so as to keep the OS on it's own partition and aback up OS install on another in case 1st one got fudged.
2. Also since page and temp files are the most frequently used, wanted to keep them closest to the outside edge as possible since the disk is twice as fast at the outside edge as the inner. This was especially important for AutoCAD back in the day, which saved to page / temp files between most operations. Of course on SSD this wont apply. Also having page file on own partition kept it from becomeing fragmented and spread all over the disk slowing things down
3. Various partitions are shared over the network so having separate partitions for each class of usage can make admin easier.
4. Again, there are certain activities in which speed is a concern and some not at all. So backups or archival storage would be placed at the inner edge of a drive. A gaming box might want all near outer edge and apps on slower portion.
5. Backups are another arena ... one drive on my box, is solely for network access ... certain groups of files / folders I want to back up twice a day, others daily, some weekly or monthly ... One drive is accessed by all PCs on the network..... it gets backed up twice a day and just having it backup Q:\ is easy.... T:\ gets done monthly ... the Boot and Applications partitions get backed up monthly. The page / temp file partition, never. yes, i could select dozens of folders at a time but the "by partition" method is just more streamlined/
Yes, many of these concerns go away with an SSD but for organization and administration purposes, I still find partitions useful. This box has (2) SSDs and (2) SSHds BTW...+ an external SSHD for off site storage.
