- Dec 3, 2009
- 1,299 (0.24/day)
- The Netherlands
System Name | PC ||Zephyrus G14 2023 |
Processor | Ryzen 9 5900x || R9 7940HS @ 55W |
Motherboard | MAG B550M MORTAR WIFI || default |
Cooling | 1x Corsair XR5 360mm Rad|| |
Memory | 2x16GB HyperX 3600 @ 3800 || 32GB DDR5 @ 4800MTs |
Video Card(s) | MSI RTX 2080Ti Sea Hawk EK X || RTX 4060 OC |
Storage | Samsung 9801TB x2 + Striped Tiered Storage Space (2x 128Gb SSD + 2x 1TB HDD) || 1TB NVME |
Display(s) | Iiyama PL2770QS + Samsung U28E590, || 14' 2560x1600 165Hz IPS |
Case | SilverStone Alta G1M || |
Audio Device(s) | Asus Xonar DX |
Power Supply | Cooler Master V850 SFX || 240W |
Mouse | ROG Pugio II |
Software | Win 11 64bit || Win 11 64bit |
Hey guys! I wanted to ask your opinion about a card I recently acquired.
The guy I bought it from was using it until he sold it, so i know it's working. The waterblock however seems to be not only be really dirty, but also the nickel started peeling away and there might be some corrosion.
If I can get it clean, and only use it in a loop with only copper or nickel parts, would the state of the waterblock be a problem?
the card:
without stickers/metal:
PCB:
Block after partial cleaning with water, soap and a sponge:
Would value the insights of you guys!
the card:
PCB:
