4 Beeps on Post, intermittent problem
4,213 (0.70/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
So, a little history first. My mobo broke down a couple of months ago giving me 5 short beeps on post. I took it back to the shop and it was repaired.
On Saturday, I replaced one of the fans on my radiator and when I touched the tubing, the computer crashed. I tried to re-start a constantly got 4 short beeps on start-up. So I unplugged everything and tested the video card and ram: no problems.
I left it a day and tried on Sunday morning but got the same problem so I disassembled it all to take back to the shop.
They hooked up the mobo and cpu and it started with no problems and so can't send it in to be fixed as there appear to be no problems.
This has happened a couple of times before and reseating the video-card sorted the issue, but this time, there was nothing I could do.
I'm wondering what could cause this problem and why it would be intermittent. The warranty ends in December and I'm trying to get this rig to last me until the next-gen i5/7's come out, so I'm trying to avoid replacing the system for the time-being.
954 (0.22/day)
Cumberland Plateau
System Name EVGA-FX | Lenny (Lenovo Y480)
Processor AMD FX-8320 @ 4.5GHz 1.416v | i7 3610qm
Motherboard Asus M5A99FX Pro R2.0
Cooling Phanteks PH-TC14PE
Memory 2x4GB Corsair Vengeance @ 1600 | 8gb DDR3 @ 1600
Video Card(s) EVGA GTX780 Classified @ 1228MHz 1.615v | GT640m LE
Storage Crucial M500 480GB, WD Caviar Blue 500GB, WD Scorpio Blue 750GB | Samsung 250GB 840
Display(s) Qnix QX2710 1440p | 42" Vizio 3D LCD TV 1080p
Case CoolerMaster HAF XB Evo
Power Supply Seasonic G-650
Software Windows 6.3.9600
You could try reseating RAM or using only one stick, but System Timer Failure usually means the board is dead (or dying).
519 (0.13/day)
UK
System Name Daedalus
Processor AMD FX 6300
Motherboard ASUS M5A97 EVO R2.0
Cooling Coolermaster Hyper 212 EVO
Memory 8GB Kingston HyperX Genesis (2x4GB)
Video Card(s) MSI R9 270X Gaming 2GB
Storage 1TB Seagate Barracuda
Display(s) LG Flatron E2442 (main - 24in 1080p)
Case NZXT Phantom 410 (Gunmetal Edition)
Power Supply XFX Pro 650W
Mouse Steelseries Siberia [RAW]
Hello,
Assuming its the Gaming System you're referring to, the ASRock mobo uses an AMI BIOS, therefore those four short beeps indicates a System Timer Failure, which means "The system clock/timer IC has failed or there is a memory error in the first bank of memory". Testing each stick of RAM may help, or testing each RAM slot - it could be a dodgy stick, or a sign that the mobo is having its last days.
Layton
4,213 (0.70/day)
Vietnam
Thanks, I found something similar. The AsRock site isn't very helpful, but it is buried there. AsRock warranties suck, you have to go through the shop you bought it from rather than doing a proper RMA. They've kept it for testing, but unless I or they can replicate the issue, I fear I'm going to be stuck with a dying board.
12,062 (2.53/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
That's pretty much commonplace in the UK now, you can't do an RMA or follow up any warranty with the manufacturer, everything is done through the retailer. This is irritating for the end user as it's just another middleman increasing the time for warranties and RMA's, however it greatly reduces the contact the manufacturer has to have with the end user, as they don't like to dedicated resources to that kind of thing, especially when most end users are the kind that are on the phone and say "I has compooter wot wont work".
Sucks for the knowledgable end user, but makes their lives easier I suppose.
Frick
Fishfaced Nincompoop
20,070 (2.87/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
It's been this way for a long time here, and it comes down to the shop. I once sent a DOAish HDD on a monday and had a new one by friday. If it's a cheap thing some shops just send you a new one. On the other hand, some shops are terrible, and some are downright atrocious.
4,213 (0.70/day)
Vietnam
Well, they kept it for 2 days for testing. But, I know they won't replace it unless they can replicate the issue. They weren't interested at all in the beep codes, just whether it would turn on. Knowing my luck, it'll keep doing it at home until January when it's out of warranty :(
Is there anything I can do to replicate this through benchmarking or using a testing tool?
95Viper
Super Moderator
13,313 (2.20/day)
I left it a day and tried on Sunday morning but got the same problem so I disassembled it all to take back to the shop. They hooked up the mobo and cpu and it started with no problems and so can't send it in to be fixed as there appear to be no problems.
Just wondering...
Are they just testing the Motherboard with the CPU or everything, with your parts?
Just my opinion, here.
A large percentage of the time this is a memory issue... Funny thing is most will say they tested the memory and it passed.
Of course it did, at that time and moment.
Could be one of the DIMMs not making good contact or loose, board does not like memory(usually needs tweaking), or dirty dim or slot. Even, possibly, aging DIMM, requiring more vitamins.
Try one DIMM at a time and wiggle it. Check the contacts... cleaning may help.
Also, remember that "System Timer Failure" could possibly be any thing that the timer controls. So, that could cover just any device on the board or anything that depends on that timer.
You may want to try booting to a completely stripped down system and connect one device at a time, even something as mundane as the keyboard.
Good luck, on chasing down the problem.
P.S. : It could be the MB; but, just my opinion, I have to say I am highly doubtful.
4,213 (0.70/day)
Vietnam
Just wondering...
I tested 2 DIMMs together in different slots and individually in different slots, I will try them again though as its an easy test.
The rig booted up fine at the shop, and actually booted fine for me 1 time during testing, after reseating the video card. However, after putting the water-block back on the chip, it stopped working again and testing with a different video-card, it still wouldn't boot.
The first time the board died, it was crashing at random times, until it finally died with a 5-beep error. But, this time, I don't think I've noticed any random crashes apart from the couple of times it's not been able to power on.
Edit - They are just testing the mobo and CPU, but I will bring my own video card and ram back to the shop when I go to collect it. The only thing I haven't tested is the PSU, but I can't imagine this would give a 4-beep error. If it works in the shop, bring it home and it stops working, that is the next thing that I will test.
OneMoar
There is Always Moar
8,840 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
did you pull the motherboard and check for shorts either on the board or against the case or a mounting stand off in the wrong place
4,213 (0.70/day)
Vietnam
The stand offs have been in the same place for the past 2 1/2 years. I did check them a while ago, but not recently. One thing I am thinking is that it could be the pressure exerted by the waterblock on the CPU. I tighten it down all the way, but I assume that the design takes this into consideration.
OneMoar
8,840 (1.61/day)
Rochester area
sounds like a intermittent contact short or possibly a bad psu
95Viper
Super Moderator
13,313 (2.20/day)
That is a possibility, since it did happen when you touched the tubing and re-doing the water block.
Can you try another cooler on the cpu... you may want to check for any warping or other possible problem items (like are solder pads looking normal in the area).
OneMoar
8,840 (1.61/day)
Rochester area
id go ahead pull the block and cpu and reseat everything
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Ditto to that.
Or needs a new CMOS battery? Long shot, but what the heck
4,213 (0.70/day)
Vietnam
No warping and the solder pads look fine. I'm going to pick it up from testing today so I'm assuming they found nothing wrong. When I put it back together, I may try to put the waterblock back on more loosely. However, its a PITA getting even pressure with an AIO system as I have to install it when the mobo is in the case
4,213 (0.70/day)
Vietnam
So, I retested my RAM and one of the sticks seems to be causing the problem. Strange, as I had tested both sticks, one at a time, before and still got the problem.
I'm going to take the troublesome stick back to the shop and I'll see if that is the problem.
4,213 (0.70/day)
Vietnam
Just an update, if anyone else encounters a similar problem. It looks like a faulty DIMM module.
After taking it back to the shop, they found that sometimes it would boot with the module, but not always. I should be getting a replacement soon.
