4k monitor scaling for gaming
4,146 (0.62/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
So, just got a 4k monitor (LG 27UL550-W), pretty nice, although a bit big for the desk, kinda have to move my head around to side to side. (Previous monitor is 2560x1440 23.8")
So I was hoping to run games at 1080p to keep the fps up but still good decently sharp, but it's not. Is this due to the scalar? Will AMD virtual super resolution work for this or not? Is there any other work-arounds for this?
Thanks
9,828 (3.40/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
If that monitor is 10 bit you should be able to run 1440P with a 1.4 cable and get decent FPS, I assume you have a good GPU as you already have a 1440P screen. AMD Radeon Boost would be better if you play FPS. Some games I do set to 1440P (Division) and run them at 60% scaling if possible.
19,379 (3.46/day)
Any non crt monitor not running at its native resolution is going to be a bit blurry... you can try lowering in-game resolution scale, but not sure if that will work.
I always run at my native res... I always bought an appropriate resolution/hz monitor for the card I have. In my case, a 2080ti for 144/165hz gaming. It's good at 60hz 4k too. :)
Try lowering AA or disabling it and other in-game options to get your fps up instead of lowering your res... as was suggested earlier, you should have a decent gpu as you were already at 2560x1440 (maybe fill out system specs so we know what you have, exactly. That said, amd doesnt really have a 4k 60 fps capable card.
What does color depth have to do with running a certain res?
SL2
2,527 (0.36/day)
Is this true if even if you running at half the resolution, like the OP does?
I mean, running 1440 on a 2160 display will obviously make it blurry, but with 1080 on a 2160 I always thought it would get sharper due to having exactly 2 x 2 pixels in the display for each pixel coming from the game. Never tried tho.
9,828 (3.40/day)
Cooling In Win SR36
[/QUOTE]
I have found that with my setup if my panel is set to 8 bit 1440P is exactly that on screen (it does not scale) but when the monitor to 10 bit 1440P scales perfectly on the display. It is just something that I have noticed.
19,379 (3.46/day)
AFAIK, yes. Running at 1080p on a 4k monitor is using 4x of the same pixels/color/size so the fidelity isnt going to be there as compared to running it at the native res.
Dude, get your quoting straight already... are you really that big of a greenhorn (~1.8K posts in) or just messing with me? Sweet jeebus, man...
I still dont understand what color depth has to do with it... do you? It doesnt make sense to me.... it's like fixing the brakes when AC doesnt work...
SL2
2,527 (0.36/day)
Seems like Windows scaling can make games blurry..
Yeah, I understand that, but I meant it should look quite a bit better than 1080 on 1440, because of the lack of interpolation (dunno the correct word here).
19,379 (3.46/day)
Maybe? I just know its blurry compared to native. :)
  • Like
Reactions: SL2
SL2
2,527 (0.36/day)
I just read this about scaling, it's on W8.1 tho, but I don't think it'll make much difference.
19,379 (3.46/day)
Well, I only have a 4K monitor on my test rig, but I will have to try that and see!
  • Like
Reactions: SL2
4,146 (0.62/day)
Thanks for the replies.
So on Win10 x64 pro 1809, other monitor BenQ BL2420PT, and ran default res 2560x1440, card RX480 8GB.
Mainly older games, like BL2, BL GOTY Enhanced, and one newer one, Witcher 3 GOTY.
Not too big of a deal being a bit blurry, but got spoiled at 2560x1440, was pretty sharp. I was hoping there was a good scaler and it would be 2:1 and be pretty good. I only tried 1080p, so maybe I will give 1440p a shot, and see if 2160p makes the card howl lol
I will check the color option in the monitor OSD, I think it''s 8bit+FRC though.
Edit
So no 10-bit option on monitor
Findings
1080p in game settings - blurry
1440p in game settings - pretty good, not perfect though
2160p in game settings - probably the worse, FoV was smaller, like looking through a scope, see below, probably why.
Now, went and checked windows scaling and it's at 150%
So 1.5x1440 = 2160 and that's when the game looked the best.
So looks like windows scaling is being applied in game as well.
Also the vid card ran BL GOTY EE at 60fps at 4k in game, but the fans ramped up.
Other thoughts, think I will try setting windows to 200% and running 1080p just to see how it looks and how FoV is.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Curious, i'll have to poke scaling options and test this myself later
I found that non native res was crap on 4k as well on various screens, but cant recall if i tested the scaler
SL2
2,527 (0.36/day)
Try 100 % while you're at it, just to see what happens. I don't expect you to stay there tho. :D
bug
14,337 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
The problem is, everything interpolates. Only the newest hardware has 1:1 scaling, otherwise even FHD on a 4k monitor will get blurred.
4,509 (1.39/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
Hmm. This is quite weird. On my screen (LG 27UD69 UHD ) I didn't have problems with 1080p. Although I'm not using this res much. I've had problem with one game but it is old and scaling sometimes gets funny here.
Try setting your desktop to lower than 4k when going 1080p with some games and see if it will scale better with 1080p then. :) For me only one game had a problem but it wasn't blurry I just couldn't get it to run :)
3,974 (1.93/day)
Thessaloniki, Greece
System Name PC on since March 2025, upgraded from 5900X
Processor Ryzen 7 9700X (March 2025), 150W PPT limit, 85C temp limit, CO -25, +100MHz (up to 5.65GHz)
Motherboard Asrock X870E NOVA, BIOS v3.2, AGESA PI 1.2.0.3a Patch A
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryosheet
Memory 2x32GB G.Skill Trident Z5 RGB (March2025) 6200MT/s 1.42V CL30-36-36-36-28-64 1T, tRFC:500, Hynix A-D
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (370W current) PowerLimit, 1060mV, Adrenalin v25.3.1
Storage NVMe: 990Pro 2TB(OS 25), 980Pro 1TB(22), 970Pro 512(19) / S-III: 850Pro 1TB(15) 860Evo 1TB(20)
Case Thermaltake Core P8 TG Gaming Full Tower, Fans: 9x140mm + 3x120mm
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3775), Install March 2025
Thanks
What exactly is the issue? Blurry image or its too pixelated (jagged object edges).
It will make sense the second as 1080p on 2160p monitor, as others said, groups 4 pixels (2x2) into one.
In large (and close to viewer) monitors, the picture's pixel density is in half and visible...
4,146 (0.62/day)
Yes I forgot to mention, my windows monitor setting is default at 2160p.
Never had a chance to put windows scaling to 200% and try 1080p gaming res to see how it looks.
Interesting findings/results none the less.
1,212 (0.59/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
4k exactly scales to 1080p but on a 4k monitor if you set 1080p each pixel is 4 pixels so it looks kinda blurry compared with a native 1080p monitor.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
I try and run 4k all the time , even on a 1060 6Gb using scaling, it's very doable.
My main rig runs 4k fine with few tweaks in most games but I game mostly on a 2600k with a 1060 on a 4k 55" telly just fine at 4k on the latest Cod, apex and GtaV ,payday2 and a few others using various normal to medium settings and scaling.
Im about 6-7 feet away with a pad (yes I am crap enough at game's that I don't need keyboard and mouse) and it looks better than 1080p if a little blury i can't tell as much at distance.
Sorry just agreeing and adding to kapone32
1,929 (0.40/day)
Romania
Nvidia and i think AMD now have sharpness filters build in to the drivers, it can get interpolated images a bit sharper and better looking.
PS: if you need to move your head to see on a 27", you are probably too close to it, i don't need to do that on a 32".
miked408
1 (0.00/day)
4k-monitor/
Ahhh, thanks for this. I was getting a blurry image and this was my problem.[/QUOTE]
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
You'll want Virtual Super Resolution off. What that does, for example, is make the card render at whatever you tell the game to render at and it samples it down to whatever the display resolution is. For example, if you have a 1080p monitor, Virtual Super Resolution can allow games to render at 1440p.
This is under Gear icon -> Display. So you'll want to disable Virtual Super Resolution unless you want games to be spammed with a lot of resolution options beyond what your monitor supports.
Also in the same place, you'll find "GPU Scaling." That's what you want to enable. It will make the GPU scale the pixels and output at native resolution (e.g. 1080p -> 4K) rather than trusting the display scaler to do the job. If this is disabled and you run a game at 1080p on a monitor with a 4K native resolution, the display's scaler will be used instead of the GPU's. The GPU should always do a better job at scaling than the monitor.
22,179 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
You want gpu scaling and it has to be integer scaling IIRC.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Integer scaling is directly under GPU scaling. I don't know that integer scaling is better in most circumstances...generally only games with a pixelated look by design.
GPU Scaling ON, Integer Scaling OFF, and Radeon Image Sharpening ON might look better.
