95c laptop under load. HELP!!
ameel500
4 (0.00/day)
Hey there!
Im posting this on every tech forum or subreddit I can until I understand or fix whats going on... I appreciate any help you guys can give me!
I recently bought an MSI GP65 LEAPORD with these specs:
I7 10750H @ 2.6 Ghz
RTX 2070 mobile // 16 GB DDR4 RAM.
I'm a dental student and I use this laptop to play games and study, so I'd like to have this thing alive for more than two years which brings me to the issue.
THE PROBLEM
On turbo mode, you could cook a steak with this thing. It constantly reaches 95 degrees when playing games like PUBG. Ive tried using Throttlestop by reducing the 6 values under TURBO RATIO LIMIT ( because I cant change the actual value of the turbo ratio limit) and Ive tried undervolting ( around –100 mv) on gpu intel, cpu core and cpu cache.
This does solve the temperature issue for sure, but it reduces the fps by ALOT. Id get around 100-120 fps on normal settings while id get 75-95 with undervolt. Ive tried slightly raising different values trying to look for a middle ground but I cant find it. It seems that changing the values of the cores ( the 6 values under the TURBO RATIO LIMIT) is what is affecting the fps and temperature the most. Ive been looking and fiddling with things that I don’t understand and I don’t wanna screw my laptop anymore than I have to.
So, any suggestions?
Deleted member 193596
that's pretty much normal for modern laptops (as long as it's not the highest end laptop on the market)
752 (0.42/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
Well its not the highest no, but Im pretty sure it wont last me if it stay at those temps 4 hours a day
You're fine.. something else will break before the CPU ever will. CPUs are made to not start throttling until 105C, so anything below that is fine, not ideal, but fine. You're maybe shortening the lifespan from 20 years to 15 by running it at 90+. And it's only for four hours a day, which isn't much anyway. And you've got a three-year warranty anyway, I'd assume, so if it does break within that period, you get a repair/replacement.
2,275 (0.97/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
that the going rate of temp on gaming laptops today, as for fps im sure you could tune throttlestop a bit more to get a better out come but to tell you how you need to talk to someone with a bit more knol than me im sure someone will be along shortly. goodluck.
ameel500
4 (0.00/day)
Thank youu
why do you think so?
the temperature is not a big problem.
my friend had a GTX 480 and a 2500k running at over 90°C all the time for almost a decade now.
meanwhile modern chips are actually build to operate at these temperatures.
ameel500
4 (0.00/day)
well pleant of people online say its not sustainable
and how many of them acutally own a laptop running at temps and having a degraded or damaged chip?
you have a warranty. and they don't make a product that breaks so easy that they have to replace it within short time on their own cost.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Intel says the maximum temp for the processor is 100°C, so anything below that is fine.
The processors also have boost states, and they will lower their clock speeds and power consumption automatically to stop themselves from going over that limit. This is the entire point of Turbo boost in laptop processors. It allows them to run as fast as possible while not overheating.
2,275 (0.97/day)
south wales uk
while you waiting you could look on youtube for a guide to your lappy and throttlestop, thats how i sorted my MSI GP72MVR Leopard Pro " mine is a gen older than yours" and max temps are 82c with higher boosts and no frame loss so it can work.
448 (0.06/day)
System Name Desktop
Processor 7800 x3d
Motherboard Giga b650i aorus ultra
Cooling pk-3 | conductonaut | AC LF II 280
Memory 64g Gskill X5 ddr 6000 cl30
Video Card(s) 7900 xt
Storage 2Tb Inland Premium
Display(s) Armada 27 1440p 165 + 25 1080p 240hz
Case Tt Black Armor : Phantek Evolv shift xt
Audio Device(s) Ae-7
Power Supply Aresgame 850 sff
Mouse Razer Viper ulti
Keyboard Saitek Eclipse I, II, & III
Benchmark Scores assd 6600|x5675 Cne11.5 -1102|Timespy 24000 | TS Extreme gpu 1 - 87 fps
eluk max 17 rtx 2070 here. 95c was normal with stock TM, Ive sinced applied cunductonaut to CPU and GPU and temps are 85C. No difference in performance(fps/frequency). These mobile RTX are literally stripped of any overclocking(frequency) capabilities with respect to cooler temps, due to a 0.85v limitation. Increasing power draw to 115 from 80watts is the only form of performance gain. Still a big bump from the x5675@4.6Ghz and GTX 280 i used to run with and now my system can run all modern AAA titles.
3,621 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
Hey there!
I7 10750H @ 2.6 Ghz
THE PROBLEM
Well if you have any experience changing thermal paste on the CPU and GPU then you should do it, Laptop that come with horrible thermal paste application is not rare.
I have the Acer Triton 500 with 10875H + 2070 Super Max-Q and with stock thermal paste I have to lower the Turbo Ratio Limit by 500mhz (from 5.1ghz single core to 4.6ghz) combine with undervolt (170mV core - 85mV Cache) and reduce Long term power limit to 40W so that my CPU can stay below 95C in PUBG.
After changing stock thermal paste with Thermalright TF-X, my 10875H has more thermal headroom to stay at stock Turbo Ratio Limit, stock Power Limit and still below 90C.
Your laptop is pretty easy to open up, just unscrew some screws and pop out the bottom and you can access the internal.
If you have never repasted CPU or GPU then perhaps ask someone to do it for you. Your laptop is pretty expensive afterall.
115 (0.07/day)
System Name MSI
Processor i9 10900KF OC to 5.1ghz
Motherboard MSI Z490i Unify
Cooling MSI 240 Coreliquid R
Memory 32GB3600Mhz
Video Card(s) MSI RTX 3080 Xtrio
Storage 512 mvne + 2tb ssd
Display(s) Samsung G9 Odessy
Case Cooler Master NR200P
Audio Device(s) Steelserie Arctis Pro + GameDac , Logitec z310 desktop speaker
Power Supply Cooler Master SFX 850watt
Mouse Steelseries Rival 650 wireless
Keyboard Steelseries Apex Pro TKL
Hey there!
I7 10750H @ 2.6 Ghz
THE PROBLEM
read my post, they help me use throttle stop to undervolt my gaming laptop well, they advice and persue me to understand the basic. hope it helps you too
