Adding a 2nd drive to enable RAID 0, do I need to format?
3,288 (0.43/day)
Sunny California
Processor AMD Ryzen 7 9800X3D
Motherboard Gigabyte Aorus X870E Elite
Memory 4x16GBs DDR5 6000MHz Corsair Vengeance
Storage 2TB Samsung 990 Pro OS - 4TB Nextorage G Series Games - 8TBs WD Black Storage
Power Supply beQuiet Straight Power 12 1500W
VR HMD Pimax Crystal Light/DMAS
Software Windows 11 Pro 64bit
Hey guys, got a few questions, and I know this is the perfect place to look for the right answer.
Just ordered a couple identical 120GBs SSD that I intend to use in RAID 0 for my OS, but due to limited supply, I had to purchase one from Newegg and one from Amazon. The drive from Newegg arrives tomorrow, but the one from Amazon will take at least a couple weeks to arrive.
Knowing me, I'm gonna want to start using the first drive as soon as I get my hands on it, and this is my first time using a RAID 0 setup by adding a second drive as opposed to enabling it to two identical drives at once.
My questions are: Do I need to format and install everything again once my 2nd drive arrives and I enable RAID 0?
Is there a way to just transfer the data equally between both drives without having to format?
If this cannot be done, can I just clone the first drive to a backup drive an then back again to the RAID 0 drives once enabled? Is that even recommended when using SSDs?
As I said, this is my first time using RAID 0 for my OS, and I feel like a noob :p Please let me know what you guys think. Thank you very much! :rockout:
Yes, u need to format both the drives.
OK, that sucks :p
How about cloning the first drive and then using the image once both drives are "linked"?
OK, that sucks :p
you can't do that either, because u want the OS to be installed on a RAID 0 drive. The OS install will expect the Raid driver which was not present before. You can try tho.
And oh putting OS on a RAID 0 is not advisable, because if one drive dies u loose whole OS. RAID 1 for OS is good.
Oh... I see, didn't think about that, I guess Win 7 has to detect the SSDs and RAID 0 in order enable the TRIM command when you first install it.
Thank you for your advice man! Also, all of my documents are saved to another 500GBs drive by default, maybe I can add another drive to that one for backup purposes. Thanks for the idea.
I would argue this point. As long as you back-up often, this is not an issue. I have had my OS on various RAID arrays for years and never had a problem. Having your OS on a RAID array is what makes the speed boost worthwhile. Yes, you could have a separate array for "Games" or "Media", but the OS functions will still hold back the array each time it has to be accessed.
I say for RAID-0 was made for OS's...what other decent purpose would they serve? I would say 90% of TPU users that run RAID-0 have their OS on it.
Yes, I guess with today's chipsets and drives, the failure rate must be really low, but still, I prefer to configure Win 7 to save all of my important files like documents, pictures and others to another drive, that saves me both drive space, and also a lot of problems as having a drive fail in RAID 0 means your data is unrecoverable, whereas losing the OS means only needing to reformat, still a hassle, but not as bad as losing all your pictures from your last vacation :)
I install OS on a single fast drive and if the board dies or if I want to upgrade or swap the board I mostly had luck in moving the drive to a different setup and Win7 installs all new components, re-activate and I good to go. Ofcourse need to do some old driver clean up, but still the OS is intact.
Can u do the same if its on a RAID 0?
Find a single platter hdd that is big enough for OS and apps and it will still be fast enough.
A single SSD is more than enough for OS.
Again I am not debating, its my proven method of usage and others have varying thoughts and results.
depends on whether you're also using it as your programs drive or not. Os install takes a few minutes. If all you're doing is running it as an os drive than there is zero reason not to run a raid 0 array
raid 0 is only risky on mission critical applications or data you don't have backed up elsewhere. An operating system is neither of those. My nas has a raid 0 array for its os. if one fails I can have my nas back online in under 20 minutes with zero data loss because all of the data is on the raid 1 array, not on the os raid 0 array.
infact using raid 1 on an os drive is moronic imo. what a waste of a hard disk.
