xazraelx
- Oct 23, 2007
- 179 (0.03/day)
Processor | i7 920 @ 3.5ghz |
Motherboard | EVGA x58 |
Cooling | HAF 932 |
Memory | 3x2 Gskills |
Video Card(s) | Dying 4890 1gb |
Storage | Too many |
Case | HAF 932 |
Software | Win7 |
I've been thinking for a while about computers. Sounds dumb, but it's true. I don't really *use* my rig anymore except for folding because I kind of got burnt out of computer gaming due to the massive amount of botting/hacking that I always end up doing. So I've moved into console gaming, but that's irrelevant.
So my love is still computers, I love building them, researching them, I know my ignorance is still tenfold that of quite a few on here, but hey...that's why I'm here. I've looked into "case modding" recently, and it looks like a lot of fun. I honestly don't have a lot of room to do it in my apartment at school, but I would like to start tinkering with some things.
Sorry for the long post, so I'll get to the point.
I've been looking at several case designs (the antec 900, p180, 1200, cm690, etc), and have been thinking about my own CM690. I want to tinker with it a little bit, because I know it's not living up to what it could be at the moment, as my temps are quite warm in my opinion, given the cooling I have.
I have the front 120mm fan pulling in air, and two side 120mm fans pulling in air. On the top are the two 120mm blowing out, as well as the rear 120mm blowing out. The vent behind the mobo I didn't do anything with, as there is no room for clearance and I don't really see a point. And I also don't use the bottom space for a fan.
For reference, these are the two fans I'm using:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999138
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998123
My ideas:
---I honestly don't think the front intake fan pulls much air in, because of all the "mesh" and plastic in front of it, so I'm considering taking that out.
---I was also considering making a little homebrew "vent" for my power supply so that the heat from that gets directed straight outside the case, rather than in the case. Thoughts on this? I would probably be cutting out some of the metal directly above the power supply, then fixing a small 80mm fan there to exhaust the psu air. Would this be stupid without an intake as well? If so, I'm sure the bottom fan can be used to intake air, then push it out the back.
---Thoughts on the top fans...I can put a piece of paper over them, and it just hovers. I don't think they are pushing out the amount of air they should either. I think this case has a flaw in that it really restricts the amount of airflow because of the "dust filterS" and plastic that is covering the fans. Maybe I can cut out the mesh and plastic, thus simply leaving the case "grill" over the fan. Or I could possibly buy some thinner filters. I'm honestly not sure, I have no experience in this.
---Ways to improve the overall airflow. Are my intakes/outtakes being utilized at their most? Or is there a better way I can do this.
---Move my case from under my desk (still free airflow, just against the wall) to on top of my desk. I suppose this might help
Misunderstandings:
My case is the CM 690. The PSU is located on the bottom.
My ideas:
Misunderstandings:
