Advice on likely PSU or mobo problem
scoie
7 (0.06/day)
UK
Hi all, interesting problem for you. This isn't a new build, rather one I did last December, but I have a recurring, annoying problem that I think this forum would be best placed to give advice on. First, the build:
Ryzen 5800X
Gigabyte 3090 Eagle OC
Asus ROG STRIX B550-F Gaming
2x16GB Corsair Vengeance LPX 3600MHz DDR4
BeQuiet Dark Power Pro P10 850W 80Plus Platinum
Win 10 Home 20H2
Valve Index VR headset
This is a good set of components and I'm very happy with its performance. However... in certain circumstances the machine hard powers off completely, like the power lead had just been yanked out. It's then completely dead (on/off switch does nothing) until I open it up, pull out the ATX power cable to the mobo and then reseat it. Only then will it restart, with no obvious ill effects. Googling around, this might be a way of draining the mobo capacitors and properly 'resetting' everything.
The hard power offs always occur when gaming, but only in certain games. I've had it in Doom 2016 and Subnautica BZ, but in random places. It happens more often in certain VR games and here it is reproducible - launching Google Earth VR will immediately cut the power as will starting a VR flight in MSFS (but not starting VR mode in the menus, that works fine, it's starting a flight that kills it). Most other VR games are fine - have played through Alyx multiple times with settings cranked up and not seen this once.
This sounds like a power delivery problem. My PSU is good quality, but is 850W sufficient for my GPU? It should be... Could it be a problem on the mobo? Would upgrading to a X570 with better power regulation help? The problem is I'm loathe to spend a whole bunch (more!) money replacing expensive components when I don't know what the problem is. What I find curious is that I can make this happen by firing up Google Earth VR from desktop. This tells me it's not heat related, as the CPU/GPU wouldn't have time to get hot. Also the power offs don't occur in demanding games (Cyberpunk 2077 runs in 4k with all raytracing on just fine) so it's not a problem with power availability, as everything can run at max power draw just fine for hours. The only thing I can think of is some kind of power surge that certain software conditions create which trips some safety switch somewhere. Or there is a weird fault with one of my components.
Would it help to run some kind of system logger and then engineer one of the power offs?
Thanks in advance for anyone who replies with advice!
Scoie
2,256 (1.91/day)
California
System Name His & Hers
Processor R7 5800X/ R9 5950X Stock
Motherboard X570 Aorus Master/ROG Crosshair VIII Hero
Memory 32 GB 4x8GB 4000CL15 Trident Z Royal/ 32 GB 3200 CL14 @3800 CL16 Team T Force Nighthawk
Video Card(s) Evga FTW 3 Ultra 3080ti/Asus Rog Strix 2080ti.
Storage lots of SSD.
Display(s) LG C1 48/ LG 27GN850/ MSI 27 inch VA panel.
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
The 3090 can have transient spikes above 500w likely triggering the ocp on the psu. The easiest thing to try is a quality 1000w psu with a good return policy. My 850w seasonic titanium psu handles a 5950x/3080ti fine but I've never seen more than 650w peak usage at the plug using a wattage meter.
scoie
7 (0.06/day)
UK
Thanks for quick response. Would a system logger pick that up? Or would it be too sudden to capture it? I think loggers poll every 1s at best.
252 (0.25/day)
Texas
Processor AMD R9 5900x
Cooling I forgot to get a aio I r stupidity
Memory corsair vengeance rgb pro 32gb
Video Card(s) xfx rx5600xt
Storage 4 ssd 2 hdd
Display(s) 40" samsung
Case Corsair icue 220t rgb
Power Supply corsair RM850 modular
Mouse logitech
Keyboard logitech
Software w10
System logger should record the event. Very much interested in your problem.
6,816 (1.35/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) Sapphire Nitro+ RX 6700XT
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) ASUS VP28UQG 28" 4K
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Sennheiser HD518 headphones
Power Supply XFX 750W XXX edition
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/20031033
Have you manually OC'ed your CPU and/or your 3090? Going by BeQuiet's PSU calculator, you should be fine with 850 watts for your system, if you do not OC it. If you OC it, the PSU calculator says you need a 1000 watt PSU. Yes, I know PSU calculators aren't 100% accurate, but it is a starting point.
scoie
7 (0.06/day)
UK
Stock speeds on both CPU and GPU. I have the RAM running at DOCP values, but I can't imagine that will be the problem.
880 (2.91/day)
Germany
Processor Intel Core i5 12600K (5.1 Ghz /4.1 Ghz 4.0 Ghz /// P/E/Ring) and tons of others (F.E 5950x, 10900k)
Motherboard MSI Z690 PRO A DDR4
Cooling Noctua NH-D15 Chromax. Black
Memory G.Skill Trident Z Neo 3600 Mhz CL16 (2x16GB) Gear 1 CR1
Video Card(s) All Ampere, two 6900XTs and other RDNA2, all Turing, all Pascal, Vegas, 980 Tis and older.
Storage Corsair MP 600 Pro 1TB, 4TB Sandisk 3D Ultra, 2x Samsung 870 QVO 4TB external.
Display(s) ASUS ROG STRIX XG27UQR 4K 144Hz / Samsung Odyssey G7 32" and others.
Case Fractal Design Meshify S2 White TG / Noctua NF-A14 iPPC-3000RPM Fans
Audio Device(s) Bose Companion Series 2 III, Sennheiser GSP600 running through a SoundblasterX G6
Power Supply bequiet! Dark Power Pro 12 1200w Titanium
Mouse G303 Shroud Edition, Model O, G903 Hero, G502 Hero SE, EC2-A
Keyboard ASUS ROG Strix Scope TKL DLX, Corsair K95, Logitech G815
VR HMD Oculus Rift S
this PSU is almost a decade old and my 3090 barely runs on a DP P11 (from 2016, the successor of yours)
100% the PSU.
scoie
7 (0.06/day)
UK
Maybe I'm running things a little too tight on the PSU then. I'll run a logger and report back, but I expect I'll end up trying a beefier PSU.
880 (2.91/day)
Germany
if you can get the straight power 11 platinum 1200W for a decent price think about it (i ran two 3090s from it with no issues and it is 100% silent and stable)
scoie
7 (0.06/day)
UK
Here's a log. I've charted the CPU and GPU power. The first part of the chart is loading the steam VR lobby room. Bit of a delay until I launched GE VR because I had to download it again. It gets as far as the logo and 'building earth' up to 14% then the power dies. There's nothing obvious in the chart to suggest a problem - CPU hovers around 70W, GPU goes up to 320W which is standard for this card. Temps were 66C for CPU and 64C for GPU, so no problem there.
So looks like my best bet is a new PSU. You mentioned the 1200W beQuiet unit. They're difficult to get hold of in the UK right now - Amazon have got it for £290, but that's £80 more than it should be. Can get for £210, but that's for a 15th Sep delivery... The 1000W equivalent is available, would another 150W be enough to be sure?
  • OpenHardwareMonitorLog-2021-08-01.xlsx
880 (2.91/day)
Germany
for a 3090 or 6900XT a 1KW unit is a safe bet.
i'd recommend the Corsair HX series, be quiet straight power, or a seasonic PSU.
the 1000W version is totally fine.
scoie
7 (0.06/day)
UK
Thanks for the advice, I'll be able to test this out later in the week and will report back.
856 (0.23/day)
Processor Intel core i9 10900k @5.5ghz
Motherboard Asus Maximus XII APEX
Memory 2x16gb Gskillz Trident Z 4600mhz cl16
Video Card(s) EVGA FTW3 ULTRA RTX 3090
Storage 1TB Samsung 860Evo,2*2tb Samsung 970Evo Plus, 1tb Intel 660p nvme
Display(s) LG Ultragear 27" IPS 1440P 144HZ
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
And when you flash 1kw bios on your 3090, you will need a bigger PSU.
33,200 (6.30/day)
Who makes be quiet psus, I know their coolers are great but psus im unsure about.
2,256 (1.91/day)
California
No idea, I think like a lot of other brands they have good and meh psu.
880 (2.91/day)
Germany
mostly CWTs high end platforms with slight modifications.
their PSUs are basically top tier and even their "upper mid tier" is on top of the PSU tier list.
6,816 (1.35/day)
S.E. Virginia
Processor i9 10850k
How about a 1000 watt Seasonic for £153.48? https://uk.pcpartpicker.com/product...-fully-modular-atx-power-supply-focus-gx-1000
FreedomEclipse
~Technological Technocrat~
21,979 (4.11/day)
London,UK
Processor Intel 8600k@4.8Ghz
Video Card(s) Gigabyte 1080Ti Gaming OC|Accelero Xtreme IV
Storage Samsung 970Evo 512GB SSD (Boot)|WD Blue 1TB SSD|2x 3TB Toshiba DT01ACA300
Display(s) Asus PB278Q 27"
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900/G502
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
33,200 (6.30/day)
scoie
7 (0.06/day)
UK
A million likes to all who contributed to this. I took delivery of a 1000W bequiet PSU today, just swapped it out and now GE VR works flawlessly. If that works I'm going to assume the other stuff does too, so the culprit was the PSU. This advice has been extremely useful and has solved a problem that's been bugging me for months, so thanks once again. I've never had a PSU problem in any build I've had previously, but then I've never owned a 3090 before!
880 (2.91/day)
Germany
Awesome :)
have fun! :peace:
616 (1.26/day)
Late to the party but you do not need 1,000W to run a 3090. I recommended a 750W Prime to a friend of mines w/ 3090 and it's doing the job just fine. There's a reason why the OCP and OPP points are set rather high on most if not all highend PSUs.
880 (2.91/day)
Germany
ever heard of transients?
616 (1.26/day)
Yes. That's why a 750W Prime is rated for 850-900W and doesn't shutdown until like 950W.
