Gwaihir137
- Aug 1, 2022
- 2 (0.00/day)
hi,
I hope I'm posting to the right forum, as this seems to be a hardware related issue but I'm using ThrottleStop as a workaround! I have a notebook with a Intel Core i7-8750h and Nvidia RTX 2060 Mobile stock undervolted by -50mV, which has been behaving strangely lately. The fact that I'm not able to identify the cause is giving me headaches, After weeks of tinkering around, I personally think the cpu is faulty but I wanted to ask you guys about your opinion and the possibilities to get the best out of my notebook using ThrottleStop, which I have been using for testing and optimization, as there are a lot of guides out there. Especially for the 8750h, which tends to run hot.
Problems first occured when I played Valheim, were I experienced random CTDs after a short time period. I first thought it to be a temperature related problem, so I disassembled the notebook and reapplied the thermal paste, but the problems persisted. To keep it short
Sorry for the long post and thanks in advance!
Gwaihir
Here is some more technical information for you
After boot
FIVR
TPL
stress test using prime95
Overview of stable ThrottleStop UVs, each measurement was taken after 10 Minutes of Cinebench R23 Multicore
more information about my undervolting experience on my blog (german): https://keepmydesktop.blog/2022/04/10/gaming-notebook-kuhler-schneller-leiser/
- When running cpu + gpu intensive applications or games, many of them will likely CTD after a few minutes. Most of the time the application just quits, sometimes I'm getting BSODs like WHEA_UNCORRECTABLE_ERROR or CLOCK_WATCHDOG_TIMEOUT (and others)
- My UEFI power management comes with 4 different profiles. When I choose "quiet" or "power saving" the CPU is limited to 2.2 GHz. Then there are no CTDs, notebook runs stable, but at a fraction of the performance.
- reinstall Windows, updating drivers etc etc
- running memtest, no errors
- some measurements using hwinfo64 and benchmarking tools. Temperatures are within the limit (cpu <90°C using prime95, gpu < 75°C using Furmark) and surprisingly zero crashes in whatever benchmark I used
- Removing the UEFI undervolt setting of -50mV, which seems to slightly decrease the amount of CTDs
- I'm mainly using "balanced" power mode (default) for day to day work, where the i8750h boosts up alle the way to 3.9 GHz. When I disable turbo boost in ThrottleStop or reduce the turbo ratios for all values to 22 (which effectively disables turbo boost), I'm experiencing the same crashes
- Extensive uv testing using ThrottleStop, which gives me a huge performance gain with reduced temps and power consumption. I mainly experimented with the FIVR voltage offset where I can go up to -200mV core voltage and -100mV Cache voltage. My settings run stable in all benchmarks, at day to day work and games which mainly utilize the CPU (like Minecraft) but the games which have had problems before will crash even more often
- Using "quiet" power mode and overriding the cpu settings with ThrottleStop leads to the same crashes, so I don't think the gpu is involved into the problem
Gwaihir
After boot
FIVR
TPL
Profile | Core 0 MHz avg | Temp Core C Avg | Temp Core C Idle | Temp Core C Max | VID V | CPU Ppow W max |
Stock +0 | 3160 | 84 | 54 | 96 | 1.298 | 86,7 |
UV -50 (core only) | 3316 | 84 | 48 | 96 | 1.234 | 89,2 |
UV -70 | 3344 | 83 | 45 | 95 | 1.208 | 89,6 |
UV -100 | 3452 | 83 | 43 | 94 | 1.170 | 87,2 |
UV -110 | 3444 | 84 | 43 | 95 | 1.163 | 85,4 |
UV -120 | 3486 | 83 | 43 | 95 | 1.156 | 83,5 |
UV -130 | 3565 | 84 | 43 | 94 | 1.146 | 82,1 |
UV -140 | 3525 | 83 | 43 | 93 | 1.136 | 80,3 |
UV -150 | 3568 | 83 | 43 | 93 | 1.126 | 77,9 |
UV -170/-70 (core/cache) | 3556 | 84 | 43 | 92 | 1.127 | 79 |
UV -180/-80 | 3563 | 84 | 43 | 93 | 1.112 | 76,9 |
UV -190/-90 | 3604 | 83 | 43 | 91 | 1.107 | 75,6 |
UV -200/-100 | 3660 | 81 | 43 | 89 | 1.092 | 73,2 |
