AGP voltage increase in bios...card run better???
675 (0.10/day)
Michigan, US
System Name Clarise
Processor AMD Athlon 64 X2 4200+ (Toledo) @2.8 (255 X 11)
Motherboard Asus A8v Deluxe rev 2
Cooling Gigabyte 3D Cooler Pro + 5 Case Fans
Memory 2GB G-Skill (2.5-3-3-6 1T) @ 467mhz
Video Card(s) XFX 7600GT 256MB GDDR3 @ 640-814
Storage Western Digital WD5000AAKS 500GB (Sata) Maxtor 120GB (Sata) Western Digital 120GB (ide)
Display(s) 19" HP Pavilion M90 / 33" Sony Wega Trinitron
Case Antec Lanboy with a few mods :0)
Audio Device(s) Creative Audigy 4 Pro - Bose Free Style 2.1 Speakers
Power Supply Rosewill Extreme Edition 500W 34A 12V rail
Software Windows XP Pro & Vista Ultimate
hey if i up the voltage to my agp in my bios will my card OC better? i am new to OC'ing vid cards. i can get 540-355 from 500-300 with no artifacts in ati tray tools, but if i play battlefield i get some artifacts, or it causes my PC to reboot. it runs stable at 535-340, with stock voltage. i realize that neither are a big jump, but i dont have the $$$ for a new card right now, and anything will help! :)
4,936 (0.73/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
Card might not run faster but it will certainly die much much faster:respect:
675 (0.10/day)
Michigan, US
System Name Clarise
i can only change it from 1.5 to 1.6 so i is not a big change. but if you think it is a bad idea i will not change it.
4,936 (0.73/day)
Hong Kong
Well, you can't really get much from a 9600XT...
Solaris17
Super Dainty Moderator
27,611 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
i actually have been thiking this can we get alot of input id like to hear alot of ppls opinions for example i know its not safe but...
675 (0.10/day)
Michigan, US
System Name Clarise
i would like to learn anything i can to get the most out of it as i am broke and cant buy a new one for a bit
s4fun
19 (0.00/day)
Processor AMD64 4400+ X2
Motherboard Abit AV8-3rd Eye
Cooling Zalman 7000cu
Memory Patriot Performace CAS 2.0 2x512MB
Video Card(s) HIS Iceq3 x1950 pro agp 256 MB
Display(s) Samsung 225bw 22" LCD
Case Antec Sonata
Power Supply Corsair HX 520
Software WinXP pro, SuSE Linux Dual boot
Misery likes company. Glad to know another ATI user need to up the AGP voltage. Cursed ATI is always trouble of this sort one way or the other. Up that voltage. Disable fast writes. No AGP calibration cycle. etc. Every motherboard is different with every ATI card and the curse is for you to find that magic combination. Screw ATI.
I've had to do with every stinking ATI board I got currently and in the past and that means 9600xt, 9800xt, x850xt and x1950 pro. Welcome to the club. Suffer the fools.
4,936 (0.73/day)
Hong Kong
Wow, a hardcore nVidia Fanboy:D
And btw, stop the fukin triple posting.
You are making yourself sound like an idiot.:respect:
675 (0.10/day)
Michigan, US
System Name Clarise
haha, i like ATI and havent had many problems with it. other than drivers. with the Omega dirvers it is much better. i just wanted to know if there were and tweaks i could do to get more out of it, already has the latest bios and as far as i can find, that is about all i can do to it.
s4fun
19 (0.00/day)
Case Antec Sonata
Well I am an idiot. I keep buying ATI stuff, because sometimes their performance per dollar is simply undeniable. But it doesn't mean I'm gonna give them a free pass on the stuff they keep screwing up on.
Kammster
188 (0.03/day)
Guyana, South America
Processor Sempron 64 2800+ DH-E6 (@2Ghz - bios limit)
Motherboard DFI NF3 250-AL (@250 FSB - 2000 HTT)
Cooling 92mm + 80mm Exhausts / Amd HSF mod:80mm fan + VF700 cuLED [mod to x800 fan control]
Memory 1GB Buffalo DDR 400 @416 3-4-4-8 1T
Video Card(s) Sapphire X800 GTO (broken- sapphire is BAD)--256mb 6200
Storage WD 120 GB Caviar SE + 1GB Flash [80GB 7200.9 offline]
Display(s) 19" Samsung Widesceen LCD
Case Xtech cheapo
Audio Device(s) onboard - Realtek 6Ch
Power Supply Coolermaster eXtreme Power 550W w/ Antec 120mmLED
Software Windows XP SP2 + nforce 76.45 + nforce 5.10
what voltage did u use on the
X850
x1950
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
i tried that on my ti4200 got an xtra 10mhz on the core that was it. :D it only helps on boards with poor power management cause the higher voltage allows the fluctuations to stay higher than stock Agp voltage.
675 (0.10/day)
Michigan, US
System Name Clarise
right now i can only get 535 and 342 stable with my 9600XT
Kammster
188 (0.03/day)
Case Xtech cheapo
are there physical voltage mods, like crossing two pins to boost agp voltage without mainboard support
s4fun
19 (0.00/day)
Case Antec Sonata
I'm running 1.6v for the 9800xt and x850 xt and 1.55v for the x1950 pro. All have disable fast writes. The AGP 3.0 calibration is disabled for the 9800xt but enabled for the others. AGP aperture size is set to 128mb for the x1950 pro and x850xt and 64mb for the 9800xt.
675 (0.10/day)
Michigan, US
System Name Clarise
does the smaller aperature size help out the vid card? case i have mine set at 256.??..
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
s4fun
19 (0.00/day)
Case Antec Sonata
Theoretically speaking, aperture size should only matter when your all the texture sizes added up exceed the memory on your video card. However the reality is some cards are more fussy than others about what aperture size is given. So if your having stability problems it is one more thing to troubleshoot.
675 (0.10/day)
Michigan, US
System Name Clarise
well i have no idea what i did, but after i reformatted my PC and reinstalled everything i can run Battlefield 2 with everything on high. and it runs good. the only thing i have a problem with is being able to see my sights when i am lookin at the sky, like trying to shoot a Heli from the gunner seat of another one. bhut i can deal with it i guess. might be my huge ass old HP monitor too.
