align 1mb to partition while keeping data intact
283 (0.06/day)
System Name Amazing Experience
Processor Intel Core i5 7500
Motherboard MSI H110M Pro-VD
Cooling Deepcool Alta 7 (CPU) | 2x 120mm RGB Case Fans (Rear and Front)
Memory Hynix 16GB (2x8) 2400Mhz (13-13-13-28)
Video Card(s) Zotac GTX 750 Ti 2GB GDDR5
Storage Crucial BX500 120GB; Seagate Barracuda 1TB+2TB; Dell 1TB Ext. HDD
Display(s) HP 22es
Case Ant Esports ICE-211TG
Audio Device(s) F&D A110 2.1 Stereo Speakers
Power Supply Circle 500 Watts APFC
Mouse Redragon M609
Keyboard TVS Gold Mechanical Keyboard (MX Blue, PS/2)
so i heard 1mb partition space at the start of drive can improve performance on SSDs and Advanced Format disks, might be helpful for my bx500 and my both HDDs are AF as well, there are 3rd party tools like minitool which can do that but i guess it require formatting but i have lots of important data and no space to backup.
The most recent partitioning software which doesn't do 1mb alignment out of the box these days was the Windows XP installer.
I assume you are fine already.
So fist you need to address this. Then stop with the "this will speed up your drive" The 1 mb is a normal part of a GPT format. MBR does not have it I believe
only my media drive has it
so it doesn't do anything beneficial?
Well it's there for a reason but if you don't have one it's because you don't have a GPT partition. GPT partition is better on a SSD but before you convert any partition back up your data
Check your properties under disk management and see what type of partition style
Well it's there for a reason but if you don't have one. It's because you don't have a GPT partition. GPT partition is better on a SSD but before you convert any partition back up your data
all my drives are gpt except external
i don't need to check that, diskpart command shows it as you can see it in my ss, btw i think that 1mb it was showing was something else and i just reclaimed it using extend volume command in diskpart :D
So it should already have a 1 Mb partion on the OS (C) drive only
