Raevenlord
- Aug 12, 2016
- 3,755 (1.18/day)
- Portugal
System Name | The Ryzening |
Processor | AMD Ryzen 9 5900X |
Motherboard | MSI X570 MAG TOMAHAWK |
Cooling | Lian Li Galahad 360mm AIO |
Memory | 32 GB G.Skill Trident Z F4-3733 (4x 8 GB) |
Video Card(s) | Gigabyte RTX 3070 Ti |
Storage | Boot: Transcend MTE220S 2TB, Kintson A2000 1TB, Seagate Firewolf Pro 14 TB |
Display(s) | Acer Nitro VG270UP (1440p 144 Hz IPS) |
Case | Lian Li O11DX Dynamic White |
Audio Device(s) | iFi Audio Zen DAC |
Power Supply | Seasonic Focus+ 750 W |
Mouse | Cooler Master Masterkeys Lite L |
Keyboard | Cooler Master Masterkeys Lite L |
Software | Windows 10 x64 |
At CES 2017, Alphacool showcased their external, AIO cooling solution for all your CPU cooling needs. What's really interesting about this solution is that it's fully external (barring the cooling tubes), meaning that no amount of heat will be dissipated inside your computer case, which should, in turn, improve overall temperatures in your system's components. And it also stands as a solution for users whose PC case doesn't support a 360mm radiator.
A 360mm XT45 Copper radiator makes up the bulk of the Eiswand. A total of six 700 RPM Eiswand Fans set up in a push-pull configuration keep the system cool, with two DC-LT Low noise ceramic pumps act as the Eiswand's heart, with universal socket compatibility guaranteeing you can use it in your system. The Eiswand also features a LED base that lights-up blue when powered.
