Alternate Frame Rendering
OrbitzXT
1,969 (0.30/day)
New York City
System Name AX-01
Processor Intel Core i5-2500K @3.7 GHz
Motherboard ASRock Z68 Extreme3 Gen3
Cooling Zalman 9700
Memory Kingston HyperX T1 Series 8GB DDR3 1600 MHZ
Video Card(s) GTX 590
Storage Intel X25-M
Display(s) 42" Samsung LED HDTV
Case Antec Twelve Hundred
Audio Device(s) HT | OMEGA STRIKER 7.1
Power Supply Kingwin 1000W
Software Windows 7 64-Bit
I have a 4870X2 that isn't always supported by some games, and it was recommended to me to set it so its alternating frames. I was told that when a game doesn't support Crossfire or SLI this is the best thing to do. Anywho, for the life of me I can't figure out how to set "Alternate Frame Rendering" with my 4870X2. I might be overlooking it but I don't see a setting in CCC, and am using the latest 9.9 drivers for Windows 7.
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
No, you're not missing anything. Unfortunately, it's not possible to set AFR modes in the CCC, even with twin 3850X2 cards like I have. You can on the nvidia control panel and it has more 3D setting options, too.
Wassup ATI? :wtf:
You might want to try googling for CCC hacks that might allow you to adjust AFR.
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Motherboard Asrock B450M Pro4
Cooling Some CM tower cooler that will fit my case
Memory 4 x 8GB Kingston HyperX Fury 2666MHz
Video Card(s) IGP
Storage ADATA SU800 512GB
Display(s) 27' LG
Case Zalman
Audio Device(s) stock
Power Supply Seasonic SS-620GM
Software win10
Not sure, but I think that your best bet is ati ray tools
REVHEAD
300 (0.04/day)
Sydney/ Australia
Processor Intel i7 920 d0 stepping @ 200x19 qpi
Motherboard Gigabyte EX58-UD3R
Cooling Noctua
Memory Patriot 1333 MHZ ram 6gb Triple Channel @ 1600 MHZ
Video Card(s) ATI 5870 x2 in Crossfire
Storage 4X WD 80gb Veloci Raptors in Raid 0 & Seagate 500gb 7200.11 x 2 in raid 0
Display(s) Dell 3007 WFP
Case Lian Li A-10b
Power Supply CoolerMaster realpower pro 1000w
Software Windows 7 X64 ultimate RC
Go into Catylist AI
Standard uses the Default ATI game profile, and Advanced uses AFR this has allways been the case since the old Days of using crossfire with a dongle. Hope this helps.
1,618 (0.27/day)
yes, advanced should do AFR if there is no profile
but issues can still arise if the game is coded unusually
