AMD FreeSync
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Razer
Keyboard Corsair
Software Win 11
Hi guys,
Got a strange problem here...
I'm trying to get 2560x1440 @ 120Hz working on my 4K Samsung UA65NU800W with AMD cards Specifically. I have no issues running 4K @ 60Hz. The TV has a "Gaming Option" which you can switch OFF/ON with the "FreeSync" option of Basic/Ultimate.
I've found that the "Basic" option works best for 120Hz @ 2560 x 1440 with the Nvidia Cards. The "Ultimate" option seems to be for 4K @ 60hz
I have had no issues running Nvidia cards (even a GTX980) with the resolution of 2560x1440 @ 120Hz. I know the TV is definitely capable of doing so. Its listed in the monitors "properties" list of resolutions with its attached Hz its capable of. I'm just unable to get any AMD card to work which is frustrating because FreeSync is for AMD cards?? :rolleyes:
So the card in question atm is a shiny new 6800 XT XFX Merc : )
So... Things I've done is: Turned on FreeSync in the AMD Driver, Turned on "Gaming Mode" with the "Basic" FreeSync option on the TV (4K @ 60hz works no probs on ultimate setting), Set my desktop res to 2560 x 1440 @ 120Hz so games might kick in (no go either).
BTW the Nvidia cards work best (2560x1440 @ 120Hz) with the "Gaming Mode" in the "OFF" position on the TV settings with the "FreeSync" option shaded in "Basic".
This seems to be the best "TV" option for the AMD cards too but they will only run 2560x1440 @ 60Hz.
Is there something I am missing? Or is it just not going to be possible to get 120Hz working with 2560x1440 with any AMD card?
Thanks in advance.
14,557 (3.79/day)
Sunshine Coast Australia
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
HDMI?
Try DisplayPort.
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
1,138 (0.25/day)
Babylon 5
System Name DaBeast!!! DaBeast2!!!
Processor AMD AM4 Ryzen 7 5700X3D 8C/16T/AMD AM4 RYZEN 9 5900X 12C/24T
Cooling Thermaltake Water 3.0 360 AIO/Thermalright PA 120 SE
Mouse Logitech G303 Shroud Ed/Logitech G603 WL
Keyboard Logitech G915/Keychron K2
Software Win11 Pro/Win11 Pro
HDMI?
Try DisplayPort.
Yep, if OP's using HDMI, swap to DP. I have my Freesync 2 monitor hooked up to my 6900 XT via DP cable @3840x1080/144Hz without any issue.
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
See reply above matey.
So regardless, why do I have no issue with NVIDIA cards?
5,682 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
AMD only support Freesync over HDMI2.1 or Displayport 1.4 or better try an Displayport to HDMI cable instead
Either nvidia is seeing it as gsync compatible or doesn't care that you're using HDMI2.0 or it isn't actually working via an nVidia GPU just because it says it on on the TV doesn't mean it's actually functioning
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
So I'm running a 2.1 HDMI cable but don't think the TV supports it so is this the problem? NVIDIA works no prob... Its AMD FreeSyn ffs...
Ill try your recommendation and report back.
Thanks pal.
5,682 (1.02/day)
Gougeland (NZ)
this isn't a PC monitor though it's a TV and doesn't have dedicated DP ports so DP to HDMI cable maybe otherwise
Thanks pal.
any chance you can put up a screenie of the setting on the TV
74 (0.03/day)
You said you are setting your desktop to 2560x1440 @ 120Hz but is that the signal that is being sent to the TV?
In your windows display adapter settings click 'List Modes' and double click the '2560x1440 @ 120Hz' setting. Does anything seem to change?
In your AMD driver display settings what is being reported as supported? We can configure what is supported with CRU if required.
I'm using a vega64 with an LG C9 and here is what my settings look like when set to 1440p 120Hz. If my Vega supports it your 6800 is going to support it.
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
No issue's with the Desktop mate.
Its as soon as I start gaming it will only do 60Hz..
Edit. Here this is what happens in all games no matter what setting I try.. Frustrating..
BTW I have tried a Vega 56 to no avail..
I don't have a HDMI to DP atm so if I get a chance tomorrow ill pick one up and see what happens.
Thing is I really shouldn't have to when all Nvidia cards I've tried (6-7) all work piece of piss.
74 (0.03/day)
Is that gaming in borderless window?
What games are you running? Have you tried the nVidia (Pendulum) or AMD freesync demos (Windmill)?
I use CRU to remove supported refresh rates as old DX 9 or 10 games (Crysis) would drop down the refresh rate to the lowest supported with no way to change it when using HDMI.
The TV has been tested and working fine with freesync so should work for you if your firmware is up to date.
https://www.rtings.com/tv/reviews/samsung/nu8000#page-test-results
1440p VRR Maximum 120 Hz
1440p VRR Minimum < 20 Hz
"FreeSync is activated by enabling the TV's Game mode and FreeSync settings; PC mode is not required. We tested in Ultimate mode because it has the widest range"
That picture looks like Crysis!
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
No, Full Screen
Id say its just a general bug with the TV and AMD drivers. The NVidia cards I have run (lots) will all do 120Hz 2560x1440. No sweat!
Games I've run atm is Crysis, Metro 2033 and Elder scrolls IV. I don't see the point in running any more as these games all work with Nvidia cards. AMD doesn't : (
I'm going to try a HDMI to DP and see what that brings to the table.
Cheers.
74 (0.03/day)
The DP to HDMI adapter won't work. The lower refresh rates need to be removed with CRU.
I know because I had this issue over a decade ago when I use to run DP to HDMI adapter for my gaming display.
409 (0.07/day)
US
Further to the point, Nvidia doesn't support GSync/FreeSync over HDMI, it is only supported over DP on Nvidia's side. So Nvidia is not running with FreeSync enabled if the connection is HDMI regardless of what the display may be reporting.
AMD supports FreeSync over DP and specifically HDMI (regardless of version) if the display/tv is FreeSync certified. In all other cases AMD supports VRR over DP and HDMI 2.1.
None of that explains why you aren't seeing 120hz on AMD. I do know AMD seems to be far pickier in terms of HDMI cable quality than Nvidia is.
uJamBo
8 (0.01/day)
hdmi 2.0 cable might fix this i have a feeling the cable is a lower hdmi version or the cable is longer than 2m if it is longer than 2m you get signal power loss
74 (0.03/day)
It is not the cable. There is a well known bug when using HDMI with some game engines and DX10. If Outback Bronze tried to play the game at 4k or 1080p I bet the game will run at 24Hz.
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
Yes and no...
If I enable FreeSync on the TV with the "Ultimate" option 4k will run @ 60hz no trouble.
If I enable the basic option, yes it runs @ 24hz.
The old fashion way all I had to do was run a custom res say 3839 x 2160 and it would run @ 60hz on 4K. I assume we are talking about the original Crysis?
74 (0.03/day)
Yes and no...
Crysis and Warhead plus there are several other games too. Custom resolution doesn't work as reliably as the CRU method.
uJamBo
8 (0.01/day)
my friend had the same issues the cable was to long 4k 60 loses signal strength over 2 meters resulting in lower refresh rates its nothing to do with games, tv's or graphics cards ITS THE CABLE
Outback Bronze
Super Moderator
2,200 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
My cable is 2m long. Is this too long?
So, if it is the cable how do you explain Nvidia cards working? Are AMD cards more sensitive to signal strength?
