Sammy187211
- Aug 24, 2017
- 7 (0.00/day)
Ive recently put in a amd fx 8370 and my temps are hiting 60 to 67 with in minutes i have good air flow
System Name | RyzenGtEvo/ Asus strix scar II |
Processor | Amd R5 5900X/ Intel 8750H |
Motherboard | Crosshair hero8 impact/Asus |
Cooling | 360EK extreme rad+ 360$EK slim all push, cpu ek suprim Gpu full cover all EK |
Memory | Gskill Trident Z 3900cas18 32Gb in four sticks./16Gb/16GB |
Video Card(s) | Asus tuf RX7900XT /Rtx 2060 |
Storage | Silicon power 2TB nvme/8Tb external/1Tb samsung Evo nvme 2Tb sata ssd/1Tb nvme |
Display(s) | Samsung UAE28"850R 4k freesync.dell shiter |
Case | Lianli 011 dynamic/strix scar2 |
Audio Device(s) | Xfi creative 7.1 on board ,Yamaha dts av setup, corsair void pro headset |
Power Supply | corsair 1200Hxi/Asus stock |
Mouse | Roccat Kova/ Logitech G wireless |
Keyboard | Roccat Aimo 120 |
VR HMD | Oculus rift |
Software | Win 10 Pro |
Benchmark Scores | laptop Timespy 6506 |
System Name | Burning a hole through my wallet |
Processor | 3700X |
Motherboard | Maximus 8 Hero |
Cooling | Custom loop (EK Extreme 360 Rad, Supremacy evo w/AM4 bracket) |
Memory | 2x16 Corsair Vengeance Pro RGB @3200MHz |
Video Card(s) | EVGA 2080s hybrid |
Storage | 960 Evo, 660p, P1, BX500, 2XWD Black, Ironwolf Proo |
Display(s) | Predator 27" 4k 144hz HDR |
Case | NZXT h700i |
Power Supply | EVGA G3 850 |
Mouse | Logitech G502 hero |
Keyboard | Drop ALT W/holypanda switches |
Software | Win 10 Pro 64, Ubuntu 20.04, Manjaro (latest) |
Welcome, can you describe a little more about what you are doing this happens (are you at the desktop, etc.) I know that fx series processors had temperature sensor issues.Ive recently put in a amd fx 8370 and my temps are hiting 60 to 67 with in minutes i have good air flow
When i am at the desktop the temp stays around 34-40 but as soon as i play a game it jumps to 60+ and i use easytune and msi afterburner to see tempsWelcome, can you describe a little more about what you are doing this happens (are you at the desktop, etc.) I know that fx series processors had temperature sensor issues.
System Name | Corsair 900D |
Processor | FX8350 |
Motherboard | Asus Crosshair V |
Cooling | Corsair H110I |
Memory | 16GB Corsair Vengeance |
Video Card(s) | Asus GTX1080 |
Storage | 2x 500GB 1x 1TB WD Green |
Display(s) | Acer 24" 1080p / HP 27" 1080p LED |
Case | Corsair 900D |
Audio Device(s) | Sound Blaster X-Fi (Built in/Mobo) - Xonar Sound Card |
Power Supply | Enermax 1020Watt |
Mouse | Logitech Something Whatever |
Keyboard | Logtich G910 |
Software | Windows 10 |
Processor | Ryzen 2600 |
Motherboard | X470 Tachi Ultimate |
Cooling | AM3+ Wraith CPU cooler |
Memory | C.R.S. |
Video Card(s) | GTX 970 |
Software | Linux Peppermint 10 |
Benchmark Scores | Never high enough |
I got it to stay around 55-60c is that still to hot i used articsilver 5 past and i have a master cooler hyper 2121. Are you talking Celsius or Fahrenheit?
2. Are you Overclocked?
3. Is the CPU Fan fully seated and did you use enough thermal paste?
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Ive got a gigabyte 78lmt usb3 motherbordYou need to provide complete system specs so that we can help you.
Under Gaming and my cpu being heavy OC it touches around 55.
Worst case is 70-75 for testing with blender.
My cpu voltage moves from 1.3 to 1.4 and i reseat my heatsink and used artic silver 5 got the temp down to 55-63Check what volts its pulling and reseat the heatsink as first port of calls checks
System Name | Moving into the mobile space |
Processor | 7940HS |
Motherboard | HP trash |
Cooling | HP trash |
Memory | 2x8GB |
Video Card(s) | 4070 mobile |
Storage | 512GB+2TB NVME |
Display(s) | some 165hz thing that isn't as nice as it sounded |
Sounds like normal temps to me.
I pull my cpu out and reapplied thermal paste earlier today another question does thermal paste go bad ? I have not done anything in biosYeah that mobo just barely cuts the mustard for that cpu for phases (needs active direct cooling) the evo cooler, has gotten long in the tooth. You may want to pull the cooler off and ensure there is no plastic strip on the base, clean cpu and heatsink off and reapply thermal compound. Ensure you have clean cable routing, nothing obstructing the fans. Make sure the fans flow path are correct, front and bottom are intake, top and back are exhaust. The biggest factor in any system running cool is the ambient temperature, aka room temperature, the cooler the air the cooler the system is overall.
1.33750 is pretty default for that cpu, have you set anything in the bios/uefi of the motherboard?
Processor | AMD Ryzen 5 1600 |
Motherboard | ASRock AB350 Pro4 |
Cooling | Cryorig H7 via Noctua NF-F12 |
Memory | Crucial Ballistix Sport LT white 2x8GB, DDR4-2400 |
Video Card(s) | Gigabyte R9 390 G1 Gaming via Arctic Accelero Xtreme III |
Storage | Samsung 840 250GB (OS), Crucial MX300 750GB |
Display(s) | Samsung 40" LED 1080p TV |
Case | Fractal Design Define S - Front: 3x Noctua NF-P14s redux-1500, Back: Noctua NF-P14s redux-1500 |
Audio Device(s) | onboard |
Power Supply | Corsair Vengeance 650M |
Software | Windows 10 Home |
If thats the stock heat sink and fan your fine there then.My cpu voltage moves from 1.3 to 1.4 and i reseat my heatsink and used artic silver 5 got the temp down to 55-63
System Name | AlderLake |
Processor | Intel i7 12700K P-Cores @ 5Ghz |
Motherboard | Gigabyte Z690 Aorus Master |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p |
Case | Be quiet! Silent Base 600 - Window |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W |
Mouse | Logitech MX Anywhere 2 Laser wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless |
Software | Windows 11 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
System Name | Good enough |
Processor | AMD Ryzen R9 7900 - Alphacool Eisblock XPX Aurora Edge |
Motherboard | ASRock B650 Pro RS |
Cooling | 2x 360mm NexXxoS ST30 X-Flow, 1x 360mm NexXxoS ST30, 1x 240mm NexXxoS ST30 |
Memory | 32GB - FURY Beast RGB 5600 Mhz |
Video Card(s) | Sapphire RX 7900 XT - Alphacool Eisblock Aurora |
Storage | 1x Kingston KC3000 1TB 1x Kingston A2000 1TB, 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB |
Display(s) | LG UltraGear 32GN650-B + 4K Samsung TV |
Case | Phanteks NV7 |
Power Supply | GPS-750C |
Processor | Intel Core i7 10850K@5.2GHz |
Motherboard | AsRock Z470 Taichi |
Cooling | Corsair H115i Pro w/ Noctua NF-A14 Fans |
Memory | 32GB DDR4-3600 |
Video Card(s) | RTX 2070 Super |
Storage | 500GB SX8200 Pro + 8TB with 1TB SSD Cache |
Display(s) | Acer Nitro VG280K 4K 28" |
Case | Fractal Design Define S |
Audio Device(s) | Onboard is good enough for me |
Power Supply | eVGA SuperNOVA 1000w G3 |
Software | Windows 10 Pro x64 |
System Name | Main/DC |
Processor | i7-3770K/i7-2600K |
Motherboard | MSI Z77A-GD55/GA-P67A-UD4-B3 |
Cooling | Phanteks PH-TC14CS/H80 |
Memory | Crucial Ballistix Sport 16GB (2 x 8GB) LP /4GB Kingston DDR3 1600 |
Video Card(s) | Asus GTX 660 Ti/MSI HD7770 |
Storage | Crucial MX100 256GB/120GB Samsung 830 & Seagate 2TB(died) |
Display(s) | Asus 24' LED/Samsung SyncMaster B1940 |
Case | P100/Antec P280 It's huge! |
Audio Device(s) | on board |
Power Supply | SeaSonic SS-660XP2/Seasonic SS-760XP2 |
Software | Win 7 Home Premiun 64 Bit |
No, but it does dry out a bit and get harder to use. That can also cause too much TIM to stay between the CPU and cooler, which makes cooling performance worse. You do need to watch your temps over time because TIM does need to be replaced from time to time, but that's normally years down the road.does thermal paste go bad ?
