- Oct 9, 2007
- 47,680 (7.42/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
AMD's upcoming Radeon RX 5600 XT graphics card features the same exact stream processor count as the $350 RX 5700, according to a leaked specs sheet of a an AIB partner's custom-design graphics card. With a stream processor count of 2,304, it's safe to assume that the RX 5600 XT is based on the same 7 nm "Navi 10" silicon as the RX 5700 series. What set the RX 5600 XT apart from the RX 5700, besides lower clock-speeds, is the memory subsystem, which is severely stripped down. The Radeon RX 5600 XT will be equipped with 6 GB of GDDR6 memory across a 192-bit wide memory interface. What's more, the memory ticks at 12 Gbps, compared to 14 Gbps on the RX 5700 series.
With these specs, the RX 5600 XT has 288 GB/s of memory bandwidth at its disposal, same as NVIDIA's GeForce GTX 1660 Ti. In contrast, with 8 GB of 256-bit GDDR6 running at 14 Gbps, the RX 5700 enjoys 448 GB/s. The specs sheet suggests that AMD has also dialed down the engine clock-speeds (GPU clocks) a bit, with up to 1620 MHz boost, up to 1460 MHz gaming, and 1235 MHz base. With these specs, it's highly likely that the RX 5600 XT outperforms the GTX 1660 Ti and gets close to the RTX 2060. It all boils down to pricing. The RX 5500 XT is a decent GTX 1650-series alternative with a lukewarm price thanks to NVIDIA's aggressive product-stack management by getting its partners to lower prices of the GTX 1660 and GTX 1660 Super. It would be interesting to see if AMD can outfox NVIDIA in the sub-$300 market.
