AMD Readying Radeon HD 4790 Based on RV790
47,655 (7.44/day)
AMD is preparing yet another performance-mainstream Radeon HD 4000 series SKU. The Radeon HD 4790 finds lineage from the Radeon HD 4890, currently AMD's fastest GPU. The RV790 GPU will be given a new set of specifications and memory configuration, to yield an SKU that performs better than the Radeon HD 4770, and slightly better than HD 4850. It beats us as to why it is positioned in the HD 4700 series, and not say "Radeon HD 4860", but we are too late to comment on that.
Specifications-wise, the RV790 core runs at 600 MHz, slightly lower than the RV770 in Radeon HD 4850 (625 MHz), but its performance increment over it comes from the use of GDDR5 memory. The GPU makes use of a 256-bit wide GDDR5 memory interface. It handles 512 MB of memory clocked at 800 MHz (3200 MHz effective). Being based on the RV790, it is pin-compatible with any existing HD 4890 PCB. Price-wise, it is expected to sit between the HD 4850 and HD 4870.
Odin Eidolon
920 (0.15/day)
Rockclimbing somewhere in Italy
Processor e6300 @ 3000, stock Volts
Motherboard msi p35 neo2-FIR
Cooling HDT-1283
Memory 2gb tracers 1066 micron d9GMH, cooled by a modded CoolIt Memory Cooler
Video Card(s) HIS 4850 ICEQ4
Storage WD Caviar 16 320gb WDAAKS + 640gb WDAAKS
Case CM RC-690 sligthly modded
Power Supply Bequiet darkpower PRO 850W (say overkill? :D)
Software kubuntu 8.10 + Windows XP, soon Windows 7 too
so its 55nm?
7,662 (1.17/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
ati is just dumping out cards
6,560 (1.01/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
swamping the market, one way to make sure you get cards sold!
47,655 (7.44/day)
Odin Eidolon
920 (0.15/day)
Cooling HDT-1283
Yes, 55 nm.
bah. i dont see much sense in this card other than that of selling out stocked chips. ATI's lineup is becoming too crowded
Cheeseball
Not a Potato
2,278 (0.38/day)
Pittsburgh, PA
System Name Titan
Storage Crucial T500 2TB x 3
Power Supply Corsair SF1000
VR HMD Meta Quest 3 512GB
So are they phasing out the HD 48xx series cards now? The performance is supposed to be between the HD 4850 and HD 4870.
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
this card really makes no sense...
is it xfireable with a 4890? :wtf:
7,238 (1.06/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Hmm. ATi is struggling with getting 40nm fabbed. It is having to create another 55nm SKU to fill the "consumer gap" in the 4770 space. The "hope"? So people think they are buying into the 47xx range of price, low power, silent, and one step quicker than a 4770. But actually, they are getting an "underperforming" 4870/4890 with similar power consumption levels.
While it might still be a good card and a good price/performance ratio, it isnt a step forward, just yet another SKU-confusion to price gouge in the retail channels where the typical consumer doesnt know sh1t.
Odin Eidolon
920 (0.15/day)
Cooling HDT-1283
5,968 (0.93/day)
New York
Processor AMD Ryzen 9 9950x / AMD Epyc 7773x
Motherboard Gigabyte B850 Gaming X/ ASROCK ROME
Cooling Be Quiet Dark Rock Pro 4(Custom) / Custom Air
Memory 64GB Crucial Pro 6400 / 384GB
Video Card(s) MSI RTX5070Ti(Temporary)/ 4X RTX3090
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
this is more than likely just to get rid of the cores that are low binned and can't run at the stock freq's of the 4890
its just a 4890 with a low core clock thats it
as a matter of fact that card is exactly the same as the Powercolor HD4890 from the looks, the PCB even has the same model number on it.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I really don't get ATi here, it seems they are trying to flood the market to make up for their failure to successfully get 40nm out in reasonable quantities.
This card just adds more confusion to the mix. It seems to me like ATi wanted to use 40nm for the HD4770 series, but because they couldn't get enough 40nm chips, they have instead used their other higher end chips to make the cards. That doesn't make sense to me really, why not keep the RV790/770 chips named HD4800, and forget about HD4770.
We still don't even know what the HD4730 can be used with in Crossfire...
Why not use those cores in the HD4870s then?
Kitkat
768 (0.13/day)
k so im officialy ready to admit this is too many cards. gettin silly. I also dont think it has anything to do with consummer gaps lol just alot of cards.
47,655 (7.44/day)
TSMC, not specifically AMD. They've got some serious fab issues, and both AMD and NVIDIA are looking for potential alternatives if TSMC gives them a hand when it's time for their 40 nm GPUs.
5,968 (0.93/day)
New York
they probably don't want to get it all mixed up and cause confusion, but then again those cores might not even clock to 4870 frequencies either efficiently
Its not that many cards I mean theres only gonna be 12 HD4XXX cards with this, but including nvidia's nearly 20 current cards now I still say not really
308 (0.04/day)
Chicago
System Name Big Beast
Processor AMD Ryzen 7 9800x3D
Motherboard Asus ROG Strix X670E-I Gaming Wifi
Cooling Noctua NH-U12a
Memory Team Group 48GB 6000MHz
Video Card(s) AMD Radeon 7900XTX
Storage Lot's of it
Display(s) Samsung CHG70 27"
Case ASUS Prime AP201
Power Supply 850watt
Software Windows 11 Professional x64
imo this is stupid, and i call shens....until i see a real press release.
leonard_222003
241 (0.03/day)
System Name Home
Processor Q6600 @ 3300
Motherboard Gigabyte p31 ds3l
Cooling TRUE Intel Edition
Memory 4 gb x 800 mhz
Video Card(s) Asus GTX 560
Storage WD 1x250 gb Seagate 2x 1tb
Display(s) samsung T220
Case no name
Power Supply chieftec 550w
Software Windows 7 64
Strange card with a strange number , overclocked can be just as good as a 4870 , the next generation must be very good if they dump the old stock so quickly , they make me curios how fast the new generation will be to dump the 4800 series so cheap.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Using the RV790/770 in HD4700 cards adds way more confusion than simply using RV790 cores in HD4870 cards. The general user wouldn't know the difference, and the RV770 and RV790 are virtually identical. They certainly are a lot closer to eachother than they are to RV740. And if they don't clock to HD4870 speeds, put them in HD4850's then. I find it hard to believe that an RV790 couldn't at least do 625MHz. Why release a whole new card to take the place of the HD4850 instead of just using the RV790 cores in the HD4850s?
As for who has more cards in production:
ATi: 13 | nVidia: 11
HD4350 | 9300GS
HD4550 | 9400GT
HD4650 | 9500GT
HD4670 | 9600GT
HD4730 | 9600GSO
HD4770 | 9800GT
HD4790 | GTS250
HD4830 | GTX260 216
HD4850 | GTX275
HD4870 | GTX285
HD4890 | GTX295
HD4850x2 |
HD4870x2 |
I don't see where you are getting 20...
2,196 (0.34/day)
Darkness
System Name Unreal Machine IV
Processor Ryzen 7 5700X
Motherboard Asrock 570X Taichi
Cooling Noctua U9S
Memory Team UD4-4000 @4000 CL18 1:1
Video Card(s) 5600XT Red Devil
Storage Kingston SSD 240GB + WD RED 4TB + WD Blue SN 550 Nvme 1TB X3
Display(s) DELL U2417H
Case Old school Termalthake xaser III black with lots of noctua 80mm fans
Audio Device(s) Creative SB X-Fi Titanium Fatal1ty Champion + Creative Inspire t7900 7.1 + Sony MDR-1A + AKG K-240
Mouse Logitech G502 hero SE
Keyboard Logitech
Software 10 pro
Benchmark Scores Cinebench R23 Multi ~15k 4.4Ghz all core Cinebench R23 single 1.5k 4.65Ghz
I bet these will sell well and ppl will try to oc the living shit out of them...
If some finds a way to oc it to 800+ i bet the stock's will be sold out...
43,628 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
4870 replacement.
1,618 (0.27/day)
HD4350 | 9300GS
HD4550 | 9400GT
HD4650 | 9500GT
HD4670 | 9600GT
HD4730 | 9600GSO
HD4770 | 9800GT
HD4790 | GTS250
HD4830 | GTX260 216
HD4850 | GTX275
HD4870 | GTX285
HD4890 | GTX295
HD4850x2 |
HD4870x2 |
where did 9800gtx, 9800gtx+, gtx280, gtx260 original go?
43,628 (6.36/day)
Though completely off topic:
9800GTX = No longer in production/replaced by 9800GTX+
9800GTX+ = Renamed to GTS 250
GTX260 = No longer in production/replaced by 55nm 216 shader GTX 260
GTX280 = No longer in production/replaced by GTX 285
1,901 (0.33/day)
Latvia
Processor 7700X \\ i7-8565U
Cooling Noctua DH-15
Power Supply Corsair AX860i
Keyboard Corsair K55 RGB PRO
SOOOOO.... IT has happened, card with lower "number" beats mine 4850... QQQQ :/
5,968 (0.93/day)
New York
naa i was tryin to say about 20 altogether but forgot to put it in a understandable manner:laugh:
sry for the confusing post
but I wouldn't include the 4830, or 4850x2 since ati is replacing the 4830 and they never truly supported the 4850x2 anyway
337 (0.05/day)
System Name Roxy
Processor i7 5930K @ 4.5GHz (167x27 1.35V)
Motherboard X99-A/USB3.1
Cooling Barrow Infinity Mirror, EK 45x420mm, EK X-Res w 10W DDC
Memory 2x16GB Patriot Viper 3600 @3333 16-20-20-38
Video Card(s) XFX 5700 XT Thicc III Ultra
Storage Sabrent Rocket 2TB, 4TB WD Mechanical
Display(s) Acer XZ321Q (144Mhz Freesync Curved 32" 1080p)
Case Modded Cosmos-S Red, Tempered Glass Window, Full Frontal Mesh, Black interior
Power Supply Corsair RM 850x White
Mouse Logitech G403
Keyboard CM Storm QuickFire TK
Benchmark Scores https://valid.x86.fr/e5uz5f
So this is the 4890 512MB
