AMD users how high can you get your HT speed
p_o_s_pc
F@H&WCG addict
13,006 (1.97/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
How high can you get your HT speed? Give a CPU-Z SS or link. Give socket type, chipset,volts, chipset cooling...
I will start...
1596
Chip-set N-force 430/Geforce 6100
chip-set cooling- stock
Chip-set volts- stock
Lets see... the highest I have gone is 5 x 270 which is... 1350...
Stupid intel users... :D
whats a HT?
Hypertransport. Much better than Intel's FSB tech. It's serial based. At any rate reason why he's asking is because the rated HT speeds usually don't exceed 1000 mhz when overclocking for stability reasons. HT will become unstable, and I guess he wants to know the max.
It's a contest in which you go as high as you can and see if you can boot!
I feel a cpu-z pic isn't nescessare as I pretty much run mine at 1050MHz. 13x210FSB for 2730MHz.
What are the Intel users doing here?
Thanks...but i was talking more about IRA. Also would anyone like to comment on my HT overclock?
Ohh, lol. Btw...from what I see...your HTT is very nice....570mhz above stock at stock volts. Any noticeable performance gains?
:( im hurt p_o_s
no i didn't notice any. Maybe i should set it back to that speed again so i can run super PI to see how it does. I will post back in a few with stockish HT and overclocked.I will try to get about same CPU speed.
If you overvolt the HT link can you get it higher than normal? Mine gets unstable around 1100. I believe the voltage is 1.2
Just to let you Intel users know, Intel's upcoming processors will finally have an on-chip memory controller and HTT. Though Intel calls it something else.
Yes you can! I would check around to see what others with your board have gotten first though. Or, just do it a little at a time and make sure your nb / sb temps are good.
CSI and Nehlam will debut with it, however it's most likely there will be two versions, one with CSI and on-chip memory controller, and one with the fsb approach. Well at least from what I read anyways.
I am back my stockish and overclocked super PI
stock-ish
overclocked
also keep in mind the ram speed.
How do you overclock CSI?
I think Intel refrained from adding the controller to thier core 2's probablly because of heat issues. The smaller die-shrink probablly solves that problem. Also won't have to worry about gynormous NB cooling anymore.
fo rly?
