AMD X570 Chipset and Mobo Cooling Solutions
INSTG8R
Vanguard Beta Tester
7,966 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Okay so I added my PCH to my main monitoring screen max temp is 55C on my X570S which is 7C cooler than my previous X570 averaged with the fan set to its max performance.
freeagent
7,541 (3.68/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Man, those are crazy high temps. I rarely see my chipset temp go over 40, or under 32. But obviously a big difference between x570 and b550..
INSTG8R
7,966 (1.12/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Well it controls the 2nd 4.0 NVME port I have my game drive on it so it’s pretty much always being used.
freeagent
7,541 (3.68/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Yup I hear you, that chipset is doing a lot more than mine, Gen 3 for me.. but of course that comes at a cost.. :D
870 (0.56/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
That's why I lowered my bios settings to pcie version 1. it lowers the temp some 15C degree.
At the moment the temperatures are looking fine. (temp3)
INSTG8R
7,966 (1.12/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Makes sense but I’m running a 4.0 NVME in the slot so I’d just be hobbling it. I‘m fine with 55C considering.
870 (0.56/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Even at pcie-1 settings, the first pci slot which your nvme sits in, will work in pci-4 standart. Because the first pci slot is "always" version 4 and uses CPU's pci lane.
INSTG8R
7,966 (1.12/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Correct. I have a PCI3 NVME in that slot. That still doesn’t change anything. Slot 2 4.0 is controlled by the chipset or anything to do with chipset temps.
870 (0.56/day)
Turkey
System Name MSI-MEG
Memory 32 GB
This is the MSI Flagship motherboard "Godlike". While testing it reaches up to 63 degrees Celcius.
870 (0.56/day)
Turkey
System Name MSI-MEG
Memory 32 GB
@kapone32 Enough is enough I will buy copper shim to put on the bare chipset itself between the heatsink. I can't using it with default settings.
7,939 (3.15/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Yep I hear you. I ended up with a 40mm Noctua and the highest it goes now is 70 C. That keeps me happy.
