An overheating issue?
Hun
15 (0.00/day)
Processor AMD Athlon X2 3600+
Motherboard Gygabyte GA-MA78GM-S2H
Cooling Spire CPU heatsink
Memory Corsair Dominator
Video Card(s) ATI Radeon 4830
Storage WD caviar 200GB
Display(s) NEC MultiSync FE770
Case Víglen
Audio Device(s) Creative Live! 5.1
Power Supply FSP 275W
Software Win7
Hi!
Can anyone tell me whether the following image shows faults caused by overheating?
http://n2.vatera.hu/photos/f6/92/a995_2_big.jpg
It is an HD4830.
Is it possible that replacing the faulty cooler solves this problem? (this happened once, then I checked the fan, it wasn't moving, I took this photo and immediatelly swiched off the rig).
Some strange artifacts you have there. I'd say it's safe to assume that the card will die eventually, though you can try baking it, results can vary.
Changing the cooler might help but i wouldn't count on it.
It could very well be a heat issue. If the fan isn't working, don't use the card.
I have a similar issue where my image shifts and mirrors, upon checking it was high temps on the MemIO sensor of the GPU, so I'll be another one to say it's related to heat.
