snbase
- Sep 20, 2008
- 26 (0.00/day)
- Ohio
Processor | AMD Athlon 64 X2 Dual-Core Processor 5000+ AM2 |
Motherboard | Gigabyte GA-M61p-S3 |
Cooling | Zalman 9500LED |
Memory | Patriot Extreme Performance 2GB |
Video Card(s) | Sapphire ATI HD 3870 |
Storage | WD Sata 750gb |
Case | Antec 900 |
Power Supply | CORSAIR 520 Watt HX Series SLI Certified Power Supply |
I was wondering what the best fan controller would be for the Antec 900 case that would fit into a 5.25" bay. I have the 4 stock Antec fans which are 4 pin molex and a Zalman 9500 Heatsink. The stock fans each have there own speed controller, but i want to set it up so i can control them all with a fan controller. Do i need to get adapters for all the fans?
This is what i was thinking...
Scythe Fan Controller
Scythe KM01-BK "KAZE MASTER" 5.25" Bay Fan Control...
4-Pin Molex to 3-Pin Fan Power Adapter Cable
http://www.svc.com/4to3ad.html
Also If i get the 3 pin adapters for the 4 pin molex fans will i be able to control the rpms on the fan controller??
