Hi all,
Finally decided to make an account here after couple years of tinkering and lurking around the forum following a lot of posts by 8750h users and the notorious Throttlestop uncle :=)
History/current setup:
I'm using MSI GE75 8SF I7 8750h model laptop since ~2019/20.
Reason for all this tinkering is the poor factory default thermals, dissapointing performance, poor airflow design for a gaming laptop and paste quality/method used by MSI as most of us have encountered.
I Have done a re-paste by some random pc shop in Australia in the past because while I attempted a re-paste myself, I ended up bending one of the heat-sink pipes slightly by accident(happened very easily due to VRAM/CPU components being stuck hard on the board from excessive ammount of paste they used. Mby I should have used a heat gun...) which then led me to buy a complete new cooling unit(heatsink + fans) because i wouldn't take a chance that even a minor bend would affect my output performance.
Still havent figured out whats the best method for best cooling method of CPU/VRAM components(pads, K5 pro, MX6, Kryonaut). Im considering an attempt with MX6 because manufacturer claims that its suitable for these situations. Quess i have to start testing a bit more because somehow i doubt that K5 Pro is actually the best option for low temps(like some people on youtube claim it to be).
Not a big fan of liquid metal btw, would like to point that out as well.
Current Idle temps(while under light load like just browsing the web/writing this article) with below Throttlestop config:
*48(avg) 71(max)
*38(avg)-50(max) max fan
My goal is to get 90c or less on the CPU while playing CS2(Counter Strike 2) getting around 250fps(or more if lucky because my monitor goes up to 360hz).
With current settings im hitting around 96-98c staying around 200-300fps which isn't really ideal in my mind while hoping to have this unit around for at-least couple more years...
Laptop sits on a glass table in cool ambient settings(currently located in Northern Europe and its pretty much already winter).
Not using external cooler or cooling pad currently(worth getting both of em? Like this one here?)
Ive also stocked up on 0.5mm/1mm/1.5mm pads + Arctic MX-6(To consider another re-paste cause last time was done over a year ago)
Anyways, heres my current Throttlestop settings while running R15(max fan):
gyazo.com
gyazo.com
gyazo.com
gyazo.com
Is there anything i could try to improve this at all?
I used to have older version of Throttlestop, so unfortunately im not quite sure if these are optimal/ideal settings
Thanks !
edit: Also would like to point out that im running cs2 1080p on lowest settings for competitive and ive also installed process lasso probalance enabled
*48(avg) 71(max)
Gyazo
Gyazo
Gyazo
Gyazo
Thanks !
