Asrock z77 STUCK IN BOOT LOOP!
110 (0.02/day)
New York
System Name Storm Trooper
Processor Intel Core i7-3770K Ivy Bridge 3.5GHz 4.5 GHz O.C)
Motherboard ASUS Maximus V FORMULA z77
Cooling Corsair H100i Hydro Series
Memory G.SKILL Sniper Series 16gb
Video Card(s) Asus GeForce GTX TITAN 6GB
Storage 120gb Samsung 840 Series/ 10000rpm Western Digital VelociRaptor 600gb
Display(s) 2 x ASUS Black 23.6" 5ms HDMI Full 1080P
Case COOLER MASTER CM Storm Series Trooper
Audio Device(s) SupremeFX IV
Power Supply Corsair HX Series HX850
Software Windows 7 Home Premium
I recently purchased parts for a new build for a friend and all seemed well everything went together fine.I go to start up the PC and it fires up, for about 3 second, shuts down and starts back up again. It's stuck in a boot loop. I was told to try and install the latest version of the bios but the only problem here is i can't reach the bios due to the boot loop.
I've tried to troubleshoot a few things here.
The RAM is Crucial Ballistix 2x 4gb 1866.
-I made sure the CPU fan was properly installed.
-Tried booting it without any RAM and it works fine and stays running!
-Tried booting it with one stick of RAM, it didn't Work
-Tried booting it with the motherboard outside of the case.
-I even tried booting it with my RAM (Gskill 1866) It didn't work.
-Tried the RAM in my PC, It works
-Made sure everything was wired proper.
All this leads me to believe that there's nothing wrong with any of the parts it just needs some tinkering with i don't want to have to send it back because that's a process and my friend is waiting for it. Also I refuse to believe something is wrong with the cpu considering it starts up when the RAM isn't in it and runs fine.
If you have any knowledge of the situation and can help that would greatly appreciated. You guys are the best!
533 (0.12/day)
Processor i7 6900k @ 4.3GHZ
Motherboard MSI X99A Godlike Gaming Carbon
Cooling CPU/GPU loop with 480mm and 360mm radiators
Memory 32GB Corsair Dominator 3000MHz C15
Video Card(s) 2x EVGA 1080 SC ACX @ 1830/1330
Storage Samsung 950 Pro M.2 512GB, WD 2TB Black HDD
Case Corsair 900D
Power Supply EVGA 850W Gold 80 plus PSU
Hey, I was having this EXACT issue and I know how frustrating it is :(
A few things that you can do are:
1. Try to boot up your system without RAM, you should normally hear a beep.
2. Grab a paperclip and bend it in half, grab the power connector for your motherboard and then stick one end into any green wire and one end into any black. If your fans stay running (Assuming their connected to the PSU) then it's likely a motherboard issue.
3. What code is shown on your POST LED? If there is nothing, then once again, it's likely a motherboard issue.
When I tested this, I got no beep, the fans would stay running with the paperclip in and the POST LED showed no code; this led me to understand that my motherboard was broken, and I just had it replaced. When I had my motherboard replaced, it wouldn't boot up and the POST LED showed 00, which turned out to be because of an outdated bios not recognizing my new CPU.
It may also be helpful if you post the PC specs. Good luck and hope you sort it out :(
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
To rule anything out, you should remove motherboard from case and try on cardboard. There could be contact on back of board to case, shorting it out.
Just to add to Paladone's excellent explanation. If it starts with the paperclip and nothing else is the culprit, then it is most likely the 5v return on the motherboard. Had the exact same thing happen to me, and that's what the culprit was, so board was RMA'd.
Also, if you have a spare PSU, try to hook just the two power cords to board from outside with just cpu and heatsink, and one stick ram. This will rule out the PSU being bad and most likely confirm the motherboard being bad.
95Viper
Super Moderator
13,313 (2.20/day)
It may help if you post what parts you replaced or used in this build.
If you removed the processor. you may want to check for bent pins, foreign objects, and check that the heatsink is not over tightened.
Disconnect any, and all, cards, drives (hard, usb, ssd, optical, etc.), mouse, keyboard, card readers... then try it.
If it has a reset CMOS header... make sure the jumper is in the correct position.
Also, try removing the CMOS battery and reset the bios.
1,113 (0.21/day)
System Name Desktop
Processor Intel Core i5 6600k
Motherboard Asus Z170-E
Cooling Cooler Master 212 Evo
Memory 16 GB Ballistix DDR4 2400
Video Card(s) NVIDIA Geforce GTX 1060
Storage 120GB OCZ Vector SSD & 1TB Western Digital Black
Case Rosewill
Audio Device(s) N/A
Power Supply 630w Raidmax Hybrid 2 RX-630SS
Mouse Logitech G402
Keyboard Rosewill Mechanical
You stated that you tried putting the RAM from your computer in and then it worked. What is the speed and brand of that RAM? Also as suggested above I would recommend that you check all stand offs. When I first built my rig I had the same issue and for like two days I was dumb founded as to what the problem was. Turns out I forgot to put the stand offs in so it was grounding out, more instantly than yours though lol
5,048 (0.91/day)
València la Vella
no,not. ^
Suspect 1 = RAM
(hardware incompatible or settings)
1,113 (0.21/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
That's why I first asked about his ram....
4,013 (0.70/day)
Sounds like RAM compatibility to me. Did you check the memory support list before buying? Some will scoff at the idea, but sometimes it really matters.
If not that, try different slots, you said you tried one stick, but didn't mention every slot. I'm still guessing compatibility, though.
4,380 (0.92/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
I am convinced of two things. One, won't post because of memory. Either not the right stuff or not secured properly. The other is not getting the cpu properly inserted, or heatsink not right...Sounds more like a memory issue, you have.
cadaveca
My name is Dave
17,238 (2.48/day)
Be aware that some ASRock boards don't like some PSUs which leads to similar behavior, but yeah, I'd look at CPU sitting off a bit in the socket, or memory like Arjai suggests.
Since you tried the ram in another board, that should be fine.
I'd try re-mounting the chip in the socket, re-doing the thermal paste, and then trying again. If that fails, then I'd try PSU, or look at the board/CPU.
I'd also clear the CMOS overnight.
63 (0.01/day)
Flag
System Name Molotov Launcher | Mafia BOSS
Processor i7 4960X All GO | AMD FX4100 Black Edition
Motherboard Rampage IV Gene | Asus M5A 78L-M LX Plus
Cooling Intel Liquid Cooling | AMD Cool and Quiet
Memory 8GB HyperX Beast 2.4 | 8GB HyperX 1866
Video Card(s) GTX690 (Morte) | Asus GTX660 DirectCU II
Storage 4x Crucial M500 240GB | 2x 500GB WD
Display(s) UNIVERSAL EXPAND | Soup Nazi Prosperity
Case Corsair Carbide 540 Air | GMC R4 Bulldozer White
Audio Device(s) Auzentech Bravura 7.1 + Z906 | SB VX Audio Processor HD 7.1
Power Supply 1000W (DUEL Blower) | 750W Resonating Compressor
Software Windows 7 Professional x64 | Windows 7 Home Premium x64
Benchmark Scores Benchmarks: "Vantage Killing It For Years" "3DMark11": Sank The "Titanic".
First thought from me was that it may be an electrical problem perhaps interferance when you mentioned you took out the case to seee if it is discharging on a MB spacer. I did that too. on mine. Ivy Bridge E doesn't work on Intel specific X79 MB was the problem. when I got an updated Asus Gene and chucked it in to get fixed it worked without any disfuction at all. I got that MB from America land of the free and prosperity. I never returned it and have no use for it. the Asus gene runs well enough for both of them.
63 (0.01/day)
Flag
It may sound strange and if you had tried it you will never know.
2,381 (0.49/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
5 (0.00/day)
Processor Intel Core i5-3550 Ivy Bridge 3.3GHz (3.7GHz Turbo)
Motherboard Gigabyte-Z77-D3H
Cooling Cooler Master Hyper 212 Hyper
Memory CORSAIR Vengeance 2x4GB DDR3 SDRAM DDR3 1600
Video Card(s) Gigabyte R7 250 1GB GDDR5, Powercolor 7870 Ghz edition
Storage Samsung 840 Pro 128gb SATA 3
Display(s) Dell 2408WFP 24" monitor
Case Cooler Master
Power Supply Corsair 550VX
Software Win 8.1 Pro x64
I also think it could be the ram. I used a lot of Crucial ram products and I have had to RMA quite a few. If the ram doesn't work try resetting your CMOS via jumper or taking the battery out for a few minutes.
