ATI tools problem.??
Bytor
1,051 (0.16/day)
System Name "The Dark Spider"
Processor AMD Phenom 9850 @ 3.0
Motherboard Asus M3A79-T
Cooling Water: CPU and GPU's, 2 pumps, 2 BIX Rads, D-Tek Fuzion v1, 2 Swiftech MCW60
Memory 4 gigs Crucial Balistix Tracers (1066 @ 1256)
Video Card(s) Sapphire 4870x2
Storage WD SATA 640 Gig HDD
Display(s) Acer 24" beast...
Case Modded Rocketfish
Audio Device(s) Onboard (only use head phones)
Power Supply 700 watt
Software a bunch
Benchmark Scores 3D Mark 06: 9859 on 2-X1950 pro's Xfire 3D Mark 06: 12794 on 1-3870 3D Mark 06: 16484 Xfire
I installed my new M3A32-MVP MB this weekend. When I opened ATI tool it shows no core or memory clock speeds. When I click to find the max clock a window opens that reads.
"the video card you selected for overclocking in ati tool does not seem to be used by windows.
Visual testing has been disabled.
To fix this, go to display properties, settings, and enable the monitor output of the card."
Now I went and tried to do as it says. But how do you enable the monitor output of the card? I couldn't find anything like that.
I hope someone out there can help with this. Its driving me nuts...
Thanks
Bytor
what version of atitool are you using? when i had my crossfire 1950's atitool picked them up fine.
Thanks for the reply...
I had .26 installed first. Then tried .27 and the same problem. It worked great on my Asus M2R32-MVP MB. But not on this M3A32-MVP. Not sure if its the PCI-e 2.0 being the problem or not. A pair of Visiontek 3870's should be here this week and I'll see if it still does it.
Found a post with the same problem and there fix was the same.
Ok its working fine now. Uninstalled the one I had and installed .27 Beta 3 and it worked... yyyeeehhhaaaa
Wonder if the older versions dont work with PCI-E 2.0. Dont know, but its working now....
TY tech power up and Random Murderer.
Can you link the site you got the beta from?
Amazingly quick! Thanks!
You're welcome. If you change the 3 to a 4 in the download link you will get the beta 4, which only helps with the x1950 and hd2900.
