ATI X1600Pro with Cell factor
powerup
70 (0.01/day)
Well I downloaded Cell factor today, and put in that enablephisx=disable to make it run. So the games starts and it loads than I get around 20 frames walk around than the games starts to lag big time. from 20 frames to 1 frame per second. How can this be? I ran the game @ 320x240 and it ran 90 frames than it went back to 1 frame in 3 seconds when moving around..
Do you think its a ATI bug? The drivers I use are 6.8 and every game runs faster with those drivers. Please help!
http://video.google.ca/videoplay?docid=-5007797965290842682
do you have a PPU card?
NO, you can use your CPU do that, but I guess becuase my cpu is older it has to go though the PhysX's part and that makes my system lag
you put that in there to start the game, without that in here the same would start and say "No Physx card detected" and it will exit
do see that piece of cloth? or the things infront of the tunnel? without a phys-X card, it will slow from almost any fps to almost none when those are rendered. try turning those off
