Audio cut out problems with a ht setup
105 (0.02/day)
Indiana
System Name Home built
Processor I5-2500K
Motherboard MSI P67A-GD65
Cooling Corsair H50
Memory 8-Gigs Patriot Sector 5 PC3-12800/1600mhz
Video Card(s) EVGA Superclocked GTX770 2gb sli
Storage OCZ Agility 3-60gig/WD 1TB Black
Display(s) AOC 28"
Case Antec 900-II
Power Supply Corsair 1000 watt
I'm having problems with my setup losing sound every 15-30 seconds for a second or 2 then coming back on. The receiver is a Yamaha RX‑V671 and I'm using a Amazon Fire TV with Plex, when the sound cuts out the speaker lights on the front display of the receiver dissappear when the audio goes out then comes back on with the sound? Same thing happens with my HTPC? I figured maybe the receiver was going out so I just picked up a new Yamaha Aventage RX-A660BL and it's doing the same thing! I did just hook up a blu-ray player and the sound is fine with it, so I guess the old receiver wasn't the problem......but no-go with either the fire tv and htpc. Any ideas on what it could be? Or what I can do to try and figure this out? I'm ready to throw everything out the window! Thanks in advance!
1,778 (0.32/day)
Little Rock, AR
System Name Gamer
Processor AMD Ryzen 3700x
Motherboard AsRock B550 Phantom Gaming ITX/AX
Memory 32GB
Video Card(s) ASRock Radeon RX 6800 XT Phantom Gaming D
Case Phanteks Eclipse P200A D-RGB
Power Supply 800w CM
Mouse Corsair M65 Pro
Something wrong with your power maybe? Plug the receiver into a different outlet.
INSTG8R
Vanguard Beta Tester
7,966 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
I got a firmware update for mine today. The notes were just "Fix drop off problems" RX-V479
1,181 (0.18/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
You are using HDMI to connect the PC to the receiver?
Might be the audio stream encoding is changing which causes the receiver to cut out for a second. It would happen to me when windows would switch from 2 channel PCM to 8 channel then back again. Super annoying. Cant remember how I fixed it...maybe a driver update or the audio settings.
Have you played with these settings?
105 (0.02/day)
Indiana
Processor I5-2500K
Cooling Corsair H50
Display(s) AOC 28"
Case Antec 900-II
Wow! Wasn't expecting help so fast :) Gave up on it for today since I have to sleep so I can work tonight but will mess with it in the morning and try some of your ideas then and will post the results. Thanks
AsRock
TPU addict
18,876 (3.07/day)
UK\USA
Cooling D15
Audio Device(s) Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti
You have any heavy usage appliances on the same circuit ?. Have you tried turning off HDMI control and things like ARC ?.
105 (0.02/day)
Indiana
Processor I5-2500K
Cooling Corsair H50
Display(s) AOC 28"
Case Antec 900-II
Found out that it must've been something to do with Plex "transcoding" audio. Setup Kodi on my server and HTPC nad now it's fine, and I get true surround DTS audio which Plex didn't do. Thanks for the suggestions anyway.
