OrbitzXT
- Mar 22, 2007
- 1,969 (0.29/day)
- New York City
System Name | AX-01 |
Processor | Intel Core i5-2500K @3.7 GHz |
Motherboard | ASRock Z68 Extreme3 Gen3 |
Cooling | Zalman 9700 |
Memory | Kingston HyperX T1 Series 8GB DDR3 1600 MHZ |
Video Card(s) | GTX 590 |
Storage | Intel X25-M |
Display(s) | 42" Samsung LED HDTV |
Case | Antec Twelve Hundred |
Audio Device(s) | HT | OMEGA STRIKER 7.1 |
Power Supply | Kingwin 1000W |
Software | Windows 7 64-Bit |
I had wanted to upgrade the computers at my job's office to Windows 7, though I've run into a bit of a brick wall at the moment. They're a contracting business and use AutoCAD a lot, AutoCAD 2002 to be precise. There seems to be some very strange behavior with AutoCAD in Windows 7.
When first installed, it works perfectly fine right off the bat without having to do anything. If you reboot the computer however, everytime you open the program you get a
and the program closes. There is a strange work around though. Double click an AutoCAD drawing created in Windows XP, it will open it without any issues. I feel it would be ridiculous to tell my bosses though to open one drawing just to open another. They're going to just want to double click whatever they have to to open it.
The other problem is they're stuck on AutoCAD 2002. It's not a matter of money upgrading to a later version, they've looked at trials of these versions and feel lost in them. 2002 does what they need and they'd prefer to stick with it out of comfort.
I've been told running XP in a virtual machine on Windows 7 makes AutoCAD 2002 work, but to be honest I'm not quite sure how to do that.
Ideally I'd like to get 2002 working on Windows 7, they wanted to upgrade from XP but they also want their AutoCAD 02. I'm the kind of person who hates disappointing people. Any thoughts of what I can do? If you google "Autocad 2002 Windows 7 Fatal Error" you can see it's a very common issue. Unless I've looked over it, I haven't found a good solution.
Edit: I've tried XP Compatibility mode, Run as Admin, and I installed a 32 bit copy of Windows 7 Ultimate.
FATAL ERROR: Unhandled e06d7363h Exception at 7668b727h
