- May 29, 2017
- 944 (0.32/day)
- Latvia
Processor | AMD Ryzen™ 7 7700 |
Motherboard | ASRock B650 PRO RS |
Cooling | Thermalright Peerless Assassin 120 SE + Arctic P12 |
Memory | XPG Lancer Blade 6000Mhz CL30 2x16GB |
Video Card(s) | ASUS Prime Radeon™ RX 9070 XT OC Edition |
Storage | Lexar NM790 2TB + Lexar NM790 2TB |
Display(s) | HP X34 UltraWide IPS 165Hz |
Case | Lian Li Lancool 207 + Arctic P12/14 |
Audio Device(s) | Airpulse A100 + SW8 |
Power Supply | Sharkoon Rebel P20 750W |
Mouse | Cooler Master MM730 |
Keyboard | Krux Atax PRO Gateron Yellow |
Software | Windows 10 Pro |
Are those fans any good at low to mid rpms? 400-800rpm range..... Is it worth to save and get these over more expensive silent wings 4 140mm ?
Arctic P14 is complete crap when going above 700rpms and Arctic P14 Max is complete crap below 800rpms so both are terrible fans if you want a really quiet system at low rpms.
Be Quiet! Pure Wings also is noisy (motor noise) are Shadow Wings 2 using the same motor as Pure Wings ?
Need a good silent 140mm fans for case intake.
For example Arctic P12 is lightyears better than P14, P12 max and P14 max when it comes to silence in 400-1000rpm range.
