Old mechanical keyboard mod. Model: Ortek MCK-201 FX.
  • Thread starter Thread starter r9
  • Start date Start date
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
I came across a IBM model M mechanical keyboard mod on the youtube and got inspired. I was looking for model m but I could not find one instead model M found this Ortek MCK-201 FX which is great!
Sound preview.
[yt]iiA6kCeqaMg [/yt]
The keyboard dirty and plain.
Disassembled.
The keyboard is din-6 or AT(as I know it) the standard is basically the same as PS/2 or mini din-5 so cable change was doable. The original cable was not soldered to the board it was connected via connector so I used multimeter to find out witch wire is leading were and using fourth picture I changed the connector from din-6 to din-5 PS/2 cable.
The cables with connector moved to from din-6 to din-5 cable.
The mechanical switches are visible. As I find out they are white alps.
Back side of the keyboards PCB.
Left the keys in mixture of water and dish-washing liquid and brush them with a brush.
Drying over night.
Keyboard case cut and spray painted with noprep paint for plastic
Assembled
I`m not sure at the moment that project is over. I`m still considering painting the keys black and red combo and applying the lettering stencil and finish with matte spray.
impressive work
  • Like
Reactions: r9
Nice work there.
  • Like
Reactions: r9
paint the keys black!
  • Like
Reactions: r9
^^^ :roll: Hope you got good memory cause you'll lose your letters
Does look better and much cleaner. The color of those oldies look so dirty and icky.
  • Like
Reactions: r9
Nice! I like it and I may do this with a few of old IBM keyboards I have laying around. :toast:
  • Like
Reactions: r9
Nostalgia my brother. I guess you never had commodore, amiga or 386.
Nice! i like the look of the original color key with the rest of the keyboard dark :toast:
But why going to the trouble of wiring when all you have to do is buy an adapter for these old keyboard in to PS2 connecter
I still have an old keyboard like that with an PS2 adapter & it works really good but now i may have to painted the keyboard dark color so it looks better...
Nah! it's a good idea but i don't use it anymore so would be a waste of time & paint...:ohwell:
  • Like
Reactions: r9
Nice work, but I would never do that to my own model M, I am too fond of the oldskool look myself :)
  • Like
Reactions: r9
Nice to see another board saved. Looks pretty good. I never had any luck with paint staying on plastic embedded with oils from hands hope it works well for you. I would never attempt painting the keys for this very reason. But you may consider something like Non-Transparent Keyboard Stickers
Congrats and good luck. :toast:
  • Like
Reactions: r9
It is not that much work and I wanted black cable anyways.
I know it just that it's easier & much faster to use an adapter ;)
I didn't thought about that , it would be a bit of a pain in the butt to paint the cable black & not to mention an accordion cable...
Changing the cable was in fact a really good idea :rockout:
yea and plus those old cables are short.. Those cables are meant for old Desktop pc's.. :toast:
You can also dye the key caps with RIT.
LC
http://retr0bright.wikispaces.com/
Retrobrite that keyboard, it will take away the oxidization in the plastic.
ALSO that doesn't look like Model M switches to me, Model M use buckling spring type switches. THOSE look like ALPS switches.
Hope my information helps out.
AH right sorry, i missed the line in the original post about them being alps.
I had a commodore way back. I do still have a really old desktop pc with the huge kb that has the curly cord. I wish I had it near me to get pics of it up. I plan to restore it sometime.
The kb looks awesome.
Crazy what a good cleaning can do!
