Best cpu benchmarks to test thermal capability of cpu cooler ?
162 (0.13/day)
System Name Mypc
Processor AMD Ryzen 5 5600x
Motherboard MSI MAG B550M BAZOOKA
Cooling Coolermaster Hyper 212 Rgb
Memory Corsair 3600 mhz Cl16 ddr4 8x2
Video Card(s) Asus RX 6750 XT Rog Strix OC Edition
Storage Samsung 990 PRO 1TB + Samsung 980 Evo 50gb
Case Coolermaster TD500 Mesh White
Power Supply Corsair CX-650F RGB
I have tried cinebench and 3dmark, both reports lower temperature values than when im gaming. What software should i go for, preferably free to test the thermal efficiency of my cpu cooler.
2,235 (0.43/day)
System Name Ultima
Processor AMD Ryzen 7 5800X
Video Card(s) Palit GeForce RTX 4070 12GB Dual
Storage WD Black SN850X 2TB Gen4, Samsung 970 Evo Plus 500GB , 1TB Crucial MX500 SSD sata,
Display(s) ASUS TUF VG249Q3A 24" 1080p 165-180Hz VRR
Case DarkFlash DLM21 Mesh
Power Supply Corsair RM650
Mouse Rog Strix Impact 3 Wireless | Wacom Intuos CTH-480
Keyboard A4Tech B314 Keyboard
curiously, what game is making your CPU heat up more than cinebench?
  • Haha
Reactions: Lei
162 (0.13/day)
System Name Mypc
Starfield and other cpu heavy games, i have tried 3dmark cinebench and prime95 aswell. Games make my cpu heat up more, maybe it is because the gpu also outputs heat so the air the case gets hotter ?
Any benchmark program that stresses both the gpu and cpu simultaneously to the fullest ?
freeagent
10,390 (4.30/day)
Winnipeg, Canada
Cooling Thermalright Phantom Spirit 120 EVO, 2x T30
Memory 2x 16GB Lexar Ares @ 6400 28-36-36-68 1.55v
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
al_bundy
LiquidExtasy Rep
80 (0.13/day)
Germany
Hi, may be ur settings was wrong? The youtuber use here in Germany Furmark for GPU and cinebench or P95 for the cpu.
I use Furmark and P95. I can see with Hwinfo and/or Coretemp how many watts the cpu/videocard needs.
las
1,693 (0.37/day)
System Name Meh
Case Fractal Design North XL
Audio Device(s) FiiO DAC
Games should not really make your CPU get hotter than Cinebench. Probably the GPU yes. Try and improve your airflow.
What is the temp for CPU and GPU in games? And Cinebench?
1,842 (0.33/day)
Azalea City
System Name Test Bench #3
Processor Ryzen 5 8600G delidded, +200PBO -30CO
Motherboard B650M-HDV M.2
Cooling Water, liquid metal
Memory TRIDENT Z5 @8400CL36
Video Card(s) 760M @3300MHz
Storage Samsung PM981
Display(s) MAG401QR
Case Open Frame
Audio Device(s) Logitech Z623
Power Supply EVGA P5
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 10 Pro
Benchmark Scores https://hwbot.org/user/luke
Y-cruncher is pretty brutal
381 (0.45/day)
Processor AMD Ryzen 7 7800X3D (4.2Ghz base, 5.0Ghz boost, -30 PBO offset)
Video Card(s) PowerColor Radeon RX 7900 XTX Red Devil OC 24GB (2.39Ghz base, 2.99Ghz boost, -30 core offset)
Mouse Logitech G502 X LIGHTSPEED Wireless Gaming Mouse
Keyboard Keychron K4 Wireless Mechanical Keyboard
Software Arch Linux
OCCT? OCCT has a pretty harsh CPU test based on my own experience.
1,842 (0.33/day)
Azalea City
Display(s) MAG401QR
Case Open Frame
Software 10 Pro
If you want to try a non-synthetic workload that really cooks, try folding@home. Just be sure to finish those work units that you started.
310 (0.50/day)
Processor AMD Ryzen 7900X
Motherboard MSI MPG X670E Carbon WiFi
Cooling Custom Loop (Watercool/HWLabs)
Memory G.Skill Trident Z5 DDR5-6000 64GB (F5-6000J3040G32GX2-TZ5K)
Video Card(s) Gainward RTX 4090 Phantom GS
Storage 7 x M.2, 4 x SSD, 2 x HDD.
Display(s) Alienware AW3423DW
Case Corsair 7000D Airflow
Audio Device(s) Logitech Z207, Shanling UA1 Plus
Power Supply Corsair HX1200
Mouse Logitech MX Master
Keyboard Logitech k360
Benchmark Scores None, but I think they'd be fairly decent.
OCCT is an excellent All-in-One (CPU, RAM, GPU) stresstester. Whether or not it's best I've no idea, but I haven't seen a point in using anything else for years now.
2,373 (0.55/day)
Audio Device(s) A LOT
I think something is wrong if you’re using the 5600x in your system specs. Gaming shouldn’t be worse than those benchmark tests and while your 212 isn’t the greatest cooler it should handle that cpu just fine.
ir_cow
5,019 (0.83/day)
USA
That's bizarre I don't think I've ever seen a game run hotter than Cinemark
OneMoar
There is Always Moar
8,837 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
Boost Clocks Can Result in Higher Per core temps due to the extra headroom for voltage/frequency compared to an all core stress test
266 (0.13/day)
System Name Ryzen 1
Processor Ryzen 5800X
Cooling Scythe Fuma 2
Memory 32GB Patriot Viper 3600 CL16
Video Card(s) AMD RX 7800 XT 16GB
Storage SSD's
Display(s) HP X32 32" 1440p 165Hz
Case Phanteks P400A
Power Supply Superflower Leadex III 750w
^ This. My CPU gets hotter playing FarCry than when stressing with OCCT or anything else. Totally normal.
@OP if you want to get a better cooler try to find something with a nickel plated cold plate. Direct heatpipe coolers like the Hyper 212 aren't great for Ryzen chips. I would look at a Peerless Assassin for $34
3,516 (0.48/day)
System Name Red Matter 2
Processor Ryzen 5600X
Motherboard X470 Gaming Pro Carbon
Cooling Water is Masterliquid 240 Pro
Memory GeiL EVO X 3600mhz 32g also G.Skill Ripjaw series 5 4x8 3600mhz as backup lol
Video Card(s) Gigabyte Gaming Radeon RX 6800
Storage EVO 860. Rocket Q M.2 SSD WD Blue M.2 SSD Seagate Firecuda 2tb storage.
Display(s) ASUS ROG Swift PG32VQ
Case Phantek P400 Glass
Audio Device(s) EVGA NU Audio
Power Supply EVGA G3 850
Mouse Roccat Military/ Razer Deathadder V2
Keyboard Razer Chroma
Software W10
intel burn test can heat one up fast
7,981 (3.29/day)
California
System Name His & Hers
Storage lots of SSD.
Agree, my 5950X runs around 68C Cinebench and around 72-75C during gaming due to how it boost differently.
