Best Fan Hub
272 (0.06/day)
Meh I just use Swiftechs fan hub cheaper easy to work with takes PWM from the CPU header. But thats just me.
What fans are you connecting?
Out of the three you listed, one is a pwm and the others are 3pin. Next I noticed that the 10 port hub is only rated for 30 watts which will only be enough for 2 high power delta fans.
i have used it with some customers builds, quite great!
but i like more: Commander F5 – Multi fan controller easy to use, also does not compromise design since it has a great design, also there is a tocuh version, Commander FT – Touchscreen Fan Controller if you like a more complex design!
Regards,
