Best Modding Case?
nhlrocker
65 (0.01/day)
Processor Intel Core 2 Duo E6650
Motherboard Gigabyte P35-DS3L
Cooling Arctic Cooling Freezer Pro, 1x80mm side intake, 1x80mm rear exhaust, 1x120mm Intake, 1x80mm Intake
Memory Corsair XMS 3GB PC2-5400 DDR2-667 CL 4-4-4-12
Video Card(s) EVGA 8800GTS 640MB
Storage Seagate Barracuda 7200.10 250GB SATA2
Display(s) Viewsonic G790 + NEC AccuSync70
Case NZXT Trinity
Audio Device(s) OnBoard
Power Supply OCZ ModStream 520W
Software Windows XP
Ok so i want to get into case modding and stuff. So what would be the best case for that?
right now i have the NZXT Trinity
Also, what kind of things do i do to mod a case, and where can i get the stuff. i live in canada.
A basic non painted or coated BTX chassis, that's entirely spartan inside(meaning it doesn't come with formed or bolted-in drive bay(s)).
Cases are often crowded and you end up doing too much cutting to take pieces away, rather than building and adding unique pieces which would properly make it 'custom.'
any case is moddable really. top tools needed... dremel, jigsaw, screwdrivers, pliers, sandpaper, paint, primer, zip ties, electrical tape, a ton of time. lol
Just get a case thats fits your general idea of the finnished mod. Make sure it will accomadate your cooling plans (fans or water). The more basic the case the better. The bigger cases are usually better, the more room to get your hands in and to be able to hide wires is great. A removable motherboard tray can be realy handy.
:toast:
ok thanks guys. :)
If you have the money to mod one i always thought Lan-li's were awesome base cases, extremely simple and well built... Unfortunatly their price is a bit high to want to hack one up.
x2 The other nice thing about Lian Li cases is that you can buy replacement parts for virtually every part of the case. So if you mess up you can replace that part, also if you're a lazy modder you can often buy pre-modded pieces and parts of Lian Li cases. Another good modding case is the old Chieftec Dragon cases:
i LOVE that case! :rockout:
mine is the antec model (steel vs alu)
best $90 i everspent! :pimp:
Ya antec cases are pretty solid, i love the solution series, or the older lanboys (not the super)
I use this case as well. 1 problem is that space from edge of mobo to drive bays here's a example.
http://home.comcast.net/~asrock/IMGP2143.JPG
Whats been changed.
2 extra 120mm fan holes one top one at the bottom
all fan grills removed
Side added 120mm hole
soon to add 120mm mounting holes over psu to help it cool.
Total fans 6
120mm bottom
120mm top
2x80mm front
120mm rear
side 120mm
Case was only $50 over 2 year ago on newegg.
EDIT:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=chenming&x=0&y=0
awe man i miss those chieftec cases, i had a blue one paited red on the inside, it was great, i cut that thing a hundred times over lol and it still worked out. lol
I would say to go with cheap cases because they're really simple and easy to mod. I bought a $40 case and it was crap to start with, after cutting some holes, a side panel window and a repaint it not only looks good but cools much better than stock.
And your best friend for this would be a rotary tool (dremel). You can't really do anything without one.
