Best remote control switch for PC Start/Reset
696 (0.16/day)
India
System Name To be ALL IN ONE MACHINE. but not yet
Processor i7 3770k
Motherboard Asus P8Z&&-V Deluxe
Cooling Thermalright Silver Arrow
Memory Gskill Ripjaws 1600Mhz 8GB *4 = 32GB
Storage Samsung pro 840 256GB, Segate 3TB and 1TB
Display(s) LG 23" Full HD LED
Case Antec LanBoy Air
Power Supply Cooler Master M2 Silent Pro 850 Watts
Software Windows 7 ulimate 64bit
Hi guys,
Would please guide me on buy the best Best remote control switch for PC Start/Reset.
I do know some from logisys, but which one is the best?
EDIT:- is below switch is good for PC start/reset ?
http://www.geeks.com/details.asp?invtid=RM02&cat=GDT
Thanks.
Hi guys,
Thanks.
If it's a standard desktop PC, you need a open/close switch, not a 12v PS switch. Assuming you are connecting it to the PWR header on your mother board?
The power button on your PC is a momentary switch (push for "on" or push for "off"). I believe the remote switch you linked to is a toggle switch (toggles the contacts between closed or "on" and open or "off") and would not work.
It looked more like a 12v supply?
•Receiver Features:
•Receiver Input Voltage: 12 VDC
•Receiver Output Voltage: 12 VDC
•Receiver Output Current: 15 Amp Maximum
So, something more like this:
http://www.instructables.com/id/Universal-IR-Remote-Power-Switch-for-PC/
Or you can WOL with a smartphone.
Nice find... even has reset. Looks like a good product. Not sure why it doesn't go directly to the MB jumpers, or maybe it does and the power cable adaptor is for a override reset.
Well one thing I don't understand here is that, how it says start/reset your pc either manually OR remotely, as I can see that those power/reset wires from MB would go into PCI wireless card power/reset pins THEN WHERE WOULD THAT FRONT PANEL POWER/RESET WIRES GO ?????
Well I did read about installation pdf on that site i guess it has two option of power/reset wires to be connected on that PCI card.
can you just confirm.
The front panel wires would connect to the card and the card would connect to the motherboard.
A few years ago I took apart an old RC car and hooked it up to a USB header providing 5VSB power and the power and reset pins. Worked great. It was a fun and simple project.
Yes. I read about it on pdf , it has two options.
Just waiting the right time to order from frozencpu.com
univerasal remote control
compatable with every tech at home.
no installation required.
kick arse price
ONLY FOR 0.75 EURO
price is w/o shipment and taxes
:D
