Better Alternative than Reformatting my PC
webarchitect
5 (0.00/day)
Vienna, Virginia
I've been reading online that once a computer reaches a particular time (around 3-5 months), it needs to be reformatted.
I haven't reformatted my PC in over a year now. It's starting to run a bit slow. I was thinking if there was an alternative to cleaning up the PC without reformatting it. Could anyone give me some tips on how to go about it...
Thanks
3,527 (0.55/day)
UK
System Name Dream Weaver
Processor Ryzen 5600
Motherboard B450 MSI Gaming Pro Carbon AC
Cooling NH-D14
Memory 16GB Flare X @ 3200MHz CL14
Video Card(s) Sapphire Vega 64 Nitro+
Storage 500GB evo 970 m.2 + 4TB HDDs
Display(s) ASUS 27" 1440p 144hz FreeSync
Case Fractal Design Define R3
Power Supply Corsair 850W
I remember reading something like that ages ago, saying that an OS has a "half life" as after a certain period becomes sluggish. I say that's BS, just use a registry scanner to remove un-needed crap, scan for spyware daily, and defragmant once a week or so and it's performance shouldn't deteriorate.
Deleted member 38767
Thanks
Nonsense. You could even install OS without formating. Most likely your PC need defragmentation. You could use some tools (I use O&O Defrag) or just run Windows defrag tool (right click on the partition -> properties -> tools). This should help. Best of luck ;)
webarchitect
5 (0.00/day)
Vienna, Virginia
Thanks for the advice. I'm also going to try removing some of the programs that run during start-up. I'm not really sure but maybe some background application is eating away my available resources at certain times. Plus the memory leaks caused by my browser (Firefox) might be adding to this slow-down.
Anyways, I appreciate all your advice. Thanks again.
3,527 (0.55/day)
UK
Cooling NH-D14
echo75
456 (0.07/day)
Denmark
System Name Main
Processor Q6700 @ 3.5Ghz (with 1.50 Vcore)
Motherboard P5K
Cooling Xigmatek HDT S1283 (amazing performance)
Memory Corsair 800mhz 4GB @ 864mhz
Video Card(s) Asus 8800GT@ 720/1800/2100,blue Pcb with 92cm Glaciator cooler(4870 still under testing)
Storage Seagate 250GB SATA , 500GB eSATA
Display(s) LG Flatron 19"
Case Antec Designer (modded)
Power Supply Corsair VX 550W
Software Win XP Pro SP2
Benchmark Scores 3Dmark06 = 15,253 for 8800GT, 3Dmark06 = 15,807 for HD 4870
Thanks
whoaa, where did you read such funny stuff, :shadedshu true to point frequent use, repeated program installating , uninstalling, file transfering and all other stuff can create fragments on your hard drive, unused registry crap, broken entries and a bunch of other crap too. Hoever proper system maintainace will keep your system running fine without any need whatsoever to format your PC.
If your PC is suddenly getting slow it may be spyware thats slowing it down. I personally have a barricade of defences to keep em at bay , then i use crapcleaner often , defragment occasionally, disk error check/fix when needed and manual registry spring-cleaning if the need arises. One of my systems has been running now for 2years (TWO) with no problems.
If you must , you can just do a windows re-install instead of a format from scratch. here is a guide- http://www.michaelstevenstech.com/XPrepairinstall.htm
DarkMatter
1,714 (0.27/day)
Processor Intel C2Q Q6600 @ Stock (for now)
Motherboard Asus P5Q-E
Cooling Proc: Scythe Mine, Graphics: Zalman VF900 Cu
Memory 4 GB (2x2GB) DDR2 Corsair Dominator 1066Mhz 5-5-5-15
Video Card(s) GigaByte 8800GT Stock Clocks: 700Mhz Core, 1700 Shader, 1940 Memory
Storage 74 GB WD Raptor 10000rpm, 2x250 GB Seagate Raid 0
Display(s) HP p1130, 21" Trinitron
Case Antec p180
Audio Device(s) Creative X-Fi PLatinum
Power Supply 700W FSP Group 85% Efficiency
Software Windows XP
That's what everybody should do. :)
But for some people (or scenarios) is just easier to re-install or even format. It depends on the use you give to your PC, how many programs you have, etc. For example, I don't bother to do all the maintenance on my second and third PCs and in the laptop and HTPC. It's just easier and less time consuming to re-install and eventually format. As long as you have your data system well stablised and have all the drivers at hand, a reinstall from scratch only takes an hour or so of your time.
Mussels
Freshwater Moderator
58,412 (7.77/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
yup. i have all my essential programs installers in the one folder and no data on the C: drives except pics/downloaded crap, so i can format and reinstall any rig (games aside on the gaming rig) in under an hour.
AsRock
TPU addict
19,257 (2.95/day)
UK\USA
Cooling D15
Yeah like others have said try cleaning the stuff of it you do not use any longer.
JV Tools is a pretty sweet program. There's a version 4 which is freeware if you can find it.
However i do reinstall every 5 month max as it does give a speed boost whot ever you try and is good idea anyways due to not all malware \ spyware is found by programs anyways. people like to think they do.
Try removing startup programs though MSConfig which you run from the run start menu or a dos box.
If you do that check for what each startup program does ask here or \ and do yahoo\google searches on them.
All so check services as well as a lot of program add crap to there too.
You could add another hard drive if you do not have a partition setup for daul boot of the same HDD.
8,519 (1.34/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
I would pull off some auto start up programs. If windows(please fill in sys specs :)) run msconfig and see what is starting up automatically. You can disable a lot of crap, especially if you bought a bloated windows(ie Dell, Gateway, ect) version.
I havnt played with Opera yet, but sounds like a good tool.
And btw welcome to TPU!
Stearic
104 (0.02/day)
Maintenance.
I just reinstalled XP last week because of major hardware upgrades and felt that a clean start would be better. Otherwise, I could have continued - it was running fine even after more than one year continuous usage and heavy gaming. Despite having about 20-30 games, a ton of programs and a few hundred gigs of files on it, it was running as good as new.
Just used to do some basic maintenance. Most important was avoiding malware and junk (as opposed to useful programs) from accumulating on it.
And:
-AV scans with AVG every weekend or two.Same with Spybot.
-Automatic disk defrag. Very convenient. Didn't waste time defragging manually or scheduling for nearly 1 Terabyte of drives. The auto defragger used to take care of defrags automatically as necessary and keep the drives fit, in great performance for quick file access.
-Cleaned out temp files and browser cache with Ccleaner every 2-3 days. Actually, didn't have much to clean out because I was doing it regularly.
-Restricted unnecessary programs from booting up with Windows during startup. Helped to keep bootup times short.
-Used Opera for browsing. Say NO to IE.:laugh:
-No registry tweaks or optimizations. Don't trust them.
That's all.
Remember, with Windows, prevention is far better than cure. Avoid malware, avoid fragmentation, avoid resource hogging programs, avoid installing unnecessary stuff.:toast:
imperialreign
7,043 (1.08/day)
Sector ZZ₉ Plural Z Alpha
System Name УльтраФиолет
Processor Intel Kentsfield Q9650 @ 3.8GHz (4.2GHz highest achieved)
Motherboard ASUS P5E3 Deluxe/WiFi; X38 NSB, ICH9R SSB
Cooling Delta V3 block, XPSC res, 120x3 rad, ST 1/2" pump - 10 fans, SYSTRIN HDD cooler, Antec HDD cooler
Memory Dual channel 8GB OCZ Platinum DDR3 @ 1800MHz @ 7-7-7-20 1T
Video Card(s) Quadfire: (2) Sapphire HD5970
Storage (2) WD VelociRaptor 300GB SATA-300; WD 320GB SATA-300; WD 200GB UATA + WD 160GB UATA
Display(s) Samsung Syncmaster T240 24" (16:10)
Case Cooler Master Stacker 830
Audio Device(s) Creative X-Fi Titanium Fatal1ty Pro PCI-E x1
Power Supply Kingwin Mach1 1200W modular
Software Windows XP Home SP3; Vista Ultimate x64 SP2
Benchmark Scores 3m06: 20270 here: http://hwbot.org/user.do?userId=12313
some other thoughts:
get a good file cleaner - and start removing stuff in temporary folders, especially temporary internet files. Thankfully, you're not using IE in this regard, as IE will hoard stoopifying amounts of temporary internet crap, and then hide it from you like a child who's stolen the cookie jar.
a good file cleaner will also look for duplicate files, but make sure to go over the list before just removing stuff; some "duplicates" aren't really duplicates at all, and just appear that way.
also, you can manually go through stuff as well, and remove files media files and the like you no longer need; also clean up a lot of the left over folders from removing applications. Although WIN will unistall them, folders and files are many times left behind.
turn off your HDD indexing service, unless you really, really need it . . . WIN will keep an on running list of where everything is located, in an attempt to find files quicker; but sadly, unless you do a lot of file searches, it really just slows the system down as time goes on.
Clean up your shortcuts within Start>Programs and clean up the number of icons and shortucts you have laying on the desktop, as well as the number of running applications that hang out in the taskbar; when WIN boots up, it checks the targets for all those shortcuts to verify that the application is still there, it can turn into a lengthy process when there's a ton of shortcuts laying around.
and these two alone will probably have the biggest impact on how your OS runs:
A good defrag application is a must; download the trial version of PerfectDisk - it can optimize your HDD while defragging, and can also be set up to defragment the HDD pagefiles on your next reboot - which is an area most defrag applications can't touch
also, pick up a good registry scanner, and remove a lot of the erratum that collects in the registry as well (just installing and removing other applications will leave broken registry values) . . . also find an application that can defragment and compact the registry as well
and one last thing, turn off WIN XP's disk defragmentation service!!! here: http://msdn.microsoft.com/en-us/library/ms932871.aspx This service chills in the background and will start to defragment your HDDs when the system is at idle or under low disk usage . . . problem being, is that 3rd party software does the job better, and WIN service will muck that up, and when your stored space starts growing, WIN service takes longer and longer to run, and in some instances doesn't like to relinquish control of the disk (it can't stop if it's in the middle of writing and copying files).
webarchitect
5 (0.00/day)
Vienna, Virginia
thanks for the tips ..I'll be trying them all out. I'm also looking in the possibility of probably installing deep freeze to keep my drive c: from accumulating too many files which are really unnecessary...so that I'll get a fresh system everytime I log in..I'll just move all my other files to d: or some other drive where I can modify or tweak them...I hope this works...
