Biostar Tpower i45 Will not detect hard drive
freaksavior
To infinity ... and beyond!
8,095 (1.19/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
Before you even ask. Yes the hard drive is fine. I have ran every hard drive test i could find.
2nd
Checked cables and tried different sata cables and ports.
It blue screens every time it starts to load windows like it see's the drive then doesn't. I have ran out of ideas.
I can't boot from CD either for some reason...
Is it set to RAID, AHCI or IDE mode, and what mode was Windows installed with?
Have you reset bios to fail safe defaults?
IDE, IDE and yes.
Im sure you have, but just in case. Have you cleared the Cmos, removed batt , Power supply from MOBO etc. Then tried it.
I had the same issue with my DFI P35 board, occasionally it wouldnt read the drives.
Also check if the jumpers on the hard drive are set correctly.
Try removing the DVD/CD drive
^ Yes, Also set the DVD as master drive and hd as slave.
It is all SATA drives No idea, i ditched that years ago.
I actually haven't taken the battery out yet. Completely forgot to do that. i will try that and the dvd drive unplugged.
p.s
I hate this board. yet to have a good experience with it.
now i get D4
seems like my crucail ballistix are bad.
but still says no hard disk detected.
Try it with just one stick of memory. Also if you have any different memory try that also. I had the same problem with mine and it ended up being the memory. I bought some Gskill and it started working fine after that.:rockout:
bad ram. Ugh stupid crucial.
Might as well try sticking them in the freezer overnight and try to salvage them.
